Monster MotorsportEM Tuning
Results 1 to 18 of 18
    Bilen's Avatar
    Dec 2012
    Surrey
    33
    Question Brakes- other issues other than "squeal"?
    Anyone else had issues with the brakes other than the well documented squeal?
    Mine are pulling to the left and stick really badly when the car is left overnight in the rain or the cold
    Also in the pouring rain it feels like there is a dead spot on the braking and it takes a while for them to respond which doesn't inspire much confidence when driving in the wet, when the rest of the car is peerless in in the wet with winter tyres...
    When I press the brakes hard from motorway speeds there is a strange metal drumming noise when I depress the pedal?
    Going into the local dealer to get technician with me out, to see if they can spot something, but its already been on once and they said everything was fine.
    since then having done Geneva and back in 4 days I'm convinced that there is something wrong
    Has anyone else experienced similar issues?
    thanks
    B
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,156
    No I've not experienced anything like the pulling to the left. I was in the pouring rain on track on Friday and brakes were superb for 47 flat out miles including one big hairpin braking from 110 to 30mph.
    The brakes do stick if the discs are wet overnight, this is also common on performance cars, nothing much you can do about that if the car is parked outside overnight. If the car is kept in a garage you can avoid this by applying the brakes a few times before you put it away.
    I do sometimes get a kind of 'duurrrrr' noise after using the brakes heavily and getting the disks hot but that is common with drilled disks (slotted/vented would really be ideal).
    When the brakes get really hot on track and are cooling afterwards the pops and bangs from the 'floating rotor' hub and disc being made of different metals and contracting at different rates sounds like gunshots.
    Mr_Freeze's Avatar
    Feb 2013
    Trowbridge, originally from Leeds
    371
    Quote Originally Posted by MBK View Post
    And i can vouch for the fact that they were hot!!!
    One of 750 RS3, Ibis White, Buckets, Privacy glass, Black styling, Cruise control, Bose, Scorpion Cat Back Non-Resonated exhaust system.
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,156
    Quote Originally Posted by Bilen View Post
    Bilen, just a thought, did you come to the RS3 from a manual car? I only ask because with the s-tronic box it can sometimes feel like you need a slightly firmer initial shove on the brake pedal due to the lesser engine braking effect when you lift off the throttle. Also the ESP system on the RS3 is quite intrusive if you have it on. The brakes themselves should feel mighty when given a good push.
    Bilen's Avatar
    Dec 2012
    Surrey
    33
    MBK, Thanks, no I came from an stronic s3 sportback, and the brakes on that felt more stable,
    the RS3 was lightly used when i purchased it (5000 miles) so there may be something I inherited?
    The brakes do feel solid when you give the brakes a good shove, but the instability during braking definitely doesn't feel the way it should, we shall see
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,156
    Yes best get that checked. A warped disc perhaps, do you get a judder through the pedal? The dealer can easily measure the disc to check this.
    Bilen's Avatar
    Dec 2012
    Surrey
    33
    Looks like others have experienced similar issues on other forums, at least I have some others with similar issues elsewhere, sounds like it might be warped discs...
    P_G
    Oct 2012
    339
    I have the same issue as Bilen in extreme wet conditions and when there is a lot of spray on the roads. It is almost like the brake have lost all heat ouot of them and there is water between the disc and pad. I don't think the caliper being mounted to the front of the discs helps with the cooling for the brakes acting as a water conduit to them as I never experience this on the RS4. Coupled with hard pads that don't retain heat to evaoprate waht water goes near them. This is alos the time when the car will pull left / right but after a couple of prods the retardation is back at it's best.
    As said mine is only in extreme wet conditions / snow and on the motorway so when I am driving in such situations I just adapt to pumping the brake a little which sorts it out. I do honestly believe a lot of the issues people are experiencing with brakes is down to hard brake pad compund both for this and the squeeling.
    Mar 2011
    207
    I thought i had warped discs, but after watching the speedo it turns out its the down change causing a surge of engine breaking.
    Nov 2012
    Birmingham
    Hi guys...
    Quick question... Does the RS3 have heated wing mirrors? Mine arent working not that i really need them and am wondering if they are even supposed to be heated?!! if so i need a word with Audi!
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,292
    Quote Originally Posted by gemmo30 View Post
    Hi guys...
    OH YES!!! BUT make sure the mirror-adjust switch is central (not to the left, or the right, but central) for both to 'heat'.
    Mar 2012
    Planet Claire
    258
    Hi guys...
    Yes they are heated Gemmo, the switch on the door card should be in the vertical position for them to heat the mirrors.
    Whoops John beat me to it...lol
    Nov 2012
    Birmingham
    Brilliant thanks guys.
    Bilen's Avatar
    Dec 2012
    Surrey
    33
    Had a technician in the car today, who heard the sound, she goes in tomorrow and they're taking the front brakes off to look,
    The head tech heard it and agreed something was definitely not right.... we'll see what they say tomorrow.
    They also said that the fix for the squalling brake issue was imminent, whatever that means?
    Bilen's Avatar
    Dec 2012
    Surrey
    33
    Worn inner pads on the fronts after 11.5k miles, wear and tear items.... £430.00 whoopie, hopefully that fixes it and they are rather important...
    Mar 2012
    Planet Claire
    258
    Gemmo PM'd you re the wheels.
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,156
    thanks for letting us know. I will check the inner pads on mine today the outer pad still seems ok but I must be getting close to needing new pads soon. I think I will be going for some upgraded discs and pads though rather than OEM, especially at £430 just for OEM pads!
    JonnyG's Avatar
    Aug 2008
    Leeds
    217
    Also in the pouring rain it feels like there is a dead spot on the braking and it takes a while for them to respond which doesn't inspire much confidence when driving in the wet, when the rest of the car is peerless in in the wet with winter tyres...B
    I've had this a few times ... it's very scary for a second before they start to bite properly !
    Audi RS3 in Daytona Grey, 7sp S-Tronic, Sept 2012
  1. Intermittant ABS/ESP light and other issues related
    By Steve B5 Biker in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th October 2012, 10:28
  2. Replies: 0
    Last Post: 15th February 2011, 20:01
  3. s3 brake upgrades? also other tuning.
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2010, 11:34
  4. CV Joint / Steering Rack or some other issue?
    By Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2008, 07:38
  5. brake bleeding issues!!
    By mrj0ey in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2007, 21:52
