Chris NottSky Insurance
Results 1 to 19 of 19
Thread: Squeeky Brakes
    Apr 2009
    Aberdeen
    65
    Squeeky Brakes
    Any one else experienced squeeky brakes with the RS3? Only does it at low speeds (in traffic etc). Its really loud and quite a low pitch.
    Never had a car with drilled discs - is it something that often happens with those?
    Cars done less the 1000 miles - could that be a contributing factor?
    Trying to make time to see the dealer about it and to sort a couple of niggling rattles. Just wondered if anyone on here had experienced this.
    Aug 2006
    Hertfordshire
    69
    Same issue here with the sqeeking brakes. I only have 350 miles on the clock so far so not sure if goes away in time.
    jerseypaul's Avatar
    May 2011
    Jersey - Channel Isles
    242
    Quote Originally Posted by g5und View Post
    I have this too.
    usually associated with performance brake pads.
    do a couple of high speed brake tests.
    power wash the brakes lightly.
    2012 RS3 Daytona grey - VW T5 Transporter 4motion 130 - VW UP!
    Scotland
    154
    I must be the odd one out this time, no problems with noise from the brakes at any speed
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,156
    Yes, infrequently I'm glad to say. Again at low speed only and I think the pattern is when the brake discs have been wet and dried a little 'rusty' if that makes sense. Once warm after 1-2 applications no more squealing.
    An Evo 360 I owned, fitted with Performance Friction floating rotor discs and track biased pads, screeched pretty much all the time at low speeds so I agree with the performance pads theory. The Evo did stop very well though so there are upsides!
    Sep 2009
    Glasgow
    292
    Yes got exactly this issue as described and was planning to take a wander past Stealers when I'm next passing. Car done 850 and only at very low speeds. Understanding the performance pads comment but surely a car or £44k should sound like this?
    If anyone gets any deer fix, please share.
    NOW...another similar RS3?!? ...Phantom Black RS3 with Buckets, folding auto dim mirrors, privacy glass, Bose, Alu inlays, light & rain sensor pack, black exhaust tips and now Scorpion decat pipes and MPSS rubber!
    REFUNDED - Phantom Black RS3 with Buckets, folding auto dim mirrors, privacy glass, Bose, Alu inlays, light and rain sensor pack.
    GONE - S3 SB BE - '10 plate in Ibis with Buckets; RNS-E; tech & comfort pack; Revo stage 1; Milltek TBE; BBS CK 19's in Anthracite on Asseymetric rubber!
    May 2012
    13
    Same issue - was squealing at low speeds. Took it back to the dealer and they applied different grease behind the pads and polished the disc I believe. From what I understand it is due to the brakes not being bedded in properly leaving an uneven spread of pad material across the disc...
    jerseypaul's Avatar
    May 2011
    242
    Yes.
    should be ok when bedded in.
    a small price to pay for stunning brakes.
    Dave Hedgehog's Avatar
    Apr 2012
    274
    Mine squeaked like crazy in traffic ...
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,308
    I did have some horrendous front brake squeal between 750 and 1000-miles but that's now resolved; I removed the pads (all four pads were very tight in the calipers) and refitted them with a generous smear of Copperslip. Problem solved.
    Mar 2012
    Planet Claire
    258
    I noticed mine have started to sqeal...bugger. 45bvtc..I may have to pop over, I only live in Telford...
    Feb 2012
    246
    i notice i only get it when i leave the car sitting for a few days etc and the rust builds up on the discs
    annoying tho !!!!!!!!!
    Coming soon the new Audi RS3.... see it attached to your rear bumper on the Motorway no matter how fast you go!
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,308
    Not a problem Moschops, I'm in Hednesford, contact me direct...
    Mar 2012
    Planet Claire
    258
    Quote Originally Posted by 45bvtc View Post
    Will do, many thanks....Regards
    Wayne
    slade777's Avatar
    Sep 2010
    763
    An S3 we have had since new (now 40,000 miles) has had squeeky brakes since new. Never had an issue when braking hard though very good. Only happens at about 10mph and lower. Have been checked by Audi and both discs and pads are fine loads of wear left in them.
    Current:
    A3 Black Edition 2.0 TDI 140
    Sep 2009
    Glasgow
    292
    Quote Originally Posted by slade777 View Post
    Hear what you are saying mate but I'm giving her another 400 miles to take her to 1.5k on the clock, let alone 40k, and then she's back to stealers......makes the car sound as if something is wrong and draws the wrong attention in heavy traffic.....no matter how good the brakes are this is not good.
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,308
    In my car the pads were way too tight in the calipers; I had to carefully drive out each pad, however, once coated with Copperslip I was able to easily re-fit the pads. I believe (I'm a retired automotive engineer) the calipers and pads have been assembled dry and stored before assembly to the car.
    My car has now done 2200 miles and the issue has not returned.
    To conclude: it's not a brake disc issue, and it's not a brake pad issue, but the 'dry' assembly of the two.
    Oh, and the low speed brake squeal on my car, at low speeds, became the loudest I've ever heard on any car, ever!
    CarrG's Avatar
    Nov 2008
    260
    Good info there thks.
    On the topic of brakes the holes in my discs are filling up fast on 2000 miles!
    I read people drill (4mm) them out!
    Ibis RS3 - Buckets - Bose - Black Ed - Privacy - New Brakes
    VW California GP 180 DSG "Candy"
    slade777's Avatar
    Sep 2010
    763
    Quote Originally Posted by elton121272 View Post
    I totally agree. Personally I would have them straight back to have them checked. Just saying we did have them checked countless time and they are fine even with the squeek.
    Better be safe than sorry at the end of the day!! No one wants failing brakes on a performance car like the RS3!!!
    Current:
  1. Squeeky brakes
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2012, 12:26
  2. Squeeky brakes!
    By paulious in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2012, 20:38
  3. Squeeky Door
    By TripleD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2009, 18:10
  4. Squeeky Pulley
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2007, 19:06
  5. A squeeky start.....
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2003, 23:34
