Badger5Monster Motorsport
Results 1 to 28 of 28
Like Tree9Likes
  • 1 Post By P_G
  • 1 Post By klauster
  • 1 Post By P_G
  • 1 Post By 45bvtc
  • 1 Post By P_G
  • 1 Post By JonnyG
  • 2 Post By RYes3
  • 1 Post By RYes3
Thread: Another Alloy wheel question... sorry
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    Can I just check. For those with standard and uprated alloy wheel option on the RS3...
    What size are your alloys?
    Are standard alloys on the RS3 19'' 8.0J all round?
    Are the upgraded alloys 8.5J all round or just the front?
    Looking to change my alloys and need to check before I make a mistake
    The alloys I am looking at are 8.5J 19''s, I don't want rubbing
    Help appreciated...
    www.SubZerosystems.co.uk - IT Consultancy
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,292
    Quote Originally Posted by klauster View Post
    Help appreciated...
    Standard fit is 19'' 8.0J FRONT and REAR: Audi Part No: 8P0601025CP @ 19-inch x 8J ET50 Tyres, as you know, are: 235/35 front's and 225/35 rear's
    Optional is an 8.5J FRONT with a 255/30, while the rear remains as an 8.0J with a 225/35
    Note: I run 235/35 winter tyres on both the front and rear on the standard 8.0J rims, and I do, occasionally, hear the rear tyres 'kiss' the inner wheel arch/trims - no sign of damage, however.
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    many thanks for that... next question is then...
    Could you run 8.5J on the rear with 235 tyres and not have an issue?
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,292
    A 225/35 on an 8.0J rim is 239mm (max in service) width, however, on an 8.5J rim this width goes up to 244mm.
    So, for a 235/35 on an 8.5J rim you're going to be increasing the (max in service) width by 10mm to 254mm (and that’s 15mm above existing).
    So, if the ET of the 8.5J wheel remains the same as the 8J wheel you'll be loosing at least 7.5mm clearance from existing; good luck Nick, let me know how you get on…
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    offset of the new ones is ET45... if that helps any....
    P_G
    Oct 2012
    339
    http://www.audi.co.uk/content/dam/au...-sportback.pdf
    On page 24 Option Code F74 8.5Jx19 wheels with 255/30 front and 225/35 rear tyres. I gather they are ET50 but it doesn't say but would make sense if the 8J's were also ET50. Funny though because on the drivers door the tyre pressure list includes front and rear pressures for 235/35 tyres. I have 235/35 fronts and rear and have to say even with family in there is no rubbing on the rears against the arches. My winter 18's are also 235/40's but they are ET45 8JX18 and again no rubbing.
    I'm guessing it will be tight and you'll have to stretch the tyres on them so they don't rub in the arches. Sportec run 9x20 rims on their project RS3 which are ET50 so you would think an 8.5Jx19 ET45 would work.
    45bvtc likes this.
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    on ballz, I hate being cutting age and one of the first to jump in thanks for the info
    45bvtc likes this.
    P_G
    Oct 2012
    339
    Get them on with 235 tyres so I can see if my dream of Sportec Mono 10's can be a reality!
    45bvtc likes this.
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,292
    Maybe this will assist:[IMG][/IMG]
    robbiemac likes this.
    P_G
    Oct 2012
    339
    If I am working this out right;
    8J = 203.2mm Centre 101.6
    8.5 J = 215.9mm Centre 107.95
    12.7mm difference
    ET50 on 8J means 50mm from centre so mounting plate is 51.6mm from outer edge
    ET45 on 8.5J means 45mm from centre so mounting plate is 62.95mm from outer edge
    11.35mm wider on the outer
    In effect like running 10mm spacers on each hub at the back. The difference between 225 ans 235 is 100mm, 5 mm on each side of the wheel so with 235 tyres on they would be 6.35mm futher out than 8JX19 ET50's on 235's. I think it could just work on the rears, plenty of pace on the fronts.
    The only other things is whether the centre bore is 57.1mm or 66.1mm. If the former OK, if the latter spiggots needed as well.
    45bvtc likes this.
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,292
    I agree P_G, but don't forget to consider the everso slight arc from static to full droop to full compression, not just the static position. My 235's on the rear are ok in static and droop, but 'kiss' on compression. I really do think Klauster should try it first...
    P_G
    Oct 2012
    339
    Maybe the solution is 8.5J's with 225's on the rear then.
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    will 225s fit ok on 8.5J? just look slightly more stretched?
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    If these have preiously been fitted to a MkV Golf R32, can we assume that the bore is correct?
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    a deposit has now been paid by the way
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,292
    225's are a recommended fit for 7.5 to 9.0J wheels - but they'll expose a whole lot of wheel rim
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    looking at this:
    Tyrestretch.com
    I'm not entirely sure 225s look right
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,292
    Just double checked (while clearing out last Sunday's sheep droppings from the rear wheel arches): 235/35's on 8.0J rims fitted to the rear of my car have 'kissed' the inner dirt shields so; my best guess is that 8.5J rims with 235/35's will fit, but you may have to do a little manipulation of your inner dirt shields to maximise clearance - there is loads of space behind the dirt shields…
    JonnyG's Avatar
    Aug 2008
    Leeds
    217
    Just to add that the "optional" Audi front wheels have an ET53 offset - so they are 19 x 8.5J ET53 (with 255/30 tyres)
    45bvtc likes this.
    Audi RS3 in Daytona Grey, 7sp S-Tronic, Sept 2012
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    I have the upgrade, 8.0 rear 8.5 front et50 and et53 respectively.
    I have pictures of the stampings somewhere if you want to see them
    Kelza and 45bvtc like this.
    2012 RS3 Ibis White | Black Styling Pack | Black Roof Rails | Bose | Cruise | Tyre Package | Privacy Glass
    JonnyG's Avatar
    Aug 2008
    Leeds
    217
    Quote Originally Posted by RYes3 View Post
    Have you driven the car with standard wheels too ? just wondering what difference you can feel ?
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    No I haven't actually, I did drive one on a test drive without them but I didn't get it going enough
    I have never noticed any under steer even in the wet, in fact it is the rear that starts to skip first.
    45bvtc likes this.
    Mr_Freeze's Avatar
    Feb 2013
    Trowbridge, originally from Leeds
    371
    Interested to know if you run 235's on the back, does this not alter the rolling circumference of the rear and mess up the gearing?
    One of 750 RS3, Ibis White, Buckets, Privacy glass, Black styling, Cruise control, Bose, Scorpion Cat Back Non-Resonated exhaust system.
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    Mr freeze john was running winters ,235 up back
    P_G
    Oct 2012
    339
    There is only a 1.1% difference inbetween 235/35 and 225/35 thus should adversley affect anything else
    JonnyG's Avatar
    Aug 2008
    Leeds
    217
    Quote Originally Posted by Mr_Freeze View Post
    It actually makes the fronts and backs the same rolling circumference !
  28. #27
    Mr_Freeze's Avatar
    Feb 2013
    371
    Quote Originally Posted by JonnyG View Post
    Yeah i know that, but if the car is designed to run 235/225 then the gearing will have been designed to take into account that the rear wheels are spinning faster, therefore by running 235 rear the wheels will be rotating slower than design spec.
    Would this not put extra strain on the diff as it will be not balanced as per spec?
  29. #28
    P_G
    Oct 2012
    339
    I would suggest that a 1.1% difference is well within tolerance.
  1. Sorry! Another RS4 Wheel Question!!
    By mountainmile in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th December 2007, 02:43
  2. Alloy wheels question
    By FoxyRoxy in forum Volkswagen and other VAG
    Last Post: 10th June 2007, 14:48
  3. alloy wheel question plz help
    By BAMS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2007, 13:48
  4. Another DIS service question (sorry)
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th October 2006, 19:48
  5. Alloy wheels question
    By johndow in forum Handling
    Last Post: 22nd December 2005, 15:34
