Badger5Volks Autos
Like Tree1Likes
  • 1 Post By NHN
Thread: R8 Climate control
    Aug 2013
    Surrey
    135
    R8 Climate control
    Hi all in the R8 section, has anyone had any problems with the climate control in their R8??
    Many Thanks
    27,099
    I think it would help yourself if you actually told us of the issues your facing, so advice can be given as tbh fella, R8 tech is based heavily on the 8P/TT, albeit not engine lol, so we can see what we can do & not allot of us can afford R8.
    Andy Crooks likes this.
    Aug 2013
    Surrey
    135
    problem im getting is that there is no power going to the blower motor, as well as the aircon light coming on when the button is pressed and going out again quickly, there is power to the CCM and seems to be working, you can hear all the flaps moving as requested. Reading the codes there is a fault relating to the CAN BUS system of the CCM, looking to be a blown/ faulty CCM, just seeing if anyone has experienced this too?
    27,099
    Its unusual for the ccm or climate to go faulty, assuming you've tried an alternative fan, as econ button will stay lit when that fan goes & these do go faulty as experienced it myself for clients.
    Post up the log of the R8 so can see what's showing.
    Aug 2013
    Surrey
    135
    Have heard of the fans going faulty, although no voltage going into the blower motor. The unit is off for testing at the moment.
    Nov 2011
    33
    I've had problems with mine. On a really hot day, the blower won't blow very much in Auto mode. I have to use manual till it all cools down. Had it in at dealer, and they did replace parts. It's working better, but nothing like it should. I don't use the car all that much anyway, so not really that much of an issue. Still annoying though.
  1. Climate Control Problem
    By adjturbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th December 2003, 21:38
  2. What's up with Audi climate control?
    By redaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th December 2003, 14:43
  3. Audi A3 Climate Control
    By ramstein666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 20:18
  4. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
  5. Retrofit LCD climate control
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 11:42
