EM TuningBadger5
Results 1 to 9 of 9
    Mar 2007
    DORSET
    112
    Hidden menu access , software update ?
    Hi all
    I am going to buy a Ross tech cable from ilexa (authorised uk dealer) because I want to enable hidden menu on my2g mmi
    my q7 mmi has the 2860 software version .
    do I have to update to version 5570 before I am able to enable the hidden menu ?
    (have been quoted £270.00 from Poole Audi for this update)
    many thanks.
    Mar 2013
    12
    Hi, the update can be done at home, for 0 £... Just find on the internet the 3 CD of the 5570 version, and update it at home. There are many tuto that you can follow to update the firmware.
    I donnot know if you have to update the firm to enable the hidden menu. Anyway, you will have to make a modification through vcds
    Mar 2007
    DORSET
    112
    Hi,
    My q7 has software version 2860
    Does the 2g hidden menu work with this software version ?
    or do I have to upgrade to the 5570 software veversion .
    thanks in advance
    Jan 2012
    1,837
    You won't need to update to enable the hidden menu but be warned, one wrong move within the hidden menu will brick your MMI.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    Is there a specific reason you want hidden menu?
    TBH if you have VCDS you don't wanna play in hidden menu ... it's practically all in German ...
    Search in youtube there are plenty of videos of it ...
    Plenty of people have done MMI FW update@home ... there are risks but if you have VCDS you can scan car before hand ...
    Mar 2007
    DORSET
    112
    Hi,
    i know to keep well away from the bootloader.
    if I enable the hidden menu , what exactly can I change safely!
    (Ie making the alarm chirp when locking ,auxilary heater timings etc ?)
    Any links would be good,
    My independant vag specialist will enable the hidden menu for £39.95
    (Still deciding whether to buy Ross tech )
    thank you all
    Jan 2012
    1,837
    Only real thing in the hidden menu is battery meter
    Alarm chirp on lock is done via vcds not hidden menu
    Mar 2007
    DORSET
    112
    Thanks a6 chris,
    i have batt monitor at mo.
    what else can be done with the menu safely ? , what is it used for ?
    thanks
    gupsterg's Avatar
    Jun 2012
    279
    The are other things like for instance you can check DAB signal strength...
    Another is like change the MMI startup screens ...
    Someone's AC controls were thinking it was a LHD car and they were able to change it to RHD ...
    If you are paying £40 now for green menu... lets say later you wanna code in an accessory like AMI how much will that costs?
    Lets say you decide to do home servicing? how much for a service reset?
    What about you have a fault and need a diags scan?
    I feel for any modern car a tool like VCDS is essential... support from Ross Tech is good ... plus you will get better support/answers from forum members if you have a fault and post a VCDS log ...
    There are output tests which can be done also, this allows you to run tests to check items ...
  1. Extra functions/hidden menu via climate control?
    By liam in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2009, 19:06
  2. 26 D9 EGR ECU SOFTWARE UPDATE
    By jr001 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th February 2009, 18:44
  3. S3 - Software Updates?
    By PaulAr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th August 2008, 09:45
  4. ecu software update..any ideals what for??
    By skooby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2007, 09:58
  5. RNS-E Software update
    By danc in forum In-Car Entertainment
    Last Post: 24th July 2007, 17:08
