EM TuningAdrian S Flux
Results 1 to 9 of 9
    oneniner's Avatar
    Nov 2004
    UK - Midlands
    12
    Post Thanks / Like
    How to take in Dash 6 Disc CD Changer out?
    Anyone know??? I have the Audi keys and have released the changer. However it seems I have to take the airvents out?
    Any help appreciated as I have a jammed CD.
    Audi B7 Tdi Avant and B7 Cab
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    It will pull out, the aircon just moves up slightly as you pull,
    My Retrofit Website
    http://www.tclsatnav.com
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,028
    Post Thanks / Like
    Dont just pull it - there are release lugs either side of the vent accessable through the slats - I'll try and post an elsawin pic.
    Porsche 997 Carrera 4 S - Black, Sport Chrono, Sport seats, PCM, Nav, Tel, Park assist and rear wiper (Yes!, its an option!)
    Audi Q7 SE - Silver,Nav, Phone, Panoramic roof etc etc.
    Gone -2007 S5 4.2 ,2008 S3, 2007 TTC 3.2, 2007 RS4 Saloon, 2004 S4 Saloon, 2006 A4 2.0T Sline SE,2002 A3 3.2 Sline, 2001 A4 1.8T,2001 Boxster, 1983 911SC,1992 Corrado G60,1988 GTi.
    (Vag com owner)
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    He already says he has the release keys
    My Retrofit Website
    The911SC's Avatar
    Sep 2003
    1,028
    Post Thanks / Like
    He has the keys for the changer - you need a special vag tool to release the air vent correctly - (its basically a hook with a handle on it)
    (Vag com owner)
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    No you don't, I have removed hundreds of Q7 CD changers, including my own and all you need are release keys and a good tug at it. If the heater vents get in the way, then gently pull them up with your fingers and the CD changer will slide out.
    My Retrofit Website
    The911SC's Avatar
    Sep 2003
    1,028
    Post Thanks / Like
    Thats not the correct way of removing and you risk snapping the lugs in the vent or bending the chrome trim as the vents overlap the cd changer by a good few mm with chrome trim - guess you dont follow the workshop guide and yours was ok...
    (Vag com owner)
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    Yes mine and everyone elses were OK
    My Retrofit Website
    iconoclast's Avatar
    Apr 2010
    In, Out & Around
    22
    Post Thanks / Like
    Quote Originally Posted by The911SC View Post
    correct, you need to properly remove the vent before you do this to avoid cracking the vent housing.
    do you have elsawin photos/instructions on removing the silver speedo/nav bezel?
    i would like to have mine painted with soft-touch but do not want to break it on removal.
    i can only find instructions on a6, similar?
