Volks AutosEM Tuning
Results 1 to 10 of 10
    jerseypaul's Avatar
    May 2011
    Jersey - Channel Isles
    242
    Definite less under steer than S3
    Hi guys.
    we had a really wet weekend over in jersey but got out in the car through some twisty stuff to give it some stick.
    really noticed how much more planted it is been with ESP in sport mode and S button on.
    The wet weather meant I could get to the limit of the tyres and it is a lot less understeery than the S3.
    wider track, better tuned suspension and chassis I guess.
    There's not a lot else out there with this combination of performance, practicality and understated looks.
    Throw in some wet weather and you can smoke most things out there.
    I know Scoobies and Evos have similar hp and drivetrain but they look like they've crashed into Halfords and dont hang onto their value.
    loving this car.
    2012 RS3 Daytona grey - VW T5 Transporter 4motion 130 - VW UP!
    quattro81's Avatar
    All the gear.. No idea
    Feb 2011
    Kent
    982
    Did you go for the 255 front option, Paul?
    Red is the colour..
    jerseypaul's Avatar
    May 2011
    242
    Quote Originally Posted by quattro81 View Post
    It was a cancelled order so no chance to change spec.
    standard front wheel tyre combo.
    loads of grip though.
    youd have to be doing something extreme to run out of grip.
    quattro81's Avatar
    Feb 2011
    Kent
    982
    cheers mate interesting to have the comparison vs the s3.. I wonder how much difference the extra wide fronts will make? sounds like its a pretty well sorted combo of all factors for the road already...?
    Red is the colour..
    CarrG's Avatar
    Nov 2008
    260
    Is so true. After a week in a courtesy S3 the RS feels very planted.
    Ibis RS3 - Buckets - Bose - Black Ed - Privacy - New Brakes
    VW California GP 180 DSG "Candy"
    Dave Hedgehog's Avatar
    Apr 2012
    274
    Quote Originally Posted by CarrG View Post
    There light years apart, the S3 i have at the moment is very like my R32, very chuck able and easy to get the rear out Not enjoying the hug flat spot / lag the S3 has at low revs, very irksome at lights etc. I prefer the R Golf which does not seem to suffer from this. The RS3 just feels like a completely new car.
    Apr 2012
    274
    I will let you know in a month if they make much difference, I hope its more than just a RIM change and theres some physical change to the car, because £1500 for half inch rim increase is .....
    jerseypaul's Avatar
    May 2011
    242
    Quote Originally Posted by Dave Hedgehog View Post
    What else can it be if you order extra wide tyres?
    Are there othe associated changes?
    seems a bit steep.
    quattro81's Avatar
    Feb 2011
    Kent
    982
    AFAIK it's just the rim size change? I was just in the box ticking mood myself that day... you can't swap any of the wheels around anyway so it's gonna be an expensive ride as far as tyres go I reckon, with or without the 255, the fronts and rears are still different sizes, so every time you wear a front, a new one must go on!.. Four wheel drive the haldex way, they are all gonna wear the fronts quicker than the rears?
    Red is the colour..
    jerseypaul's Avatar
    May 2011
    242
    Yes, fronts will wear quicker.
    pall part and parcel of ownership these days.
    Jeremy Clarkson does a great write up on tyres on the Top Gear website.
    the RS2 used to eat tyres with the Torsen diff.
    manouvering at low speed you could hear and feel the tyres scrubbing as the diff tightened.
    New set every 9000 miles !
  1. steer wheel removal
    By stoop44rio in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th January 2011, 14:18
  2. torque steer
    By mad max in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2009, 11:21
  3. A great find A definite sticky
    By macattax in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd February 2007, 10:32
  4. CAMBER STEER
    By brianalexander1 in forum Handling
    Last Post: 31st May 2006, 23:15
  5. Torque Steer
    By nigeltee in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2005, 23:49
