JMB RetrofitsChris Nott
    Feb 2012
    South
    138
    Anyone gets this at 4th gear?
    Guys,
    I am not sure this is an issue or not. When going from 3rd to 4th or 5th to 4th in manual (I can't seem to feel it in D or S), I feel a slight "disconnect"/delay associated with some movement that I can't quite describe. I cannot call it a judder as this is much more subtle.
    Is anyone getting the same? Does anyone know what it may be? Am I changing gear too early?
    Stephane
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,156
    Sounds like a bit of 'computer says no' to me, whatever you are asking for the S-tronic software doesn't like. I think I know the sort of thing you mean, at least as far as the downshift is concerned, changing down on track in manual sometimes the box doesn't react as quickly as you think it will - which is odd because left to it's own devices in S it will select that same low gear quite happily - some form of manual safety measure I suspect.
    Mar 2011
    207
    Not noticed this at all, What kind of revs you changing at?
    RS4 Gone.... RS3 as the replacement
    Feb 2012
    South
    138
    I'll be changing between slightly under 2krpm and 2.5krpm, like the D mode would. This is mostly felt at low speed from 0 to 30mph
    It's not the delay between shifting and the actual gearing, but more like a mechanical wobble, literally. It will shift but you have the wobble and impression that it's hesitating like a slight stutter.
    Sorry guys very difficult to explain, but easily reproduced.
  1. Replies: 9
    Last Post: 22nd July 2011, 06:44
  2. Anyone else seen this on Top Gear
    By dpeilow in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2006, 00:09
  3. Should I get this work done on my 1996 A6?
    By cble8869 in forum Classic Audi Forum
    Last Post: 12th December 2003, 16:42
  4. Anyone seen this colour S3?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2003, 17:29
  5. Anyone remember this S3 battle....
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2003, 13:52
