Hi all,
ive been in and out of audi since August of last year with a metallic sound, the noise is intermittent , on start up sometimes it will make the noise which echo's away to nothing , if I blip the brake in 3rd and it changes down to 2nd the noise is present and lowers with the rev's, also this noise can be heard when messing around with the blow heater setting
audi said it was the secondary oil pump coming on to much and apparently the values were changed and it shouldn't come on so much,unfortunately the noise is still there audi rang today to say they test drive it back to back with another rs3 they have in and it too makes the same noise so it's fine.
Im quite sure none of you guys on Here suffer with the noise as I've never seen a post about it and also no one has posted about it in response to my old previous posts.
please guys check if you have this issue
cheers
cheers
