AH FabricationsJMB Retrofits
    Mar 2007
    DORSET
    112
    Hidden menu activation.
    Hi,
    would any one be able to activate my 2g menu in my Q7 ?
    or know of some one in the area.
    (if possible please).
    i live in Dorset , if any one is close by?
    Many thanks
    ps once the hidden menu is active ,can you only change things with a Ross tech cable and laptop ?
    PPS
    I pressed NAV , then set up , Pressed "set up" and return together and got the following on my mmi screen(sorry it's upside down)
    what does the menu info mean etc
    Mar 2007
    DORSET
    112
    Hi
    Can anyone explain the menu on the previous post ?
    thanks
  1. Accessing the hidden 3G MMI Menu
    By VRStu in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 2 Weeks Ago, 10:30
  2. Hidden menu of MMI3g
    By H5N1 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 7th December 2012, 20:56
  3. activating hidden menu
    By Ian Burton in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th August 2012, 12:52
  4. Extra functions/hidden menu via climate control?
    By liam in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2009, 19:06
  5. Active Subs?
    By mramage in forum In-Car Entertainment
    Last Post: 12th January 2003, 15:19
