AH FabricationsEM Tuning
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Macdaddy
Thread: The "S" button - coding question
    Mr_Freeze's Avatar
    Feb 2013
    Trowbridge, originally from Leeds
    372
    Ok guys, this ones for you clever coding peeps.
    Is there any way you can recode the "S" button so that it defaults to on and then you have to press to turn off?
    I think i would prefer it that way round if it can be done.
    Also is the exhaust valve powered open or is it powered closed, just in case it can't be coded, wondered if there were any other ways of doing this?
    One of 750 RS3, Ibis White, Buckets, Privacy glass, Black styling, Cruise control, Bose, Scorpion Cat Back Non-Resonated exhaust system.
    Mar 2011
    207
    Simple answers no.
    On the R32's, TTRS etc there was a mod which involved removing the suction hose which opens the exhaust flap (actuator)
    May be possible to have the exhaust flap open all the time but when I was last under the car I don't think it's the same setup.... I'll double check
    RS4 Gone.... RS3 as the replacement
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    Doesn't it sharpen throttle response as well?
    www.SubZerosystems.co.uk - IT Consultancy
    robbiemac's Avatar
    'S' Button engaged....
    Nov 2012
    733
    ha ha ha.... before I even reach the end of my drive.......
    . push the 'S' button
    . push the traction to 'Sport
    . select 'S' in the DSG box (unless I've woke up + select manual)
    and off we go, great shout though; this set up should be default
    With great power comes great responsibility.......
    Mar 2011
    207
    Quote Originally Posted by klauster View Post
    I thought so, All the vacum pipe removal will do is make the car sound like it does in 'S' but all the time.
    Mar 2011
    207
    Right ive had a look under the car, Its the same as other VAG marques with the pump activated actuator.
    If you wish to have your car like its in Sport all the time just pull off the rubber pipe from the actuator valve and plug it with a screw, then cable tie it up out of the way.
    Mr_Freeze likes this.
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    I have noticed that when on choke, the S button does nothing until it comes off choke. It then opens. I think it is forced closed so that would mean that if there were any timing/throttle response changes disconnection the pipe to leave it open may be a bad idea?
    2012 RS3 Ibis White | Black Styling Pack | Black Roof Rails | Bose | Cruise | Tyre Package | Privacy Glass
    P_G
    Oct 2012
    339
    Same thing happens on the RS4's, sport mode didn't open the exhaust flaps until after initial 30 second warm up phase. Those that disconnected / plugged their exhaust flaps didn't have any issues with the warm up phase by doing that.
    Jan 2011
    224
    Its probably to stop people ragging it when cold.
    2008 A3 1.8t FSI Sportback S-Line - Avus Silver - Full spec.
  1. Custom Code Questions?
    By s-line stu in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th May 2008, 13:46
  2. an e-code question
    By 4Ring Jelly in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th April 2007, 05:24
  3. RNS-E VAG coding question
    By jvbates in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st April 2007, 20:58
  4. engine code question??
    By nky_84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2007, 07:17
  5. quick engine code question
    By paulwakinshaw in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2005, 12:05
