Chris NottSky Insurance
    Nov 2005
    UK
    586
    Dealer re-flash of ECU
    Hi,
    If I have a stage 1 tune on my 2012 Audi S3 and the Audi dealers then have a manufacturers re-flash of the ecu (as I have had happen before ), what is the procedure for returning the engine to stage 1 again ?
    If I have the SPS, do i download the new Audi map and send it off to you for a further/new upgrade ( and if so is it free of charge ), or wouldi have to effetively start again and be charged for a second re-map, or would the original map still work ok and would simply need to be uploaded again ?
    Many thanks
    in the fast lane
    Aug 2005
    Warwick
    150
    Hi there, you can go back to your Revo dealer and have the new Revo version of software loaded onto your ECU. Factory updates are FOC from Revo however dealers do reserve the right to charge for their time. The first thing they would do is check the ECU ID and software version to make sure it has actually been updated.
    Just so you're aware the SPS is a Serial Port Switch, it's not a flashing device so cannot be used to update files in your ECU.
    Kev
    Revo Technik
    www.revotechnik.com
    Nov 2005
    UK
    586
    Many thank Kev.
  1. Audi ECU Software Update - Main Dealer Price?
    By Wabby in forum General Automotive Chat
    Last Post: 20th October 2011, 23:17
  2. ECU Flash count
    By KRL in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th November 2007, 15:43
  3. MTM - Flash or ECU Swap?
    By mjair in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2007, 19:06
  4. MTM - Flash or ECU Swap?
    By mjair in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2007, 14:28
  5. ecu flash
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th April 2007, 15:29
