Chris NottAH Fabrications
    K13 ASJ's Avatar
    Aug 2011
    Buckie (north east scotland)
    176
    Q7 suspension problems, help!
    I'm away at work at the moment and one of the lads is having a problem he can't get an answer on:
    He has a 57 plate Q7 with air suspension.
    At the moment he can cyle through all the ride height settings but the NSF (drivers front) won't move an inch. All other corners go up and down, NSF nothing.
    He's had a disgnostic on it and has been told "its a sensor". using Bosch machine got the code, 01be?
    Before he takes it to Audi I thought I'd ask on here, anyone got any idea's?
    All help/ advice welcome.
    Thanks in advance
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Could be a sensor or the air valve leaking.
    Is that side lower than any others or its stuck at its current height?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    K13 ASJ's Avatar
    Aug 2011
    176
    It is sitting lower on that corner. On MMI its set on comfort mode but the nsf is sitting lower than the others.
    If he changes the settings on the MMI suspension modes, all others go up and down.
    There is also a amber suspension light that flashes on and off after driving around 500 yards.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    My only experience with air suspension is on a tourage.
    It had the same issue of sitting low on one side and it was the valves.
    They started to slowly leak and got worse over time, had the errors on the dash as well.
    The sensors was fine this time.
    You should be able to hear it leaking but if you spray some soaping water on the valves you can tell by the bubbles.
  1. Help....my brakes are sh*t!!...plus suspension problems!
    By A3Tom in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2010, 13:17
  2. HELP HELP...... S3 DIFF / SUSPENSION PROBLEM
    By Tom Mineral Grey S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2010, 17:41
  3. Suspension problem (I think) - please help!
    By A3_'99_Tsport in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2008, 21:25
  4. help ,suspension problems 2.0t quattro s ed
    By gaza in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th January 2007, 16:23
  5. instument problems, Help
    By fireblade in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th August 2004, 19:11
