Results 1 to 23 of 23
    TimJK's Avatar
    May 2011
    Norwich, Norfolk, United Kingdom
    400
    Stage 1 S3 map, fluttering from 3500-4000rpm
    Hello, Had a stage 1 map put on the car this morning.
    I have a forge recirc valve (Changed to yellow spring), ITG intake.
    Since map I now have a flutter in power when under hard acceleration between 3,500-4,000rpm. It is fine before, and afterwards throughout the rev range.
    Its running currently on tesco 99.
    I have removed the forge recirc valve thinking its dumping too early but its not cured it...
    anybody else come across this problem before?
    Tim
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Check my earlier thread
    Silky explained it fully so all is well
    TimJK's Avatar
    May 2011
    400
    I may be blind but cannot find your thread?
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Just click on my profile and then started threads
    TimJK's Avatar
    May 2011
    400
    Yep I must be blind then, Cannot find a thread you've started with the same issue.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,087
    Hey Tim, all it is is the diverter valve modulating the boost, it's perfectly normal. Nothing at all to worry about. I have the Forge DV and yellow spring fitted also. For me it just became more noticeable after I had my Forge TwinTake fitted. Have a read of Silky's original thread (couldn't find Blackie's one from the other day when having a quick search either, ..I should have gone to Specsavers, I guess lol) xx
    S3 Boost Modulation/Flutter
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    TimJK's Avatar
    May 2011
    400
    But it's funny how the original valve and the forge valve both do this? It doesn't seem right that it should do it... I'm going to ring up the place that mapped it when they are open again just to check its definitely ok.
    TimJK's Avatar
    May 2011
    400
    I fitted a milltek turbo back exhaust and it stopped the fluttering..... Until I had a play with an sps it came back. But reverted to settings I first had on and still there. Fail!
    Also fitted a hpfp so going to go back for a stage 2 or 2+ map soon and ask about it.
    TimJK's Avatar
    May 2011
    400
    Flutter still present and its now been stage 2+ map, on studying the RR graph I've noticed it doesn't have as greater climb in the power curve between where the fluttering starts and stops. may need to return to mapper?
    in the fast lane
    Aug 2005
    Warwick
    150
    As above the fluttering sound is boost modulation as Paullie explained above!
    Kev
    Revo Technik
    www.revotechnik.com
    TimJK's Avatar
    May 2011
    400
    Quote Originally Posted by RevoKev View Post
    Strange how as it happens though there is a dip in the power curve, Any way to get around it happening?
    in the fast lane
    Aug 2005
    Warwick
    150
    There shouldn't be an actual did in the power curve, but it is doing that to modulate boost. Sounds to me like you'd benefit from our update and getting the car setup again, either ourselves or dealer would then be able to explain what the car should/shouldn't be doing!
    2.0L TFSI K04 Revo Stage 1, 2, 2+ FOC Software Update
    Kev
    Revo Technik
    www.revotechnik.com
    TimJK's Avatar
    May 2011
    400
    I will scan in and message you the graph if you like. It is the latest software version as you may recall being contacted by a dealer about problems flashing my car and had to return the next week once the new software was released.
    in the fast lane
    Aug 2005
    Warwick
    150
    Yes please!
    Kev
    Revo Technik
    www.revotechnik.com
    TimJK's Avatar
    May 2011
    400
    Yes please!
    I have sent it to you now
    TimJK's Avatar
    May 2011
    400
    Have you checked your messages yet?
    in the fast lane
    Aug 2005
    Warwick
    150
    Yes and I spoke to Dan over at Clive Atthowe's as well, there's no real dip in the power curve but you can see a dip in the torque curve which is accentuated on the graph due to the scaling. That car's seeing some very healthy figures for stage1!
    To make sure it's all okay I'd get it logged on the road, you'd be able to see boost dipping if it's massively pulling load out for some reason.
    Kev
    Revo Technik
    www.revotechnik.com
    TimJK's Avatar
    May 2011
    400
    Ok I will log again on the road, this isn't stage 1 this is stage 2+ mapped
    in the fast lane
    Aug 2005
    Warwick
    150
    That makes more sense although the thread title is confusing!
    Kev
    Revo Technik
    www.revotechnik.com
    Audi Dynamik's Avatar
    Sep 2011
    2,115
    I used to Run my Car on Tesco 99 and i started having the Hesitation problems,
    I have recently been on Holiday with a Tank full of V Power been down South to the Isle of Wight for a week and then to Devon for a week clocked up 960 Mile in 2 week with using nothing but Shell V Power and the hesitation has vanished !!
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    TimJK's Avatar
    May 2011
    400
    Sorry yeah i thought maybe it's something that was only going to happen stage 1 but then it remained when I went to stage 2+ but added it to this thread.
    TimJK's Avatar
    May 2011
    400
    Quote Originally Posted by Audi Dynamik View Post
    Mine has always been on vpower so hesitation is with that.
    in the fast lane
    Aug 2005
    Warwick
    150
    Tim, as I said I spoke to Dan over at Clive Atthowe's, there's no real dip in the power curve but you can see a dip in the torque curve which is accentuated on the graph due to the scaling. To make sure it's all okay I'd get it logged on the road, you'd be able to see boost dipping if it's massively pulling load out for some reason. The guys at Clive Atthowes would be able to do this!
    Kev
    Revo Technik
    www.revotechnik.com
  1. A3 1.8 t stage 1 map and benefits
    By atr1g1978 in forum Custom-Code UK
    Last Post: 15th March 2012, 16:11
  2. Will A Stage 1 Map......
    By A3 T in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2011, 23:32
  3. Stage 2 map
    By gez in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2010, 23:16
  4. REVO stage 2 map for S3?
    By Rabbit222 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2008, 13:14
