Monster MotorsportChris Nott
    Nagasaki's Avatar
    Aug 2012
    Henley on Thames
    24
    Map for GTRS Eliminator on B7 1.8t Cab
    Hi, we have the above Cabriolet with Milltek Hi Flow Cat and System, green filter, dump valve and your stage 2 re-map. However it is running on the original SMIC and therefore has not apparently been wound up to full boost.
    I have just bought a replacement upgraded SMIC from Turbo Revs which I intend to have my local chap fit but am also considering replacing the turbo with the ATP Eliminator from the states.
    Do you have a specific map for this add on? The car is not driven hard (as is a CVT) is very well looked after but just fancy tweaking a bit more. Seems to run out of breath above 4,500 or so.
    Also would I have to plumb in a second SMIC?
    All advice much appreciated.
    A4 1.8t B7 Cabriolet - Revo stage 2 map - Milltek Hi. Flow cat and system - Water Methanol injection - Forge valve - Brembo brakes with braided lines - Bilstein B12 Pro suspension kit - Air freshener
    in the fast lane
    Aug 2005
    Warwick
    150
    If you want to run an ATP Eliminator then yes we cater for the 28rs, you would need to run 550cc injectors as well and if you want to make the most of it you'd need a decent FMIC. This would be our Stage3 setup and it's adjustable so could be setup in a lower than 'full-on' mode if you wanted. The side mounts are okay, but thats about it even the uprated ones aren't as efficient as a nice front mount.
    Kev
    Revo Technik
    www.revotechnik.com
  1. A REVO re map for the 3.2 :) mmmm
    By imported_S_Line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2008, 11:15
  2. gtrs eliminator intake help????
    By 20vtdaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2007, 21:10
  3. Superchips Bluefin extra power map for my 2.0 TDI
    By mjepson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th September 2007, 15:04
  4. GTRS Eliminator Finally Fitted
    By ChriS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2006, 17:41
  5. Re-Map for 2.0TDI
    By imported_Pimpster in forum Tuning
    Last Post: 16th March 2005, 12:09
Tags for this Thread
