Badger5Sky Insurance
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,968
    suspension + other fault codes Q7
    DID A FULL SCAN....CLEARED ALL FAULT CODES DROVE ROUND THE BLOCK AND THE FAULTS BELOW CAME UP,MY WORRY ONE IS SUSPENSION ONE.......IT SITS LEVEL ALL ROUND,AND IVE DONE SOME OUTPUT TESTS VIA VAG,ALSO IT RAISES ALL ROUND AND LOWERS ALL ROUND OK,BUT STILL GET THE FAULT...........ANY IDEAS ?
    Wednesday,29,May,2013,13:51:04:07342
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 4L0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
    55 56 61 62 67 6D 6F 72 76 77
    VIN: WAUZZZ4L07D034266 Mileage: 140380km/87228miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 0010
    67-Voice Control -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    6F-Centr. Conv. II -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4L0 910 401 M HW: 4L0 907 401
    Component: 3.0L V6TDI G000AG 0030
    Revision: --H05--- Serial number:
    Coding: 0011775
    Shop #: WSC 06144 000 1048576
    VCID: 2C5C11CB8F179978AD4
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09D-927-750.lbl
    Part No SW: 09D 927 750 FK HW: 09D 927 750 FK
    Component: AL 750 6A 0940
    Revision: 00H52000 Serial number:
    Coding: 0000504
    Shop #: WSC 31414 790 00001
    VCID: 7CFCE18B3FF7C9F87D4
    Address 03: ABS Brakes Labels: 4L0-910-517.clb
    Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
    Component: ESP ALLRAD MK25E1 0130
    Revision: 00H21001
    Coding: 0038033
    VCID: 2854EDDB9BEFB55849C
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000493662
    Coding: 0000147
    Shop #: WSC 00202 210 80978
    VCID: E3CE3AF722499600DCE
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
    Part No SW: 4L1 910 732 G HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 386GZ067515771
    Coding: 0002002
    VCID: 2E581BC3B90BEB68830
    Part No: 4L0 910 609
    Component: E0380 BedienteilH01 0060
    Address 08: Auto HVAC Labels: None
    Part No SW: 4L0 910 043 HW: 4L0 820 043 F
    Component: KLIMABETAETIGUNGH05 0060
    Revision: 00---012 Serial number: 00000000153176
    Coding: 0298006
    Shop #: WSC 00202 210 50776
    VCID: E1C230FF38558410CE2
    1 Fault Found:
    00565 - Rear A/C Control Head (Climatronic) (E265)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 50
    Mileage: 140381 km
    Time Indication: 0
    Date: 2013.05.29
    Time: 13:10:15
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    VCID: 316200BFA835F4909E2
    Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AU716 H12 0100
    Coding: 00022806
    Shop #: WSC 31414
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150059
    Shop #: WSC 31414
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4L0 910 111 A HW: 4L0 035 111
    Component: CD-Changer H41 0100
    Revision: 00000000 Serial number: AUZ5ZBF3031364
    Shop #: WSC 00000 000 00000
    VCID: 1E38CB03C9AB7BE8330
    Address 15: Airbags Labels: 4L0-910-655.lbl
    Part No SW: 4L0 910 655 B HW: 4L0 959 655
    Component: 31 AIRBAG AUDI8RH38 0120
    Revision: 05H38000 Serial number: 0037GD06EATC
    Coding: 0013105
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H08 0230
    Revision: 00H08000 Serial number: 90054061900297
    Coding: 0102142
    VCID: E6C823E3D17BE3283B0
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4L0 920 980 G
    Component: KOMBIINSTR. M73 H17 0110
    Revision: 00300000 Serial number: 5HJ38KC76
    Coding: 2657443
    VCID: 234EFAF7E2C956001CE
    Address 18: Aux. Heat Labels: None
    Part No SW: 4L0 910 105 HW: 4L0 815 071 C
    Component: Heizgeraet H07 0060
    Revision: 0000000E Serial number: 00000009011043
    Coding: 0000002
    VCID: E0C435FB335F8D18C1C
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 HW: 4L0 907 468
    Component: J533__Gateway H06 0040
    Revision: 00H06000 Serial number: 0900B067198014
    Coding: F55BBE7F307202
    VCID: ECDC51CBCF97D9786D4
    Address 34: Level Control Labels: None
    Part No SW: 4L0 910 553 B HW: 4L0 907 553
    Component: LUFTFDR.-CDC H03 7550
    Revision: --H03001 Serial number: 15.1528-0095.2
    Coding: 0015510
    VCID: 2952E8DF80E58C50562
    1 Fault Found:
    01577 - Turn-Off due to Over-Temp
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 140382 km
    Time Indication: 0
    Date: 2013.05.29
    Time: 13:42:12
    Freeze Frame:
    Error Code: 68
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H48 1060
    Revision: 00000000 Serial number: 399GY067530247
    VCID: 3B7E22977A790EC034E
    Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
    Component: TSG FA H12 0130
    Revision: 00000000 Serial number: gh‚
    Coding: 0002651
    VCID: 2F6606C7BE01E260886
    Address 46: Central Conv. Labels: 4L0-910-289.lbl
    Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
    Component: Komfortgeraet H05 0020
    Revision: 0020 --- Serial number: 01016072060000
    Coding: 7348475
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 134
    Reset counter: 49
    Mileage: 139057 km
    Time Indication: 0
    Date: 2013.03.26
    Time: 11:22:20
    Address 47: Sound System Labels: Redir Fail!
    Part No SW: 4L0 910 223 B HW: 4L0 035 223
    Component: DSP-AU716 H20 0100
    Revision: 11S00001 Serial number: 01307060320074
    Coding: 0000013
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 E
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000004784
    Coding: 0011101
    VCID: DEB80B03092BBBE8F30
    Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
    Component: TSG BF H12 0130
    Revision: 00000000 Serial number: uƒ
    Coding: 0002651
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000022
    Part No: 7L6 941 329 A
    Component: AFS-Modul links H06 0002
    Component: AFS-Modul rechtsH06 0002
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 388GW067540507
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4L0 910 181 HW: 4L0 915 181
    Component: J0644 BEM H12 0530
    Revision: -------- Serial number: 00000000029522
    Shop #: WSC 00551 210 86264
    VCID: E4CC39EB27479138254
    Subsystem 1 - Part No: 009 2S5 013 0
    Component: von VA0 536079390A
    Coding: 303039325335303133302056413035333630373933393041
    Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
    Component: TSG HL H21 0050
    Coding: 0002058
    1 Fault Found:
    02110 - Window Regulator Switch
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 48
    Mileage: 140187 km
    Time Indication: 0
    Date: 2013.05.19
    Time: 14:04:50
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
    Component: SDS 3502 UK H45 0630
    Revision: 00000000 Serial number: 00000607050343
    Shop #: WSC 12336 024 394758
    VCID: 366833A3415BD3A8CB0
    Address 6D: Trunk Elect. Labels: None
    Part No SW: 4L0 910 945 HW: 4L0 827 851 A
    Component: ValeoHeckdeckel H20 0280
    Revision: --H20001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    Part No: 4L0 910 946
    Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
    Part No SW: 4L0 910 290 HW: 4L0 907 290
    Component: ILM HINTEN 2 H05 0060
    Revision: AAH05061 Serial number: 001845617-----
    Coding: 0000001
    VCID: E5CA24EF2C7DE83032A
    2 Faults Found:
    02914 - Sensor 1 for Trunk/Hatch Closed (G525)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 89
    Mileage: 140372 km
    Time Indication: 0
    Date: 2013.05.27
    Time: 12:14:24
    02915 - Sensor 2 for Trunk/Hatch Closed (G526)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 89
    Mileage: 140372 km
    Time Indication: 0
    Date: 2013.05.27
    Time: 12:14:24
    Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
    Component: TSG HR H21 0050
    Coding: 0002058
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
    Component: Parkhilfe 8-Kan H12 0060
    Revision: 00H12000 Serial number: 06320618801916
    Coding: 0201146
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H13 1130
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0010900
    Full leather/19"wheels/cruise/
    vw754's Avatar
    Nov 2006
    U.K
    1,968
    ive just read this on another forum.........
      1. 0157 is not an actual error is just a notification that compressor was overheated due to many changes of the ride level, can happen if you set your car at DYNAMIC and drive at about 100 kmh and not more.
        According to the Audi Service Procedure, this error must not be addressed in any way as long as there is no other malfunction indication in the suspension system.
    1. Audi Q7 3.0TDI-2008 S-Line - 2010 FACELIFT
      Mods so far: 7K7, 4K7, 8T4, 9WK, UF1, QV3, QV9+Mpeg 4 HD, 9M9, 4L7, 4E9 + Remote Closing, 3GH, 7Y3, 1D2, QF3, QH1, QQ1, VC1, 7AL, 7B1, 7F3, LED Interior Lighting+QQ1, Software VIM, iPhone 4G adapter, Front Infrared Camera+DVR, ACC Facelift Cluster, W12 MMI Control Panel, 2012 style wood/leather gear knob, Side View Camera, 7G9.
      Mods in progress: .......
    2. neo_andersson, Jan 18, 2013
    3. #33
    4. Ricky
      Hi neo thanks for the promptmreplynas always,
      So, are you saying that i should just leave it as is as long as there is no fault to be seen in the suspension sytem?
      Ricky, Jan 19, 2013
      #34
    1. neo_andersson
    2. yes, if you look at the error posted at this line "Fault Frequency: 2" you will see it happened only twice. so nothing to worry.
      Compressor is overheating and triggers this error when there is a leak in the pressure system so it has to run longer, but there is another error which must be present in this case as the system can no longer keep the selected ride height.
      In your case, as you have only 0157 there is no problem present.
    3. Audi Q7 3.0TDI-2008 S-Line - 2010 FACELIFT
    4. neo_andersson, Jan 19, 2013
    5. #35
  1. Needle Lift Sensor G80 plus a few other fault codes
    By vrbob in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2010, 13:52
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
