Results 1 to 14 of 14
    jerseypaul's Avatar
    May 2011
    Jersey - Channel Isles
    242
    Does your exhaust rattle on cold start?
    Hi gang.
    When I start the car in the morning the exhaust or maybe the valve sounds a bit rattley to me.
    it quiets down after 20 - 30 seconds.
    thought it could be the valve "cycling" if switched off with the sport button down.
    let me know if you notice the same.
    cheers.
    2012 RS3 Daytona grey - VW T5 Transporter 4motion 130 - VW UP!
    babyboss's Avatar
    Sep 2012
    south africa
    23
    same here ..
    Aug 2006
    Hertfordshire
    69
    Same here... I thought it was something grinding at first but i'm pretty certain it's the exhaust rattling. Seems to get worse if I pull away immediately before the engine idles just below 1k rpm
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,089
    Mine doesn't, at all...
    Feb 2012
    240
    The software update available fixes alot of cold start issues Audi told me, so maybe worth while going into Audi with your cars
    Hope this helps
    Coming soon the new Audi RS3.... see it attached to your rear bumper on the Motorway no matter how fast you go!
    jerseypaul's Avatar
    May 2011
    242
    Quote Originally Posted by Sticks View Post
    Hope this helps
    Booked in friday
    will report back
    Got a VW Up! to try as a loaner. ( don't forget the !)
    jerseypaul's Avatar
    May 2011
    242
    Rs3 mod / recall pics
    Car was in today for the recall.Software upgrade to " various systems" as the paperwork described.The brake duct mod also carried out - see pics below.The VW Up loaner was pretty good too.Brake duct in wheel arch liner:Front grille mod - holes added
    jerseypaul's Avatar
    May 2011
    242
    Forgot to add, the exhaust seemed quieter but will need to check from a proper cold start.I can start the car without the break pedal also.
    babyboss's Avatar
    Sep 2012
    south africa
    23
    brake duct mod ?
    what was the problem there ?
    pls explain top & bottom pics >> thx
    jerseypaul's Avatar
    May 2011
    242
    Quote Originally Posted by babyboss View Post
    brake duct mod ?what was the problem there ?pls explain top & bottom pics >> thx
    Hi mate. UK spec RS3 have had a recall notice.A temp differential was found between the front brakes in certain situations.Also reports of noisy exhausts has resulted in a software mod to adjust settings in some way.The UK offside front grille ( left as you look ate the front ) had some extra holes created - bottom pic.The top picture shows some new ducts/louvres that we're placed to the wheel arch liner.Not sure if all variants/manufacture dates of RS3's have the same mods.A few on here have.
    Sep 2011
    80
    Just rang my local audi service centre.
    Booked my car in for a check-up and update on those issues...
    JonnyG's Avatar
    Aug 2008
    Leeds
    204
    I've just picked up a brand new RS3 ... my dealer had done all software updates / recalls ..
    My engine revs quite high for 30 seconds but no exhaust rattle ... maybe the idle speed is the software fix ?
    jerseypaul's Avatar
    May 2011
    242
    Quote Originally Posted by JonnyG View Post
    Yes mine has always had the slightly higher rpm for 30 secs during LCD start, even before recall mod.
    I think they may have parked the exhaust flap for the mod maybe.
    It seems to have a different noise although I wouldn't describe it as quieter.
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,089
    My car is at Stafford Audi today or it's first service; oil and filter change. The only mod being undertaken is the brake ducting, nothing else, and I've had Stafford Audi check again today to make sure my car is not listed for any of the other changes some of you guys have listed: time will tell, of course.
    PS: got a NEW S5 as a loan car: 2-litre petrol with manual 6-speed box - you don't want to know… I'll have the RS3 back tonight, YES!
  1. S-tronic clunky sound when cold? Does your do the same?
    By RedDejavu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th February 2012, 12:57
  2. Rear exhaust box rattles when cold
    By Perplexer in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2009, 21:52
  3. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
  4. What colour does your 2.8 Exhaust Burn?
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd August 2004, 09:45
  5. Who's had the wet exhaust rattle modification?
    By JaGermanCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2003, 10:23
