Badger5Sky Insurance
    Aug 2006
    Hertfordshire
    69
    Grinding noise when cold
    When starting up with the engine cold, as soon as I select D I hear a grinding noise for a short time until the engine begins to idle at 950rpm (or wherever it normally idles). It becomes louder if you move off. Does anyone know if there's a common issue with the DSG box that may cause this behaviour?
    jerseypaul's Avatar
    May 2011
    Jersey - Channel Isles
    242
    Not grinding noise.
    I posted before what I thought was a rattling from the exhaust when cold, but I think this was the exhaust valve cycling, when you switch off with the sport button on.
    2012 RS3 Daytona grey - VW T5 Transporter 4motion 130 - VW UP!
    Aug 2006
    Hertfordshire
    69
    It's weird because if I wait a couple of mins and let the engine idle speed settle at 900rpm vs. where it sits when initially starting the car cold it doesn't make the noise. It's only there if I move off straight away and lasts a few seconds...
    Aug 2012
    I have noticed this as well but in mine I would nt really call it a grinding noise but its definatly a strange sound that disaperas like you mentioned - I pull off the drive in reverse rather than D and it happens for a few seconds. Think I wil have to mention it to the dealer, but I can see now they will say leave it with us so we can start it cold etc PITA unless it gets worse I dont think I am gonna worry about it.
  1. Replies: 10
    Last Post: 23rd March 2010, 15:20
  2. S4 front end noise when cold
    By andybnwc in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2009, 17:31
  3. Grinding noise when changing down gear
    By darkhawkuk in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2008, 21:12
  4. Grinding noise when the wheels start to spin?
    By JB_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2006, 23:08
  5. Grinding noise when cornering
    By vbking in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2006, 13:43
