Sky InsuranceChris Nott
    Oct 2013
    Bristol, UK
    Q7 rattling noise when opening the boot
    Hi, my first post here.
    I have had my 56-reg Q7 for more than a year and I'm quite happy with it. A few weeks ago the boot lock started to rattle before the door opens. I press the button to open the boot, it makes a ra-ta-ta-ta noise and then opens fine. It closes fine. This happens only 3 times out of 4 boot openings.
    I cleaned and greased the bottom part of the locking mechanism but it didn't help.
    Audi dealer recommends changing the locking mechanism and the motor but I suspect there must be a cheaper option. The mechanism seems fine, I don't think it needs changing and it is possible the motor is fine as well.
    Any advice? Thanks.
    27,099
    Welcome to the site.
    Are you opening via the remote, boot microswitch, does it have auto boot opening, all relevant, but sounds like the lock is trying to disengage, but takes multiple attempts, maybe adjust the lock/striker plate, I dont know the Q7 very well tbh, but most work on the same basic design.
  1. Rattle noise when accelerating on motorway
    By Mikemc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th April 2013, 16:52
  2. How to open the boot with out the key fob?
    By A3matt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th April 2010, 19:15
  3. Noise When Opening Door
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2007, 12:49
  4. strange noise when you open the drivers side door
    By MateloT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2004, 13:30
  5. Anyone else get a river when they open the boot??
    By Irish in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2004, 11:43
