EM TuningVolks Autos
    boost-addict's Avatar
    Aug 2011
    977
    diy mdf speaker ring/adaptors
    ok, so im no carpenter and probably could have taken a little more time, but you know, i rarely use a router, and proberly had the wrong cutting bit, but hey ho, heres my go at adaptor rings, that a knocked up in literly an hour
    so these are 6" speakers to fit in to the original location, the vibes have a shallow mount and including 10mm mdf produde about 20/25mm more then original location
    i did try and do a pod mount which turned out good, but kept hitting my foot, and just looked gash from a oem standpoint.
    so
    adaptor ring, i cut about 1/3 way down to allow movment of cone and it sits nice and centred
    then had to cut a slot becasue theres no other way to do it and get it right in to the corner to clear the door skin.
    i decided id go all bodge and use some masking tape and tape the out side and fill the inner side with thin packing foam (the stuff wrapped round games consoles and such)
    so once set in place i run some resin around the foam to make it go ridged, hold ot in place with the attempt to direct the sound out and not in to the back of the card
    and then with the foam back over you can see it still fits in the foam. all good.
    lastly if you want me to knock you some up give me a pm, and i promise to take more care with the cuts. i just did it as a spur of the moment boeardem type deal. but they came out really good. and i found why my door speakers were crap, the foam pretty much all the way round had seperated from the cone!
    hope you enjoyed that and give you some ideas of your own.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Did you make these for front and rears?
    Aug 2011
    977
    Front but i ended up doing it a different way after getting black air components
    Rears are easy i got a baffle to accept a 6x9 when i remember to collect the black air 6x9's speakers from work.
  1. AndyMac's MDF speaker spacers in DUBAI
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2013, 15:24
  2. Autoleads PC9-408 speaker line adaptor (Bose)
    By <tuffty/> in forum For Sale/Wanted - Miscellaneous
    Last Post: 16th March 2013, 12:29
  3. Andy Mac Front door MDF Speaker Adapters
    By Jay in forum For Sale/Wanted - Miscellaneous
    Last Post: 12th September 2011, 16:32
  4. A4 Avant B6 Speaker Adaptor Help.
    By stuart_75 in forum In-Car Entertainment
    Last Post: 2nd September 2007, 22:22
  5. speaker adaptor rings b5
    By rasA4 in forum In-Car Entertainment
    Last Post: 27th October 2005, 23:37
