Chris NottBadger5
Page 2 of 2 FirstFirst 12
Results 41 to 46 of 46
  1. #41
    SixDegrees's Avatar
    Aug 2009
    73
    What paint did you use? Your thoughts on it; good, easy to use, worth the money, etc? Thinking of doing mine as the car is all black and could od with a subtle splash og colour
    A3 1.8T Quattro (2001 | Y) - Black, 5DR, Full Leather, Recaros, Climate, CD, Elec Everything, TT Alloys
    BMW 320 MSport Touring (2007 | 57) - Le Mans Blue, 18" MV3s, PDC, Cruise, CAR
  3. #42
    ROLTYA3TURBO's Avatar
    essex boy :)
    May 2009
    essex, uk
    247
    Search for the thread I made called 'painting engine cover' it was a writeup I done while painting mine.
    There's a local car paint shop I went to to get the azure blue mixed up,the primers and clearcoat I bought where from halfords.easy to use,pretty cheap and readily available .what colour are you gonna do yours?
    '98 azure blue a3 1.8t, forge 007p,KW 40mm springs/shocks,18" polished rs4's,s-style chrome mirros,black diamond front 20 groove discs,ebc greenstuff pads,painted and decal'd calipers,colour-coded engine cover,aero wipers,chrome indicator bulbs,l.e.d xenon sidelight bulbs,h.i.d xenon headlight bulb kit,let the work begin!
    Latest addition - s style chrome mirrors
    Next up - remap,exhaust
  4. #43
    SixDegrees's Avatar
    Aug 2009
    73
    Quote Originally Posted by ROLTYA3TURBO View Post
    Sorry, meant to say brake calipers. But I'll also check out the cover thread as I might do a wee bit colour inside the engine bay.
  5. #44
    essex boy :)
    May 2009
    essex, uk
    247
    ohhhhhh lol.i used normal hammerite out of the tin with a brush cleaned the calipers up with brake cleaner/degreaser wire brush and sandpaper then just brushed it on,1 coat then left to dry,2nd coated when dry and there fine .just lucky hammerite make a similar colour paint as my car
  6. #45
    Spec's Avatar
    Currently just a Clio owner :(
    Jul 2008
    Birmingham, In the Yellow Clio
    84
    nice this is.
  7. #46
    essex boy :)
    May 2009
    essex, uk
    247
    well after a few weeks of having the kw 40mm kit on,it's bedded in nicely!only thing that had been bothering me was the gap in between the front wheel and arch,seemed a little too high still,took a good look round and made a few phone calls to kw,and turns out me and my old man had put the springs around the wrong way which is what i thought at the time but my dad werent having it!but anyways it's no biggy,just gotta take it all apart and swap them around!cheers dad so that's a job for the weekend!
    also i have been having some temperature issues,as in the temp gauge was showing 65-70 while running then if sitting still would get really hot,so i've got a new temp sender and thermostat and 2 bottles of g12 coolant.got both the stat and sender as i thought might aswell renew the lot and make sure rather than running backwards n forwards for parts.so gonna flush the coolant system and renew the coolant at the same time.so i've got some bits to keep me busy this weekend
