Monster MotorsportBadger5
Page 8 of 9 FirstFirst 123456789 LastLast
Results 281 to 320 of 334
Like Tree1Likes
Thread: Project RS28
  1. #281
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Cool. You got me thinking now...
    Does the 'wood' facia just pull off / unclip?
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
  3. #282
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Liking the centre console mate.
    I keep looking at mine and thinking of doing something like that.
    I'm shocked that no one made a complete replacement to save having them annoying little spacers.
    The lights do look a lot better as well.
    Hows the ICE coming along?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  4. #283
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Quote Originally Posted by Geeman View Post
    You got some allen/torx screws behind the HVAC unit.
  5. #284
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Very clean mate! - Nice suttle changes... Red is my favorite colour aswell!
  6. #285
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Thanks lads.
    Geeman- As Scott said, screws/torx but im sure they were behind the stereo?
    Scott- Thats all the front end stuff finished now, so just to concentrate on my amp rack, then trim that and the box and install subs, 2nd amp etc. Not long now, promise! lol.
    Rob- Thanks mate.
    Project RS28 build
  7. #286
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Quote Originally Posted by Foxmeister View Post
    You might be right, I knew it was one of the two.
    Foxy, will it be ready for the next AITP?
  8. #287
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by scott b5 View Post
    As in next year Scott? Definately will have all loose ends tied up by then, hopefully even running the charger by then too!
    Project RS28 build
  9. #288
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Next year mate.
    should give you some time to get it done.
  10. #289
    Chin.'s Avatar
    P88LSH
    Jan 2011
    Grangetown, Middlesbrough, United Kingdom, United Kingdom
    184
    Lovely looking car mate, well done
  11. #290
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by Chin. View Post
    Cheers mate, hows the B7 coming along, wots next for it?
    Project RS28 build
  12. #291
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quick vid of noise from inside, and rediculous mpg when used properly!
    Project RS28 build
  13. #292
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Nice.
    Who beeped?
  14. #293
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Nice.
    Who beeped?
    That was me, Doh! Leaned on the horn!
    Project RS28 build
  15. #294
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    i see that at 5mpg
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
  16. #295
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by rasA4 View Post
    i see that at 5mpg
    Yep, and thats without the Charger fitted yet......Can you get negative values for MPG? Find out next year! lol
    Project RS28 build
  17. #296
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Following on with the audio install, this is for the amps, with template
    Had to countersink the mounting points
    Top side drilled through with 10mm holes
    Trial fit in the car....this is why the bolts were added before
    Longer bolts will be cut down, and countersinking so amps can be mounted over these fixings
    The rack obscured the boot light slightly so trimmed of a bit
    Drilled corners then jigsawed out
    Made up a template to trim some edge of the rack and so it flowed better with shape of boot
    Cuts done
    Back in for another trial fit, looking better now
    Project RS28 build
  18. #297
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Then i had to configure the amp arrangement
    Decided to space them, ready for wiring
    All marked out and holes started
    All fixed wiring on top side
    And complete
    Used this to take back to metal for good earth
    Rack in final position with cables all routed thru
    Subs ready for fitting
    Banana plugs and cable for subs
    Finally all wired and in position
    Settings all accessible from inside the car
    Just some last pieces needed to cover the cable run, trim the rack and box and form some mounting design to solid mount the box, carry on with this soon, unless i decide to sell!
    Project RS28 build
  19. #298
    Jun 2011
    GLASGOW
    20
    Decks sake Mick. Just read from the start. Hat off to you. Car is looking sweet.
  20. #299
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    eyy up lad looking good ive done a similar thing to mine with the amp tray as i didnt want to amps on the back of the seats
    great minds
  21. #300
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Brian- Thanks mate, kept me busy the last couple of yrs!
    Ras- Great minds alright, Ha! Get some pics up of yours, never get to see it really, lovely car!
    Project RS28 build
  22. #301
    Oct 2011
    14
    holy sh!!t i love the carbon parts on your audi! and nice backlights in red!
  23. #302
    Oct 2011
    168
    looks awasome mate .. very good project you have going.. need more pics of the charger lol
  24. #303
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Thanks mate.
    The charger has been put back till next year now, but will be digging it out soon to clean and service it ready for install. Car is back off road now and next stage of work is in planning, more to come.
    Project RS28 build
  25. #304
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Well this is how the car was put away, front bumper had a little tussle with the driveway again the last time i moved it, left it looking like this
    OUCH!!! Bumper has seen better days so decided to get it off anyway seeing as the cars back in the garage
    Kinda like the look without the bumper, if only it was legal!!! lol
    Will decide on a replacement later when its near the road again, doesnt need it for now!
    Project RS28 build
  26. #305
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Thats a harsh drive.
    No wonder you keep catching the bumper.
    Shell out for some Air ride.
    What is it in the garage for now?
  27. #306
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Tell me bout it, plan is to move in a year or so, so will hopefully eliminate that problem soon!
    I took it back off the road when i lost my job mate, cashed in the tax aswell as its too thirsty for daily duties and cant run it on my "im a feckin scumbag not trying to find a job" allowance! Will use that time wisely to upgrade some bushes etc and vacum lines for when the mighty charger gets thrown into the mix!
    Project RS28 build
  28. #307
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Ouch kinda does look good without front bumper, lol looks like its been in a fight bottom jaw missing
  29. #308
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Its a rogue alrite!!!
    Project RS28 build
  30. #309
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Cant believe i havent seen this since Nov! Car has been locked away due to financial issues after job change, and getting ready to move home soon so no more stupid camber on the drive to ruin it anymore!!!!!!!
    Ready to start a few things on it in the next few weeks to get the ball rolling for this year, and a custom front bumper to be fitted for the time being till i can source and have an RS4 bumper done again at a later date.
    Project RS28 build
  31. #310
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Blast from the past mate.
    Hurry up and get some updates. :D
  32. #311
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by ScottB5 View Post
    Im trying, im trying! lol
    Just been so busy with other stuff that its took a back seat, will have some updates in the next week or 2!
    Project RS28 build
  33. #312
    Oct 2011
    West Yorkshire
    67
    Awesome project mate
  34. #313
    Mar 2012
    Durban, South Africa
    22
    Visit PelicanBlue's Instagram Channel
    Ahoy!
    I posted on your thread at superchargedaudi but it appears that this is where you post more frequently.. just wanted to congratulate you on the work you've done on your car and i certainly will take lessons from your experiences and DIYs.
    I was just wondering whether your PES G2 install was successful?
  35. #314
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Hi guys,
    Thanks for kind comments.
    PelicanBlue- I havent been on SC for a bit mainly due to not having done anything with the charger install yet, have mostly everything needed now including equal length DP's, uprated injectors etc, the other bits are the expensive and harder to find stuff like somebody to do a full custom map on it as i believe the PES map is pretty crap. Im currently moving home also which is taking up a lot of time and money, but as soon as i have settled and saved a bit, i intend on pushing on with it again, will update here and on SC Audi when i do to let you know.
    Cheers!
    Project RS28 build
  36. #315
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Quote Originally Posted by PelicanBlue View Post
    Ahoy!
    Welcome to ASN. Hope you enjoy the forum.
  37. #316
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    At last, an update, in between all the house move stuff aswell....
    Anyway, made a start on getting the seat mounts fabricated up. Started off with the Ford RS Recaro sliders, had to remove the mounts fitted for the Escort, quite easy, bit of grinding and they were off
    Got the auld man skivvying for me aswell! lol
    All done and smooth, ready to mate
    And one perfectly good Audi Sport seat....
    Dismembered......
    And a quick mock up of both runners
    Now its a case of some measuring and get a tack weld to attach them, then a trial fit of the seat, if all is good with measurements and heights etc, the 2nd will be done, then sent in for seam welding and painting, ready to fit.
    Hopefully able to trial fit one seat tomorrow seeing as the weathers holding up!
    Project RS28 build
  38. #317
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Bout cuffing time mate. lol
    I hope this thread pics up speed now.
  39. #318
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Just for you Scott^^^ (now seeing as weathers good, go fit those wheels ya whorebag!)
    Unfortunately i didnt make it to welders today, more "home" things had to happen first!
    But i did manage a quick trial fit in the Audi to make sure all looks well
    At this point there are 2 means of slide adjustment, the Audi design that is on the B5 frames and the Recaro design that is on the Ford sliders. Decision made to cut up the rest of the Ford design to obtain only 2 rails i need that bolt onto the bottom of the Recaro seats, these will now be set out and welded onto the B5 base, tac at first with a test fit of the seat to check heights, position etc with any final adjustments done, they will then be fully seam welded at every contact point possible between the rails, to obtain a proper, single piece seat mount ready to fit.
    More pics from today
    And what im now left with from the Ford rails
    Some careful measuring of the seats
    And my Rolf Harris engineers drawing
    Looking like i might have tomorrow off maybe, so will defo get the welding started if thats the case!
    Project RS28 build
  40. #319
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Faster gold fish man, if you go to slow you'll forget.
    Looking forward to the final bit of the puzzle mate.
  41. #320
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    LOL^^^ You crazy Mr Scott!!!
    Well its off to the welders soon, hopefully have some fitted pics later!
    Then its time to start saving for the REMAPPP!!!!!!!!!
    Project RS28 build
