Volks AutosBadger5
Results 1 to 11 of 11
Thread: mmi upgrade
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,971
    mmi upgrade
    is it worth getting the cd pack to upgrade the mmi in a 2006 q7 ? ive heard it can even eliminate battery drain,and other bug fixes?
    mine got the 4 772 i think the latest is 5570 ? any pro's, cons? component protection be affected?
    Full leather/19"wheels/cruise/
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Never heard of it fixing battery drain, i think your clutching at straws there, it removes the battery monitoring from the MMI and you have to manually put it back (if you had it in the first place)
    It has some bug fixes for the bluetooth and other bits, so it is worth doing to bring things up to 5570. But be aware if it goes wrong you can feck up a module and that can be costly.
    vw754's Avatar
    Nov 2006
    U.K
    1,971
    ok,thanks,can it go wrong? what happens if i dont put the battery monitoring back in?
    Quote Originally Posted by s8craig View Post
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    It's rare to go wrong, nothing happens if you don't put it back, you just get frustrated as your missing a function from the MMI.
    As you have such a high version already your not likely to lose functions that are there, it happens when you upgrade from lower rev software such as 2120.
    vw754's Avatar
    Nov 2006
    U.K
    1,971
    ok,nice one,aslong as i do what instructions say,i should be ok then, my version is SW:42.2.0 0709 42.20 THEN? I THINK.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    What instructions?
    vw754's Avatar
    Nov 2006
    U.K
    1,971
    IF ANY,or il just start with cd 1,2 and 3.....ive read somewhere to use cd 2 twice?,im sure it will come with instructions if i buy from audi.
    What instructions?
    vw754's Avatar
    Nov 2006
    U.K
    1,971
    if i get the 2013 sat nav cd from any audi sat nav, will it work in my q7?.........or just update mmi?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No it doesn't come with any, the disks are for installation by technicians so no instructions are provided.
    vw754's Avatar
    Nov 2006
    U.K
    1,971
    ok,is it quite simple then,just insert each disc one by one in the in-dash 6 disc changer?
    vw754's Avatar
    Nov 2006
    U.K
    1,971
    ordered the 3 mmi discs from audi,how do i put the battery monitoring back ?
  1. MMI 3G low firmware upgrade?
    By NeilStone in forum Satellite Navigation
    Last Post: 1st December 2012, 18:54
  2. Upgrading Audi A4 B8 MMI to possibly AMI?
    By audi58 in forum In-Car Entertainment
    Last Post: 1st November 2011, 10:59
  3. a6 mmi tv upgrade?
    By brian.n in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st August 2009, 18:59
  4. MMI without Nav- upgrade?
    By trekbiker in forum In-Car Entertainment
    Last Post: 28th May 2009, 21:27
  5. MMI Software Upgrade
    By mistrb in forum In-Car Entertainment
    Last Post: 7th December 2007, 21:11
