DTUKForge Motorsport
Results 1 to 1 of 1
    Sep 2011
    Post Thanks / Like
    Fitting a Kufatec Comfort Hatch Module - Audi Q7 2011
    Just in case anyone is thinking of fitting the boot closing module to a 2010+ Q7 I thought I'd post some tips as the downloadable instructions are laughable!
    1) Ignore all the rubbish about removing the boot interior light to take a screw out to remove the rear boot trim - the screw isn't there any more! I just levered the trim apart near the LEFT hand side of the boot opening and gained access to the plug from there. The whole rear trim will totally come off if you like - its on spring clips. You need to remove the plug on the BLACK motor unit, not the blue one on the right (that is the opener!)
    2) You will need to solder and tape the wires on the module to certain wires attached to the plug - forget the instructions they are out of date and specify colours for cables (where they are actually all grey with German writing on!) Also forget calling Richter Sport LTD as they gave me the WRONG instructions!
    The correct wiring is:
    MARKING ON MODULE Connect to Wire
    CAN LOW PIN 7 Orange/Brown
    CAN HIGH PIN 3 Orange/Green
    GRUN PIN 5 Green/Yellow
    BRAUN PIN 4 Brown
    RoD PIN 8 Red/Blue
    The module fits easily into the extra space under the trim. It was actually quite a simple job after the faffing around for hours using the wrong instructions - hopefully this should make it easier for some of you.
    Double press open+close buttons to close the boot - job done.
    If you're interested the unit came to €133 shipped from Germany.
  1. Roof Module Fitting - Is Coding an Issue???
    By kevin00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th May 2011, 10:08
  2. No VCDS communication to comfort module MY10 A3
    By phil_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th May 2010, 23:30
  3. Coding Comfort Module
    By Acidic32 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st December 2009, 11:53
  4. Comfort lighting module
    By Ibzzzzz in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2009, 17:20
  5. Comfort/Central Locking Module Issues
    By judge888 in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 30th March 2007, 23:22
