AMD TechnikUnicorn
Results 1 to 9 of 9
    Oct 2009
    Bulgaria
    6
    Post Thanks / Like
    my project 1.8t 450hp
    Показване на романизацията
    Turbine Garrett-gt 3076
    New titanium and strong beat Pistons.
    Full inspektsia the motor, smiana of bearings, pulleys and other segments.
    Gateway to the head, new valves and guides to fit and shlaif.
    Ceramic clutch at high pretiskatel and revised flywheel.
    ECU and Electronics from the TT-2003.
    Electronics Greddy spec-2 for the turbine opravlenie
    Diuzi 670kub.
    Second tank 5l. with pump Bosh -400 liters per hour, all in the trunk
    Kuler turbo and new roads.
    New genetatsia, Daunpaip of 110 millimeters. Back to 73m.m. sports with pot and resonator
    New water pump
    Horse-adjustable suspension
    Brembo front discs sport 320m.m.
    Gearbox of RS.
    Wheels of RS-4
    Front cover of carbo SEIBON
    Crankcase ventilation
    Revised reactor.
    Blol off BLITZ.
    Recent data from Dino Run in MADNES-MOTOR SPORT.
    450 hp the shaft and 530 n.m. time
    Nai good score of 400 m. 11.900 seconds.
    Oct 2009
    48
    Post Thanks / Like
    Impressive, any pictures?
    A3-sport's Avatar
    BOSE
    Mar 2009
    197
    Post Thanks / Like
    Cool. Whats the 0-60 in that? Looks impressive.
    FOR SALE: A3 (8P) Car Mats - Front pair & full set - BRAND NEW
    2004 onwards: for the 3-door, Sportback, quattro and cabriolet versions.
    Oct 2009
    Bulgaria
    6
    Post Thanks / Like
    I can not upload photos, please help
    Oct 2009
    48
    Post Thanks / Like
    Quote Originally Posted by spas-gt View Post
    Get onto www.tinypic.com, upload the pic and then copy and paste the link - job done!
    Oct 2009
    Bulgaria
    6
    Post Thanks / Like
    http://tinypic.com/view.php?pic=wjtc3c&s=6
    http://tinypic.com/view.php?pic=2d7f2c4&s=6http:
    http://tinypic.com/view.php?pic=10e1y60&s=6
    http://tinypic.com/view.php?pic=i2j7k7&s=6
    Oct 2009
    Bulgaria
    6
    Post Thanks / Like
    http://tinypic.com/view.php?pic=2ithaur&s=6
    I do everything myself, and I need your help and advice.
    Oct 2009
    Bulgaria
    6
    Post Thanks / Like
    car without a meter is set up with some factory ECU can you give me advance a table for 2-bar.
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    MAF less tune on a MAF ECU (narrow band without MAP) can work and there are lots of guys in the US doing it without problems.
    It can be risky as you have no real way of monitoring how lean/rich you are running at WOT and requires a very smooth remap.
    I would want a top of teh range wideband AFR guage to keep an eye on things
