Sky InsuranceJMB Retrofits
Page 8 of 13 FirstFirst 12345678910111213 LastLast
Results 281 to 320 of 512
  1. #281
    jcb
    Sep 2005
    uk
    4,077
    custom fab? must have been pricey
  3. #282
    Oct 2007
    2,597
    Quote Originally Posted by jcb View Post
    Cheaper than Audi's 13,5 kilo item.
  4. #283
    Oct 2007
    2,597
    Removed the wiring harness, ready for modification. Includes removal of the auto box ECU / connector, replacement of the main ECU connector with the VEMS one...
    Flywheel fitted to S8 motor...
    6 speed gearbox trial fitted, to determine timing reference...
  5. #284
    Oct 2007
    2,597
    Timing sensor location...
    Engine's on TDC, in theory the 2 missing teeth should be close by. But, it would appear the 60-2 teeth location is different between auto and manual cars.
    Each tooth is 6 degrees. The sensor location on the transmission is 11 teeth before the timing reference. The orange paint denotes the sensor location with the transmission removed.
    So, the EMS will be mapped to recognise the settings...
  6. #285
    May 2003
    9
    Awesome project, all I can say is that your car looks meaner in real life and lower also. Often see it when I am biking to work.
  7. #286
    Jul 2007
    Essex
    400
    Spot on loving the work... just had my engine apart. Isnt there a spacer plate that sits between the box and the block on manual cars?
    Ming Blue A4 B5 RS4 Replica (SOLD)
    T28 Kit (SOLD)
  8. #287
    beeitch's Avatar
    Mar 2006
    Madrid, SPAiN
    64
    Great, awesome, amazing job !....
  9. #288
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,369
    i think the spacer is to accomodate the dual mass flywheel?
    Do you have to shorten the input shaft on the gearbox when bolting it up without this plate?
    TD5 Land Rover Defender build
  10. #289
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    The timing ring looks bolted on, can you not remove it and replace closer?
  11. #290
    Oct 2007
    2,597
    Quote Originally Posted by Byzan A4 View Post
    Timing ring is not bolted on.
    It's in the correct place, and machined directly into the flywheel.
  12. #291
    Oct 2007
    2,597
    Spacer is for DMF, yes.
    Not required here.
    The stock propshaft has enough plunge to acommodate the tranny without the spacer, which is 11,2mm.
    But just in case, I have an RS4 propshaft too.
  13. #292
    Oct 2007
    2,597
    Quote Originally Posted by tombee View Post
    You live local to me then?
  14. #293
    May 2003
    9
    Yes I do mate.. Ipswich.. I don't have a Audi any more tho I have a E34 M5 but looking to get a S4.
  15. #294
    Oct 2007
    2,597
    Hmm. Haven't seen any M5's lately down here.
  16. #295
    May 2003
    9
    Quote Originally Posted by Siena View Post
    She doesn't come out too much.. Maybe could meet up to see each others cars.
  17. #296
    Oct 2007
    2,597
    That'll be cool.
  18. #297
    jcb
    Sep 2005
    uk
    4,077
    re using the flywheel bolts? thought they were stretch items...
  19. #298
    Oct 2007
    2,597
    They're not stretch bolts on the S8.
  20. #299
    Oct 2007
    2,597
    The S4 / RS4 bolts with 17mm hex head are stretch items.
    S8 with 15mm hex head are not.
  21. #300
    Jul 2007
    Essex
    400
    Not required here.
    Ohhh crap, i have just installed my SM flywheel and retained the spacer plate will having it on damage my new clutch? or should i take it off ASAP?
    T28 Kit (SOLD)
  22. #301
    Oct 2007
    2,597
    Quote Originally Posted by Andy.B View Post
    Spacer plate?
    How thick is it? If it's thick enough, it wouldn't damage your clutch, it'll just mean your clutch slave cylinder piston will have further to travel, before it actually pushes the pivot arm.
    It could also cause difficulty in engaging gear, as the clutch pedal will reach its stop, long before the actuating pivot arm does...
  23. #302
    Jul 2007
    Essex
    400
    Its the standard audi spacer plate between the box and the block for the 1.8T prob around 1.5mm thick IIRC. The clutch works very well and has no chatter or problems engaging / disengaging.
    T28 Kit (SOLD)
  24. #303
    Oct 2007
    2,597
    Ah, you'rs isn't actually a spacer.
    More of an engine backplate, so that's fine.
  25. #304
    Apr 2004
    12,520
    the thin dust sheild thingy? I cannot see it being a problem,dont worry
  26. #305
    Jul 2007
    Essex
    400
    Thanks guys top advise
    T28 Kit (SOLD)
  27. #306
    Oct 2007
    2,597
    RS4 propshaft to enable fitment of S4 DSY 6-speed tranny...
  28. #307
    Oct 2007
    2,597
    Well guys, updates have been slow in coming along.
    I've been pretty busy, between setting up my business, getting the website set up, organising my "getting hitched" for next autumn, I haven't had a great deal of time for Outlaw.
    But, the hard work's almost over, haven't slept properly for 3 weeks.
    I can now focus on Outlaw. Anybody got front driveshafts for a 1.8T / V6 manual FWD?
    Still need to buy a clutch, then all the ingredients are at hand.
  29. #308
    jcb
    Sep 2005
    uk
    4,077
    I have two front drive shafts off my 1.8t minus inner CV's.
    kept those for the RS4 hybrids I am running to mate with the RS4 hub carriers.
    any use?
  30. #309
    Oct 2007
    2,597
    Lol, no. I specifically need them with the 108mm inners, to mate to the S4 6-speed box.
  31. #310
    A4 2.4 30V PES Supercharged
    Sep 2006
    Derby
    159
    Havent been on here for over a year now due to illness, thanks for making me smile, one hell of a project. I'm def getting a supercharger for my 30v now, you have inspired me thanks.
    A4 2.4 30V
  32. #311
    Oct 2007
    2,597
    Good to have you back, McKay. Hope you're better now.
  33. #312
    Oct 2007
    2,597
    I done a timing belt and waterpump kit on a B5 RS4 today.
    Has covered 93,000 miles, and had a stage 3+ clutch fitted at 68,000.
    The clutch feels very heavy, he hasn't gotten used to it in all this time.
    I've decided to go for a stock RS4 clutch for my car, will be ordering it next week.
    I still need a pair of driveshafts, off a manual B5 1,8T/V6 FWD. There've been enough cars breaking on here of late, someone must have a pair. C'mon guys!
  34. #313
    Oct 2007
    2,597
    My clutch turned up today - pressure plate, friction disc and release bearing.
    Also got a needle bearing, as the S8 was an outo, and had a steel bush inserted in the crank, to support the torque converter.
    Still after a pair of 1,8T/V6 FWD driveshafts, else I'll just have to purchase them new as well.
  35. #314
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    So come on Siena, when is the likely completion date of the project?
    These constant cliffhangers are killing us!!!
    Mo power, mo problems
  36. #315
    Oct 2007
    2,597
    BT, it'll be done once I have everything in place, I'll never pull a daily driver apart, untill every conceivable part is to hand.
    Getting married next year too, so that's definitely a priority.
  37. #316
    Jan 2004
    York
    1,656
    Can the drive shafts be removed and still leave a car capable of being pushed in and out of a garage ?
    MY15 8V S3 Sportback with options
  38. #317
    Oct 2007
    2,597
    Yes, they can.
    Obviously, you couldn't tow the car a great distance without ruining the wheel bearings, but if the car's a breaker, it wouldn't matter.
  39. #318
    Jan 2004
    York
    1,656
    Ok can you drop me a PM on how to remove them and I'll have a pair of V6 shafts off this weekend for you.
  40. #319
    Oct 2007
    2,597
    Auroan, you need to undo the central hub bolt.
    Very tight, so needs to be done with the weight of the car on the wheels, and wheels firmly braked / chocked.
    Then with the car raised and supported, remove both front wheels.
    Disconnect both lower arms, and the uprights should pull away from the driveshaft splines.
    Next is the inner CV-to-transmission bolts.
    These are spline-headed bolts, and it's wise to make sure they are free of grit, so the spline tool can be firmly tapped into the heads. If the spline bits arent fully inserted, you run the risk of stripping the splines.
    Once all 6 per side are undone, you may need to lightly tap the inner CV's with a soft mallet, then they should crack free. Withdraw them from the outside, job done.
    You'll just need to re-connect the uprights to the lower arms, then the car can be pushed.
  41. #320
    Jan 2004
    York
    1,656
    cool, lets see how I go on Sat !
