Results 1 to 7 of 7
Like Tree11Likes
  • 1 Post By JonnyG
  • 2 Post By 45bvtc
  • 5 Post By 45bvtc
  • 1 Post By tee-bee
Thread: Winter rims
    Sep 2011
    80
    Winter rims
    Hi all,
    what are your thoughts of these rims for winter use?
    4 X Alufelgen Felgen OXXO VAPOR 19 Zoll Audi RS3 Sportback 8P | eBay
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    they look good, but remember you can run 18'' winters, which will save quite of bit of cash when it comes to the tyres
    www.SubZerosystems.co.uk - IT Consultancy
    JonnyG's Avatar
    Aug 2008
    Leeds
    218
    Quote Originally Posted by tee-bee View Post
    Hi all,
    I would be careful about the offset (ET) ... it is stated as 35mm in that ad (if my German is correct !)
    45bvtc likes this.
    Audi RS3 in Daytona Grey, 7sp S-Tronic, Sept 2012
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,307
    And here's the ET explanation diagram for the original 19inch x 8J RS3 wheel again, just in case:
    So, if you're looking at 8J wheels with an ET of 35mm then the 68mm dimension (as shown in the diagram above) will INCREASE by 15mm (50-35) and the effect of which is that the wheel will stand 15mm further OUT from the hub i.e., 15mm CLOSER to the wheel arch = Ooops!
    Be VERY careful!
    Mr_Freeze and DAYTONA500 like this.
    Mr_Freeze's Avatar
    Feb 2013
    Trowbridge, originally from Leeds
    372
    Professor, errrr I mean John what's the recommended et for 8.5 rims?
    Also do you think you could put a 8.5 on the rear with a 235 tyre?
    One of 750 RS3, Ibis White, Buckets, Privacy glass, Black styling, Cruise control, Bose, Scorpion Cat Back Non-Resonated exhaust system.
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,307
    Quote Originally Posted by Mr_Freeze View Post
    Hey Neil, welcome home...
    Ok, we know that the 8J rim with a 235/35 does fit and has sufficient clearance (just) with 4/5 up.
    So lets do the math…
    1) Overall 'fitted' width of a 235/35 tyre on an 8J rim is: 246mm (taken from ETRTO tables)
    The 'ET' of the 8J rim is: 50mm (taken from Audi wheel rim markings)
    So, 246mm divided by 2 = 123mm
    And 123mm minus 50mm = 73mm i.e., the distance from the mounting face to the outside edge of the as fitted tyre
    2) Overall 'fitted' width of a 235/35 tyre on an 8.5J rim is: 251mm (taken from ETRTO tables)
    The 'ET' of the 8.5J rim is: 53mm (taken from Audi wheel rim markings)
    So, 251mm divided by 2 = 125.5mm
    125.5mm minus 53mm = 72.5mm i.e., the distance from the mounting face to the outside edge of the as fitted tyre
    0.5mm MORE clearance Neil, you decide, it's very, very tempting…
    And until you asked the question, and I did the sums Neil, I didn't know that!
    What a can of worms you've opened Neil, a right Pandora's box I'll be bound…
    And here's a wheel/tyre data diagram:
    KKM, Veneeringman, 8PARSY and 2 others like this.
    Sep 2011
    80
    Yea, unfortunately I've purchased a set of winter Vredestein tyres for my existing RS3 rotors (same like 45bvtc).
    Will be posting my shiny new brakes protected via POR-15 (thanks to 45bvtc again) as well.
    Will be looking for a set of summer 19" rims but the fronts at 8.5J come spring time...
    45bvtc likes this.
  1. Winter Rims/Tyres - Did I get a good deal?
    By a6-chris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2012, 13:41
  2. Anyone else bother with 'winter rims'?
    By danA3T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th November 2010, 13:24
  3. Few pics with the winter rims!
    By joshW in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2007, 22:42
