Badger5JMB Retrofits
Results 1 to 12 of 12
Like Tree6Likes
  • 4 Post By jb0o
  • 2 Post By Macdaddy
Thread: How to launch control properly...?
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    Now the car is run in properly I'd like to start using this function
    whats the correct sequence to get the biggest buzz and fastest times?
    www.SubZerosystems.co.uk - IT Consultancy
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    1. Left foot on brake
    2. Turn ESP OFF
    3. Hit the accelerator all the way (revs should limit to 3k)
    4. Take a deep breath
    5. Remove left foot and watch the world go backwards.
    Enjoy!
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    Mar 2011
    207
    Or for the faster version"
    2. Turn ESP OFF
    2A *Select Sport on the dash and the gearbox*
    monkeyboy_marcus and KrAzY K like this.
    P_G
    Oct 2012
    339
    It doesn't work as well on winter tyres!
    I would also add hit sport button for added aural pleasure to macdaddy's list
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,609
    Doh, my bad. Launch control wont work without being in 'S'.
    Jul 2007
    151
    You also forgot...
    Download this to see what times you got...
    https://itunes.apple.com/gb/app/dyno...286208729?mt=8
    May 2010
    37
    Be careful launching, look out for your prop shaft in the rear view mirror haha!
    Oct 2012
    LEEDS
    81
    Mar 2014
    Durban, South Africa
    Quote Originally Posted by Macdaddy View Post
    2. Turn ESP OFF
    ....what does it mean if I did all of the above but when I plant the accelerator the revs go up to +- 3000 but don't stay there? it drops back down and there is a big time lag before it launches?
    thanks.
    Mr_Freeze's Avatar
    Feb 2013
    Trowbridge, originally from Leeds
    372
    If it drops back down then you must be releasing the accelerator.
    You have to plant the right foot all the way down and keep it there, the revs will sit somewhere near 3k and the engine will rumble and make weird noises like it's running on 3 cylinders.
    Then release the brake and watch everything go blurred in your peripheral vision.
    Only then can you change the position of the accelerator to suit your needs.
    One of 750 RS3, Ibis White, Buckets, Privacy glass, Black styling, Cruise control, Bose, Scorpion Cat Back Non-Resonated exhaust system.
    Mar 2014
    Thanks...i will be sure to try again
  1. DSG 2.0tdi "launch control feature"
    By Atomic in forum Handling
    Last Post: 4th January 2007, 00:14
  2. Launch Control - Not sure
    By Steve-L in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2006, 22:13
  3. DSG Launch Control whats your veiws
    By imported_S_Line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2006, 17:18
  4. Launch Controll Question
    By imported_kkline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th September 2005, 13:43
  5. New BMW m6 featuring "launch control"
    By imported_Yaseen in forum Other Brands & Models
    Last Post: 18th April 2005, 07:06
