Volks AutosEM Tuning
Results 1 to 10 of 10
Like Tree9Likes
  • 1 Post By peterg60
  • 2 Post By peterg60
  • 3 Post By peterg60
Thread: mk1 golf 1.8t frankenturbo f23 build
    peterg60's Avatar
    Jul 2012
    fought i put up my build on here since loads of 20v builds and hybrid builds. this is my mk1 golf 1983 hellious blue.
    i always wanted a 20v turbo after seeing loads of people doing it. after some quotes of £5000 + supply and fit i decided to have a go myself . i was a bit worried as ive only changed a oil filter in a car before, but i fought i have a go. what can go wrong hey!.
    the old 8v out
    engine agu 80k
    running megasquirt manegment as i wanted to have a go to map it myself
    fully repainted
    went to fit some forged conrods. opened engine up and cambelt faluire on ebay engine
    old pistons
    cylinder 3 bore
    head some bent valves
    bores honed
    pistons from a low milage passat aeb engine same pistons as agu 20mm wrist pins
    new pistons installed along with forge rods and racing bearings ( see my wallet its low )
    cylinder head rebuilt by a m8 of my had new
    new exhaust valves
    new valve guides
    valves remachined
    head skimmed
    dechoked
    new tensioner
    epytec g60 adaptors
    ScottD3 likes this.
    peterg60's Avatar
    Jul 2012
    engine all fitted up just need to fitting timing belt and sort loom back.
    f23turbo(boxed)
    rentless v3 manifold
    cremic coated f23 hybrid turbo
    came with oil/water lines aswell
    matt from trackslag needed a mk1 golf to make a downpipe for his range of downpipes and exhaust so he used my
    3 inch downpipe done
    bigger toyo intercooler fitted
    made my own tip with a jetex filter
    ScottD3 likes this.
    peterg60's Avatar
    Jul 2012
    aem wideband
    then thursday i went to fit the new bosch 550cc injectors into my fuel rail and they were shorter than the standard ones
    so a drive up to badger 5 and bill sorted me some unspacers
    ready to bed in rings
    well took my car to the dyno day at garage streamline and was happy with the results(thanks eddie). needs more mapping and boost to be turned up to 1.5 bar or maybe more running on asda fuel lol
    here is a video at 10 psi
    mk1 1.8t k04 hybrid 10 psi run garage streamline - YouTube
    and pitcures and dyno plot with 0.7 bar and 1.2 bar. i need a electronic boost controller as the mbc boost drops
    Dean_T and ScottD3 like this.
    peterg60's Avatar
    Jul 2012
    so i upped the boost and took the car to dyno. still on asda fuel i know i forgot.
    then car went to bills. it was detting uptop . needs mapping propley
    [/url]
    lost 2 psi some where
    so car in now in bits in garage. im in talks with dough at frankenturbo with another manifold. so will report bk when all fitted with vpower and mapped by a proffessional
    peterg60's Avatar
    Jul 2012
    took car to gti internatinal and did a 13.3. oh and a diff will be fitted next week
    mk1 20v f23 hybrid(bassi) v mk3 vr6 (lee) gti international 2013 - YouTube
    and some pitures of curby sprint day clubgti
    [/url]
    [/url]
    [/url]
    Dean_T, ScottD3 and TwedA4 like this.
    peterg60's Avatar
    Jul 2012
    me and chris on curby track he got fastest time i took it easy
    curborough 2013 chris Chris Eyre and pete bassi - YouTube
    JimmyH's Avatar
    Oct 2013
    Marham
    242
    Nice build, I half way through my MK2 20VT at the moment, things take for ever when your a perfectionist
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,905
    Impressive work
    Nov 2013
    101
    wow, good work mate! And you've done a spot on job if you haven't done much tinkering in the past! all the work i do usually is ghetto mods... works but looks nasty haha.
    Dean_T's Avatar
    May 2004
    West Mids
    523
    Great work, respect for taking on such a big job and winning!
    Dean.
  1. Neru's A3 Frankenturbo F23 Build
    By Neru in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2014, 08:10
  2. Mk1 Golf
    By Andy101 in forum The Cool Wall
    Last Post: 13th June 2012, 20:31
  3. Mk1 Golf with S3 engine?
    By S3_2007 in forum The Cool Wall
    Last Post: 3rd July 2008, 10:15
  4. Selling advice.... mk1 golf gti
    By ValverLad in forum General Chat
    Last Post: 24th January 2005, 18:53
  5. MK1 Golf 507bhp 190MPH
    By daver in forum Volkswagen and other VAG
    Last Post: 27th December 2004, 14:19
