Results 1 to 9 of 9
    JonnyG's Avatar
    Aug 2008
    Leeds
    218
    Creaking Rattly Drivers Door Window - anyone got a fix ?
    My drivers door window is used a fair bit every day (up / down / up for car park tickets) and has, after being fine for the first two weeks of ownership, now developed a creaking rattle sound (like it is moving about slightly and the seals creaking under the pressure). It is worse when crusing around at 30/40mph on poor surfaces when every flex of the chassis makes it creak / groan / rattle continously
    Has anyone else had this and found a cure ?
    Audi RS3 in Daytona Grey, 7sp S-Tronic, Sept 2012
    Sep 2012
    106
    Warranty is a marvellous thing
    CatnipRS3's Avatar
    Oct 2012
    In a Litter Tray Up North
    204
    Mine had this and Audi put some hi-performace silicon spray inside all the rubbers and sound has totaly gone...and yes sounded like glass was moving around.
    Going to Audi next week, will ask what exactly the product was called.
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Take a black crayon to the felt surfaces on the window/door frames. Worked for both my A3 and S3
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    CarrG's Avatar
    Nov 2008
    260
    Quote Originally Posted by Acheron View Post
    Mine did it badly when new inc door card.
    All inc glass was replaced by Bath Audi.
    Ibis RS3 - Buckets - Bose - Black Ed - Privacy - New Brakes
    VW California GP 180 DSG "Candy"
    JonnyG's Avatar
    Aug 2008
    Leeds
    218
    Quote Originally Posted by CatnipRS3 View Post
    Was it called Krytox ?
    DuPont Krytox lubricant – door seals, hinges, latches, squeaks and rattles | my-gti.com
    From what I've read it's the felt that needs to be kept moist, so the above or black crayon may help !
    Others reckon a bit of vaseline or tyre gel on the felt alone (not the rubber) will cure it. Will give it a try and report back
    Many advise against silicone sprays - short term fix but longer term the creaks come back with a vengeace
    JonnyG's Avatar
    Aug 2008
    Leeds
    218
    Well after some research using Google and a bit of trial and error I have found a fix
    1st Attempt : On lowering the window a few mm the creaking stopped completely, so I thought it was pretty clearly the window seals that were at fault and creaking. First attempt was to lubricate the felt seals with vaseline (supposed to be THE best cure from my first research - a lot of people said this worked). Well it did improve things slightly but the creaking was still there for me so I carried on researching.
    2nd Attempt The second attempt followed advice on a BMW forum This recommended cleaning and treating the whole of the upper door seal right at the top of the door and all the way down to the hinge area (and not the window glass seals). Then clean the inside of the door frame (along the whole length where the seal meets the paint). Well I thought I'd give this a go and gave it a good clean and wipe with Autoglym Rubber & Vinyl care. Result !! no more creaking at all.....the car is completely quiet again (well apart from the squeaky brakes occasionally )
    6th post down was the one that worked !
    Window Creak - BMW Forum - BimmerWerkz.com
    poli84's Avatar
    Nov 2010
    Melbourne. Australia
    430
    I get this in my 8P S3 also, common 8P problem.
    I treat all window/door felt and rubber with Einszett Gummi Pflege Stick every 2 or 3 months and it has removed the problem.
    The Audi dealers wouldn't even diagnose the problem.
    MY10 S3 Sportback - 6Sp Manual - Sprint Blue
    REVO Stage 2+ /
    Forge Twintake / 3" Miltek Hybrid DP/​ Autotech HPFP
    Bilstein PSS10
    / H&R 10/12mm Spacers / BFI Dog Bone /EBC Yellowstuff
    BUILD THREAD
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,294
    Quote Originally Posted by JonnyG View Post
    Anyone tried a hard-soap bar? I used to use the 'thin' remnants of a soap bar to 'wipe' the window seals of my 1971 Elan Sprint and it really did work, shut them up and lubricated the guides: I also use hard soap on the runners of my sliding double glazed doors at home, and that works too. Try it. If it doesn't work then that's one less thing to try.
  1. MY09 audi a3 3 door sline detachable towbar? Anyone got or seen one?
    By andi1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2012, 16:07
  2. Anyone got a part number for cabin filter door 2.0tdi
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2010, 20:15
  3. anyone got a spare lower door trim ??
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2010, 16:29
  4. Anyone got a spare window regualor clip?
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2009, 22:40
  5. anyone got a creaking from the glove box lid?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2005, 09:13
