AMD TechnikKowalski
Results 1 to 15 of 15
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,468
    Post Thanks / Like
    Grrr - wallpaper border adhesive...
    Previous owners of my house decided to put a border up in the hall/stairs/landing. When I moved in I redecorated in a similar colour so just left the border in place & painted up to it.
    Now 12.5 years later I'm redecorating completely and have removed the border but it's left a film of rubbery adhesive (not normal wallpaper paste) stuck to the wall that will not easily shift. I need to get this off so I can just paint the wall.
    Had a look on the net and have tried the following 'solvents' I had already in the house:
    White spirit
    Metholated spirits
    Cellulose thinners
    Acetone
    Hammerite thinners
    GT85 oil
    Degreaser
    Fabric softener
    Windowlene
    Sugar soap
    Wallpaper remover
    None of these seem to be doing anything great. The only one that works slightly is the fabric softener which does seem to loosen up the glue a bit, but I still have to scrape it off with a scraper (and in the process I'm catching the paint behind making a mess of the wall). It's taken me about half an hour of scraping and rubbing to do about half a metre - and I must have 20m more to do :-(
    Anyone got any bright ideas, or am going to be spending hours trying to get this bl**dy stuff off.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    quattrojames's Avatar
    Mar 2008
    Dorset
    11,001
    Post Thanks / Like
    The latter I think
    Good luck!
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Sep 2009
    92
    Post Thanks / Like
    IPA which you can get from home base I think, or if you can find it, T74 or CN20. Nothing will resist the latter 2!
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,468
    Post Thanks / Like
    IIRC IPA is a close relative to Acetone? Will it's performance be markedly different?
    Jason
    Sep 2009
    92
    Post Thanks / Like
    Errrm, pass... I don't know how there properties differ as Acentone is oxidised IPA.... But I've always found IPA better at removing gunky stuff. Maybe I just scrub harder with the IPA though haha.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,273
    Post Thanks / Like
    cant you steam that stuff off with a wall paper stripper?
    Do you want £5k a month, every month, for working 3 hours a week part time ? I'm serious, open the link!
    http://www.makeandsavecash.com
    Turkster's Avatar
    Dec 2007
    2,273
    Post Thanks / Like
    also try de-icer , yer the spray one in a can that you use on your windscreen........
  9. Thanks jcs356 thanked for this post
  10. #8
    sportstractor's Avatar
    Gangsta
    North Devon
    2,405
    Post Thanks / Like
    It sounds like they have stuck it on with silicon... You can get silicon remover, but removing cured silicon is an absolute *******
    S3 - Minger AMK - Stage 2 Custom 'R-Tech Powar' Remap - Badger 5 Tip - Welly Cooler - 25mm eibach springs - S4 reps
    "Remember one thing, No matter how pretty she is, Someone, Somewhere is sick of HER SH*T!"
  11. #9
    Mar 2008
    Dorset
    11,001
    Post Thanks / Like
  12. #10
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,468
    Post Thanks / Like
    Quote Originally Posted by sportstractor View Post
    Nah, it's not silicon, it's a rubber based glue of some description that's still tacky. If you rub it with your finger end, it will eventually rub up into little balls on the paint surface. Problem is that's a lot of rubbing. Makes me think of something like Copydex (if you can still get that???)
    Will try the de-icer as I have some, and also some silicone dissolver as I have some of that as well. Looking at all the various solvents/cleaning agents I have makes me look like I'm a glue sniffer.
    I've also remembered there is a specialist decorators shop in Alder****e that I'll go and see tomorrow to see if they have any advice. Will take a sample of the glue.
    Oh, and I like the flamethrower idea - I also need to do the gloss as well. Two birds with one flamethrower
    Jason
  13. #11
    Turkster's Avatar
    Dec 2007
    2,273
    Post Thanks / Like
    if all fails, hammer and chisel !
  14. #12
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,468
    Post Thanks / Like
    Right I've got some DIF by Zinsser (US) from the local decorators place - will give it a try and report back.
    Jason
  15. #13
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,468
    Post Thanks / Like
    Well that didn't bl**dy work either! Neither did a hot air gun or a sander.
    Right, resigned myself to the fact that this isn't coming off the wall so going to get the worse of it off just by scraping and then paint over the remainder.
    Jason
  16. #14
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,468
    Post Thanks / Like
    Right, had another flash of inspiration and it has worked - metal pan scourer soaked in white spirit. The spirit frees up the glue a bit and the pan scourer is abrasive enough to remove the residual glue but not go through the paint. Cleared about 3m worth in about 15mins.
    Only downside is the house stinks!
    Jason
  17. #15
    Turkster's Avatar
    Dec 2007
    2,273
    Post Thanks / Like
    open the windows and put the heating on! If your hard up then have a look at this, (cough) ...::: Paul Donneky Authorised Distributor for Utility Warehouse :::...
  1. Anyone with Vagcom near Notts/Derbyshire border
    By FUNKYCLIFF in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th May 2011, 06:53
  2. Best Adhesive for Glass Wiper Blank?
    By bhavin1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2010, 23:40
  3. Irish Border
    By lil_coz in forum Jokes, Games & Humour
    Last Post: 25th March 2008, 18:26
  4. Trim adhesive
    By Stringster in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2007, 01:20
  5. What to use to remove spray adhesive glue?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2004, 14:03
