AH FabricationsSky Insurance
Results 1 to 35 of 35
Like Tree3Likes
  • 2 Post By 45bvtc
  • 1 Post By NHN
Thread: Oil and coolant required.
    jerseypaul's Avatar
    May 2011
    Jersey - Channel Isles
    242
    Hi gang.
    Just completed a 600 mile round trip in the UK.
    Mainly motorway cruising along with some A and B road blasting.
    After checking the car (4 k miles) I found the oil and coolant level just about in minimum.
    Same with you guys?
    Cheers.
    Paul
    2012 RS3 Daytona grey - VW T5 Transporter 4motion 130 - VW UP!
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    Mine is loosing coolant it's in on the 25th to be looked at. Oil is fine though
    2012 RS3 Ibis White | Black Styling Pack | Black Roof Rails | Bose | Cruise | Tyre Package | Privacy Glass
    jerseypaul's Avatar
    May 2011
    242
    I know new motors can use more with the higher temps during a running in process.
    just wondered if it was a known thing with this new 5 pot engine?
    JonnyG's Avatar
    Aug 2008
    Leeds
    216
    I've done about 5000 miles from new now.
    My coolant has dropped to the minimum mark and I'm keeping my eye on it to see if it has "settled" or continues dropping.
    My oil is about half way between max and min, so looks fine.
    Audi RS3 in Daytona Grey, 7sp S-Tronic, Sept 2012
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,279
    Quote Originally Posted by jerseypaul View Post
    ALL engines 'like' to be worked hard!
    Engines that don't get 'worked' generally develop glazed bores and develop high oil consumption and/or contamination from blow-by (spoken from 30-years experience in petrol/diesel engine (50 to 2000 BHP) design, development and test).
    Now, one of the issues I have with the RS3 is that when I'm driving in 30/40/50mph restricted zones with the gearbox in 'DRIVE', the gearbox drops into 6th and/or 7th gear ratios far too easily and the load on the engine is greatly reduced - see paragraph one.
    So I generally use the 'SPORT' mode in such restricted zones as this holds the gearbox in the 3rd and/or 4th gear ratios I'd normally expect with a manual gearbox. The added benefit for me is the car 'feels' more throttle/speed-controllable and the engine is working just that little bit harder.
    OK, fuel consumption will be a little higher (mine has done 25.6mpg from new) but if the engine could talk, it would be a lot happier.
    Note: I do this both with my 7-speed/DSG RS3 and 6-speed/DSG TT: the engine oil stays clean with consumption ZERO between changes. Neither do I have coolant loss issues.
    My advice: work those RS3 engines a little harder.
    RYes3 and robbiemac like this.
    jerseypaul's Avatar
    May 2011
    242
    Quote Originally Posted by 45bvtc View Post
    I do certainly use all of the rev range when warmed up.
    agree about S on the gearbox - quicker responding and better engine braking to.
    Will keep monitoring the levels.
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    That's very interesting! Thanks for that info!
    Jul 2012
    195
    I agree. Manual/Sport..Traction Control OFF only way.
    Never been in Drive..cant see the point.
    I like to build up a few credits,before giving it a belt.always av 28.5 mpg.
    At the end of the day car has the final say if you forget to change down anyway.
    Jul 2012
    195
    Quick Q for those that might know.
    As I only drive in Manual Mode.the Q is....... Which are quicker the Stick or the Paddles .
    I nearly always use the stick,as the paddles seem very slightly slower.Am I imagining this, or is there a technical reason why this should be so.
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    I never really noticed, I only use the stick in M when pulling out at junctions.
    Feb 2012
    245
    Best and cheapest place for oil is
    is opie oil online,
    Coming soon the new Audi RS3.... see it attached to your rear bumper on the Motorway no matter how fast you go!
    27,028
    Shouldnt really use that much coolant tbh, oil maybe a bit as my S4 used to burn it like the Saudi's supply it, but coolant either had some air in system which has burped out now from factory which is highly unlikely for 5k miles now or something isnt quite right.
    May 2012
    11
    Quote Originally Posted by RYes3 View Post
    Yep, mine too with exactly the same thing - into Warrington Audi on the 21st....
    27,028
    Sounds like a leaky pipe or maybe even a rad.
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    Quote Originally Posted by pauly-b View Post
    That's good news as mine is going into Warrington too!
    May 2012
    11
    I hope you have better luck with them than I did - they've no idea why the coolant would fall having pressure tested it, have never heard of the brakes issue either so gave them a good clean as it might be brake dust - despite what I'd told them beforehand..... Total waste of time with them if I'm honest....
    P_G
    Oct 2012
    339
    5k miles just ticked over on the clock and coolant is at normal level / just under 'Max' and oil is fine too.
    May 2012
    11
    The oil has never been a problem at all - never needed to top it up - but I've had to top up the coolant twice in 3400 miles.. The only thing they could guess it was 'its a new car and they do that sometimes'....
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,279
    "Oil and coolant required."
    Mines now at 4100 miles...
    NO oil useage - and staying clean (so good piston to bore fit).
    NO coolant loss - and staying clean (so good engine gasket sealing)
    Mine was carefully run-in and is now being properly (but safely) used - as in last Monday's 250-mile (ish) blast into and out of Wales...
    A GREAT motorcar... that is now being spoiled by incompetents...
    jerseypaul's Avatar
    May 2011
    242
    Hi all.
    I have to say the car has been faultless to date.
    Thanks for the replies / info on the coolant & oil.
    i will naturally be keeping a closer eye on them.
    At service time I will mention that they were low and needed topping up.
    Brakes - a slight squeak sometimes but not a "problem" amount of noise.
    A good hose down of the calipers during a clean every Sunday is usually enough.
    the amount of dust that comes off is surprising sometimes.
    The brakes are stunning by the way.
    Paul
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    Thanks for this info, will see how I get on Monday!
    geek's Avatar
    Dec 2012
    56
    5000 miles in and zero loss of oil.
    Loss of coolant from 500 to 2000 miles, system left pressurised over a weekend, no further loss since.
    1mm run out on both front disks recorded at 4700 miles, disks and pads replaced under warranty, second set bedded perfectly an feeling spot on (already squealing though)
    Engine is brutally strong so much so it ate a prop shaft last weekend; prop replaced, bearing on the new prop redesigned.
    Awesome car.
    Suzuka Grey RS3
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    Well mine has been in for the last two days with coolant loss. It was pressure tested last night and lost 1/2 bar overnight. They said this wasn't a major leak but that it was more than they would like so it stayed in for some endoscope treatment!
    May 2012
    11
    Hope they find out what the coolant issue is for you! Have they checked the brakes yet? Mine are squealing already again unsurprisingly...
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,538
    My coolant is low so will have to keep an eye on that and check the oil..
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    They told me they haven't bothered looking at the brakes as they know there will be a fix from Audi at the end of March, either a fix or an update anyway.
  28. #27
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    Quote Originally Posted by Rs3kel View Post
    Yeah keep an eye on it for sure, mine has only done 3500 miles and it is a couple of mm below the lowest minimum mark when cold.
  29. #28
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    Well mine is on the way back to me now. After pressure testing for a second night there were no losses whatsoever despite a 1/2 bar loss the first night. They have topped it up and it is to be monitored..
  30. #29
    27,028
    1/2 bar loss seems a fair bit of loss overnight tbh, mine lost this recently with a substantial rad corner leak, think they need to keep it & run it for a few days.
  31. #30
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    I thought it was quite high to be honest but they weren't worried by all accounts. Apparently they have equipment to simulate the running of the cooling system without the engine running (a bit like a heart bypass I guess lol). They think it was possibly an air lock but you never know when you are being bullsh*tt*d IMO.
  32. #31
    May 2012
    11
    Hmmm.. So Warrington Audi have now had two RS3's in within a week - Both with coolant loss and they can't find anything wrong with either of them.... So genuinely where is the coolant going then?
  33. #32
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    No idea lol, I have heard of others coolant issues disappearing after pressure testing so hopefully that will be the end of it! You can hope!
  34. #33
    27,028
    The tool is just a pressure tester, whereas just screws onto the coolant reservoir & they pump 1.5 bar of pressure into the coolant system which simulates & then that should be enough to find leaks, worrying if its air locks on new cars & by looks of it a few now.
    Sorry I should advise I dont run an RS3, but the same system is used to do the pressure test on the 8P's.
  35. #34
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,538
    Hi what coolant we on now for the rs3 ,g12,g12++ or g13 ....
  36. #35
    27,028
    G 013 is whats used now, superseded from G 012
    Kelza likes this.
  1. oil and coolant lines for gt28 71r
    By jonno123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2013, 14:02
  2. Audi B7 170TDI - juddering, drinking oil, drinking coolant and making odd noises.
    By eddscott in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th September 2012, 15:00
  3. Oil and Coolant caps
    By marknjayne in forum For Sale/Wanted - Audi Parts
    Last Post: 19th June 2012, 21:54
  4. BARGAIN Oil and Coolant Caps.
    By Reesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2012, 17:23
  5. Gaining interest for oil and coolant cap
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2012, 13:00
