Sky InsuranceVolks Autos
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 138
Like Tree2Likes
Thread: Lëon OEM+
  1. #41
    jamiebennett81's Avatar
    May 2008
    230
    So I drove over to Nicks to pickup a set of lower arms and wheel hubs, top man! saves the car sitting on axle stands for months on end, and means its easier to do a straight swap when the time comes
    How I got them:
    Spent an hour cleaning them tonight
    de-greasing
    First scrub down with a wire brush and picking the old paint off with a screw driver, a bit to go yet
    These are going to need quite a bit of work to get like new again
    hanks to a few members off Edition today, they pointed out a 30% sale on euro car parts, so ordered two new lower ball joints and two new wheel bearings
    Next up is to scrape all the sound deadening out of the leon, take the roof lining out and as much weight as possible....potentially the air con as well as that weighs a ton
  3. #42
    May 2008
    230
    Bought some of this today....not cheap but will make it easier and get the job done
    and here's a picture of her next to my mates R5 before she was SORN
  4. #43
    May 2008
    230
    Been trying out the rust stuff today, it's actually really good, and has really stripped the rust off with very little work
    still some discoloration, but it has stripped the rust and some paint right back. I am going to leave it on over night, then clean it off tomorrow. Pretty much done and ready for painting then
    This was one of the worst arms. A lot of rust has been stripped but still a way to go yet
  5. #44
    May 2008
    230
    few bits arrived
    ordered some snow foam as well to clean the rear arches as I will be sealing these, shortly and ordered some butyl as well to sort out the leaky doors
  6. #45
    May 2008
    230
    in progress
    Bought these from AKS Tuning as well, OEM+ coolant and washer caps in black, look awesome. One problem with spraying the washer cap is the paint cracks when you bend the fixing point back onto the bottle. This doesn't happen with this washer caps as the actual plastic is black
    Coolant
    Washer
    Snow foam turned up also, so I can prep the arches and sills and get sealing these before the cold properly sets in
  7. #46
    May 2008
    230
    Had a fairly productive evening tonight
    Gave the arms a final coat of paint tonight, all done. Just need to drill out the bushes ready for the new polybush ones
    [imghttp://i253.photobucket.com/albums/hh67/jamiebennett81/Lowerarmsfinished.jpg[/img]
    Then I got onto the black sound deadening, was quite therapeutic doing this actually
    To the side of the footwell
    Then the spare wheel well
    A good 5kg of this stuff already, and got the whole of the footwells to go which is very thick, so a good 15-20kg I reckon of weight to come
    Got a shot of the engine bay, very dirty and bogging looking, nothing pretty about it
  8. #47
    Nov 2011
    215
    Hello fancy seeing you here!
  9. #48
    May 2008
    230
    Cracked on with working on the car tonight
    Sound deadening removed from under the rear seats
    Removed the drivers seat, and cracked on with removing more sound deadening
    first half gone
    full bag already of sound deadening, good 10kg's already
    Up in the air again
    Spot the difference and what is missing....
    Dirty arch
    Cleaned guard
    During clean
    Spotted three spots of rust, so I am glad I started this job now
    Lower arms all done
    Arch now sealed and left to dry
    2001 Seat Leon Cupra. 291bhp 13.4 1/4 mile @ 108mph.
    Click the picture below for my build thread.
  10. #49
    May 2008
    230
    Decided to start tidying the interior up, and get rid of the old glue left over from the sound deadening
    Before
    After
    Rear patches tidied up
    spare wheel well (still a bit to sort)
    Made a brief start on the drivers side
    Before
    After
    Roof lining, grab handles, interior lights and plastic side pillars removed
  11. #50
    May 2008
    230
    The car was absolutely full of water, I knew it had a leak but didn't realise it was this bad....and we have had some pretty torrential rain
    Luckily I left some big cloths in there to soak up the water....I literally squeezed out two pints worth of water from them!
    The water is pouring in from the pollen filter housing. I removed this last night, and the seals around the pollen filter were soaked. So I resealed these and I need to reseal the plastic cover against the windscreen, but ran out of sealant
    Apologies for the poop quality
    So the evening started off like this
    Pollen housing...minging
    Screwed seals around the pollen filter housing
    Now resealed, so hopefully this will hold out for a while. Doing the rest of the sealant tonight
    I finally got round to sealing the last wheel arch.
    During cleaning
    Sealed
    Next up is finally crack on with reconditioning the hubs, removing all the old sealant glue, relocate the battery and start to design my custom housing to enclose the air filter.....
  12. #51
    May 2008
    230
    Got most of the old glue off from the sound deadening
    Pulled off the passenger cover tonight...trying to find the source of the leak as it's still leaking...and losing some more weight from the car
    Before
  13. #52
    May 2008
    230
    Wheel arch refitted for the last arch which was sealed
    Finally got round to adding the last resistor to the removed SAI, so the error code stops coming up (Thanks to Mylo again for making this up for me)
    tidied it away since the pic.
    Sorry Bill....but I have rebuilt it since
    Old Vs new pollen filter
    Hopefully sealed the leak...but still don't think I have properly, as yet again the cloths on the passenger floor were absolutely soaking
  14. #53
    May 2008
    230
    These arrived (and still to be fitted yet also)
    3" Downpipe and decat off Nick
    Silica Gel, to soak up the moisture, as still got a small leak, and water collects on the inside of the roof (no roof lining)...also with it sitting around so much it never gets warm to dry up the moisture, so this will have to do for the mean time
    First set of polybushes arrived also
  15. #54
    May 2008
    230
    Determined to get my downpipe off ready for the 3" downpipe and decat....in the pouring bloody rain
    Downpipe off, not too difficult but made harder laying on the drive way
    Spot the restriction. 3" DP vs the restrictive supposed updated downpipe from Blueflame which is measuring in at just over 2.2"
  16. #55
    May 2008
    230
    So I got the spark plugs changed, which had not been changed since the turbo went pop.....they were very oily
    Old Vs New
    This was the plug nearest the turbo (something isn't right)
    Next was to pull out the sensors from the existing exhaust, but first I had to get this bolt out of the decat which was a pig...ended up putting the spanner and standing on it, which released it
    sensors out and then I put them in the 3" DP and decat....again standing on the spanner to undo the sensors!
    Then my outside light went pop!
    Inside of the old cat as well
    Next will be getting the DP and decat on, and changing the fuel filter
  17. #56
    May 2008
    230
    Time to replace the rocker cover gasket and the valve cover gasket
    Valve cover off, came off nice and easy too
    Bit of dried gunk on the 4th valve
    This is the old valve cover gasket, the 4th one which was where the oiliest spark plug was....I couldn't notice any splits or particularly worn gasket
    Fresh nuts also
  18. #57
    May 2008
    230
    Stage one to losing some more weight out of the car, this turned up
    Corbeau Pro Kevlar, weighing in at 8.6kg, compared a good 35kg+ for my leather electric seats. Only one at the moment as I couldn't afford two at the same time, so the second one will come later.
    Other developments recently are my 3" Downpipe and decat are now on the car, and has made a big difference. You can really hear the turbo spooling even more now. Thanks to Nick.
    Getting the seat fitted on the 10th March, then next up will be ordering my water meth kit
  19. #58
    May 2008
    230
    Box steel arrived ready for the bucket seat being mounted
    Relocating the battery
    Bucket seat was installed. Started at 9 and finished at 18:00.....for one Seat. I did not realise the amount of work that went into this, but wow.
    Nick is an absolute legend, and his technical skills amazed me today.
    Today started off like this, at Prawn HQ
    Seat out
    Nick drilling out the welded OEM Seat rails
    Mess around the car
    Nick cutting out the 3mm steel for the box steel to be welded too
    Nick Tack welding the steel to the sides
    This was then removed, and sprayed up (to ensure this doesn't ever rust)
    All done
    Welding bolt eye into place
    Half done
    Lovely jubbly
    more welding
    Seat rails in
    Trial mounting seat
    [img]http://i253.photobucket.com/albums/hh67/jamiebennett81/IMG_20130310_175802_zpsf4adaa74.jpg/img]
    AND fitted, sorry for the poor pic, but this was late, we were frozen beyond belief
  20. #59
    May 2008
    230
    few better pics of the seat in daylight
    Ordered my water methanol kit, DVC30 progressive kit, with low level float warning and 4 quarts tank. This also comes with the sensor showing the pump is actually pumping to stop any issues with detonation etc which is pretty important!
  21. #60
    May 2008
    230
    Bought a gauge pod, which is slightly angled towards the drivers seat
    Took the gauges out of the old Audi mounting brackets and trial fitted them
    Perfect fit
    Notice how the fittings are slanted also, so they point towards the driver
    Got myself a Makita angle grinder as well, as I need to cut up some steel plates to hold the alloy battery cage in and start making my custom heat shield
  22. #61
    May 2008
    230
    plan today was to get some more airflow to the FMIC
    Bumper
    Half cut out
    Done
    [img]http://i253.photobucket.com/albums/hh67/jamiebennett81/IMG_20130331_134258_zps296914fc.jpg/img]
    I tidied it up a little bit after this as well
    hanging on after drilling the crash bar a bit as well, as you can see its quite a bit more flow to the FMIC with the number plate cut out
    Bits cut out
    Cut out.....actually looks wonky the holes cut but that's because parts of the bumper are sunken
    Took it off and drilled the back with a larger hole saw to maximise flow
    Naked again
  23. #62
    May 2008
    230
    Tidied up the crash bar and finished off spraying it
    Decided to clean up the points where the crash bar mounts to
    Before
    Sprayed
    Dried and done
  24. #63
    May 2008
    230
    3m carbon arrived to finally do the missing bumper cover
    In yellow, but that doesn't matter
    Carbon covered
    Parts have arrived for the gauges today
    oil pressure sender
    Sump plug and sump plug oil temperature sensor
    nd my bits are ready from GStar wraps....SUPER excited about these
    Massive thanks to them. They can be found by searching for GStar wraps or www.gstarwraps.com
  25. #64
    May 2008
    230
    Few bits arrived for the car. Some of the cars performance issues is related to the stat and temp sensor as these are bringing the engine management light on, and this can really affect fueling etc.
    This figures because the mpg I get is piss poor even when coasting off boost and is effecting power top end as I don't think it can work out fueling correctly. Either running lean or rich
    Stat
    Temp sensor
    Boss to be welded into the intake pipe for the water meth
  26. #65
    May 2008
    230
    Superseize TIP arrived. This was a custom made one from SFS which fits to a K03 hybrid turbo, but goes into an 80mm MAF fitment. I wanted all one pipe, instead of having to use reducers from the MAF to the intake, as a hybrid runs an 80mm MAF
    MUCH bigger than the forge one
  27. #66
    May 2008
    230
    Battery relocation is a work in progress at the moment
    cut the brackets to pin the battery cage down. The lips on the end of the battery cage were to narrow and too thin to put bolts put through them, so I cut my 3mm steel left over
    cut and drilled the ends
    Started spraying them up, and the other black bracket is the top which goes over the top of the battery in the cage. The cage is too bling for my liking to its getting sprayed satin black also
    Trial mounted in the boot. You can just see the ends of the battery cage where they are too thin, so the metal bars will be clamping this down.
    I'm going to spray the white patch in the spare wheel well also at the weekend.
    Then all I have to do is drill the foot well and bolt it down, fit the negative cable then that's job done and I can start on the supersize TIP.
  28. #67
    May 2008
    230
    I will just leave this here...
  29. #68
    May 2008
    230
    went down to Portsmouth today to pick up the replacement subframe, was in bloody good nick as well, rushed back.
    car jacked up and ready to go
    Subframe was changed in an hour thanks to the help of Nick, but while changing it over we noticed the dog bone mount was absolutely shagged....literally no rubber left in the mount at all
    now going to order a polyflex replacement one
    got the dogbone mount done today, as it was absolutely fecked
    Old rubber from the mount, absolutely soft as butter....an uprated mount from a supplier I won't mention]
    Old bush insert cut off, but had to drill a 15mm hole....and drill bits come in 14mm or 16mm....so out with the 14mm drill and widened the hole until the small insert came out
    Insert out
    Bush was then pressed in. This was a struggle, but managed to do it with a clamp I had. Took a few goes as it was only a small clamp and it kept sliding off the bush, but got there in the end
    Put the whole dog mount together. Next challenge was to press the two main bushes enough for the bolt to grip through the center of them onto the connecting nut, but got there in the end
  30. #69
    May 2008
    230
    Fitted the dogbone mount tonight, hardly any engine movement now, and it's very stiff
    Then started with fitting the supersize TIP.
    Comparison (this is a custom made version as I run a K03 Hybrid, so it is a K03 fitment on the turbo end, but an 80mm MAF fitment the other end, as I run an LCR MAF)
    Fitted...excuse the absolute mess and wiring everywhere as I am in the middle of relocating the battery as well which is to be tidied up
  31. #70
    May 2008
    230
    small bits of progress tonight
    9.5mm bung's for the supersize TIP
    Started making the heatshield template tonight. Cut and ready, bit rough around the edges and a few bits to tidy up but on the whole it's sorted
    Looks like it sits very high, but that's because there is a bolt on the chassis so it's not sitting flush yet, and the bolt needs cutting off. It will sit lower once done.
    Shielding is going to be made from 1.5mm mild steel sheet, sprayed black, then wrapped in reflective heat material
    Ordered a few other bits as well arriving this week, more updates to come shortly
  32. #71
    May 2008
    230
    Few things arrived today
    Methanol intake pipe, thanks to Bill Brockbank at www.badger5.co.uk
    6 speed quick shift as well.
    Just ordering 1.5mm mild steel now for the heatshield and magmashield tape for the heat shielding
    still sat on the driveway going nowhere...
  33. #72
    May 2008
    230
    Since stripping the car, the buttons for the TCS and fuel cap are hanging loose in the car, so I have started to make the mount. The VAG com port is also going to be mounted into this.
    cut (maybe a bit too tall at the moment, but this is to be adjusted) and also small pieces to brace the sides of the mount
    This is how its going to look. It will sit lower than this as it is resting on the two bolts which is what it's going to be bolted onto. Will spray it black also to tidy it up
    Battery relocation done, but the boot is too thin to mount the negative wire too, which is causing a weak signal, so I need to get a longer piece of cable and mount it to the seat belt point
    Final filter relocation bits arrived
  34. #73
    May 2008
    230
    Started on my heat shield properly, cutting it etc
    From this
    To this
    fits perfectly, needs trimming more, and the holt cut out for the filter then its almost done
  35. #74
    May 2008
    230
    Did some more work on the car tonight, only had an hour or so though
    Battery tray
    two bolts in the way, out comes the angle grinder..... (earth for cable is going onto the engine mount where the hard pipe is)
    quick clean
    The issue with catch can as you can see is its a complete mess and in the way of the TIP, and the pipework is also in the way of the DV.
    This needs to be relocated. I have taken it off its mount
    Mock up of how it will look, and the catch can which is going to be mounted to the side of the heat shield. Other pipes need trimming down of course
    Got the day off on Thursday and Friday so I aim to finally complete it all then
  36. #75
    May 2008
    230
    Also just ordered a 5m roll of magmashield, to wrap the heat shield and to wrap the pipe going onto the filter (will also be sprayed satin black)
    Example picture:
  37. #76
    May 2008
    230
    Magmashield turned up today
  38. #77
    May 2008
    230
    So finally finished off my custom heat shield yesterday, really pleased with how it has turned out!
    Hole cut out and filter mounted
    Trial fit
    Rubber mount
    Sprayed satin black
    Here it is finished
  39. #78
    May 2008
    230
    ll in and done. Relocated the catch can as well and mounted it to the heat shield
  40. #79
    May 2008
    230
    Finally got the car up and running today with help of Nick.
    It was such a stupid problem as well.
    when I originally took apart the battery fuse box to fit a new cable, I only did up four of the nuts...leaving the other four loose
    We scratched our heads for a few hours this morning. We went and bought a volt meter tester in the end, 4 of the nuts were good and showing good current, but when testing other areas of the fuse box, the signal was very weak.
    We only figured this out because when applying pressure from the volt tester, we faintly heard a few sparks....then we realised the four nuts were loose....
    tightened these up and hey presto.
    SO frustrating because everything I had done with the battery relocation was right, and it was all undone from 4 nuts loose on the fuse lid
    I can't believe it was something so stupid!
    I then went for a test drive...almost straight away the car died on me and the EPC light came on and the car was struggling to run.....something had popped off
    found that the charge pipe to turbo had not been tightened
    Limped home, tightened it and all good
  41. #80
    May 2008
    230
    Few pics of the battery install in the boot. Need to cable tie the main cable to tidy it up still
    You can see the LCR spoiler in the passenger footwell I picked up the other night as well, going to fit this when it stops raining, much bigger than the standard LC spoiler
    and because race car
    finally got my hands on a facelift rear spoiler. Much bigger than the LC one.
    Pic doesn't do it justice, but when fitted it looks a lot bigger and much deeper as well. very pleased with it
  1. buy a bike or build a track car?
    By Syvo in forum General Chat
    Last Post: 21st April 2011, 21:18
  2. A3/S3 kick builds
    By will_S3 in forum In-Car Entertainment
    Last Post: 6th June 2003, 13:55
  3. Donnington Track Day
    By Joshie in forum Major UK Events
    Last Post: 27th February 2003, 19:07
  4. Tracking Systems
    By Jack829 in forum General Technical / How To
    Last Post: 20th February 2003, 11:54
  5. Donnington Track days
    By Simon in forum Other Brands & Models
    Last Post: 13th January 2003, 15:56
