Page 1 of 2 12 LastLast
Results 1 to 40 of 58
    Mar 2012
    52
    My LCR 225 - Badger 5 edition. PIC Heavy first page.
    Copied direct from other forums.
    18th November 2011, made the 350 mile round trip to go and collect it. Bought it from a very loving owner, who also gave me alot of other bits and pieces i wasnt expecting, like 5l of mobil 1 oil, tailor fitted car cover and a few others.
    Well here it is...
    Basic spec:
    225PS – 1.8, 20v Turbo – Running the standard map
    • K&N 57i Cone filter – freshly cleaned and re-oiled red
    • Jabbasport polished stainless heat shield
    • Autobahn88 Silicone Turbo intake pipe, in red
    • Newsouth phenolic intake manifold spacer gasket
    • Forge Motorsport closed loop diverter valve
    • N249 Bypass mod
    • Various replacement vacuum/boost hoses in red silicone hose
    Wheels/Tyres:
    • Standard Leon Cupra R 18” wheels – minor scuffs and discolouration, but no buckling
    • Toyo Proxes T1-R’s - All 4 newly fitted in February this year, with less than 5,000 miles covered
    Brakes:
    • EBC Ultimax Discs front and rear
    • EBC Yellow stuff pads front and rear – rears have plenty of life left, but the fronts are due for replacement. A set of OEM spec Ferodo pads will be fitted prior to sale.
    • New O/S/R calliper, lacquered red to match, fitted at time of brake overhaul (approx 35k ago), plus new brake fluid
    Chassis:
    • Superpro Polybushes - fitted to Wishbones, Dogbone Torque mount and Anti-roll bar
    • Audi S3 upper strut brace
    • Original Stock LCR spec springs and shocks – Firm and stiff, but not harsh
    • N/S/F Wheel bearing replaced – January 2010
    One thing I didn't realise, was how slow these are in standard trim!! Soo...
    FMIC
    Milltek exhaust, non res, with sports cat.
    this shall be fitted next week and hopefully in for mapping at P-Torque at the weekend...
    Today gave it a winter protection, using :-
    Auto glym SRP
    Jetseal 901
    Supernatural Hybrid Sealant
    Dodo Juice Purple Haze wax
    20/11/11
    Soo...
    Stealth
    Before,
    During,
    After.
    21/11/11
    Update again..
    Love it!
    Then I got lazy and got someone else argue with the seized cat bolts
    Already pulls so much better than the standard down pipe back system. Hopefully it'll be in for mapping on Saturday.
    24/11/11
    More pictures with another wax coat:
    Some pictures to show how (in)visible the intercooler is:
    27/11/11
    Well, took the trip up to p-torque yesterday.
    Arrived there will was tied up with another car but took the time to come and explain he was running slightly behind, but would be with me shortly.
    After he finished, onto my car it was. Strapped down and ran up on the rollers. Then, on the power run, disaster!! Down to 3 cylinders. Gutted. Especially as the previous lever had only just replaced the coils before I bought it. Will took off the. Engine cover off and found cyl 4 cool had come unplugged. Due to a broken look clip. I think he was relieved as I was!
    After a few runs, he unclipped it and took it out. Came back and handed me the keys, I took it out, and at first, a little disappointed, but i think this is due to how smooth it is. However, when I drove away, it felt ALOT better, I'm guessing it was down to the heat soak.
    Results were:
    Std 224bhp/fly
    P-torque 278.0/fly
    Std 175bhp/wheels
    P-Torque 242/wheels
    Std 219lb/ft
    P-torque 302lb/ft
    Will did say it made 315lb/ft at one point but was getting vibration from the flywheel do knocked it back
    The drive home, as expected, fun. Apart from pulling out from strensham services, giving it a boot full and BANG. I initially thought, well, rods did well lol. But it was the dump valve being blown out the charge pipe so a 2 mile walk back to get a screwdriver and all was sorted.
    Pics/vid
    Graph
    Vid:
    http://i432.photobucket.com/albums/q...2/d2135c8b.mp4
    (All was not as it seemed as you shall read further on...)
    12/12/11
    **** just got real y0.
    KW V3's.
    5/1/12
    Quick detail using New products and camera
    quick clean and playing about with my new 350d
    Mar 2012
    52
    Clean:
    17/1/12
    One of a few packages has arrived
    Delivery 2/5
    Delivery 3/5
    And 4/5
    Final delivery is here, many thanks to Russ, my mate who works for VW as a parts manager..
    All genuine:
    Cambelt kit
    Water pump with metal impellor
    Head gasket
    Head bolts
    Thermostat
    4/2/12
    A few pics.
    Managed to get the rounded bolt out, so its now at the stage of removeing the oil pump and strainer to remove the rods.
    I am also waiting on a delivery from the us of a..
    Some pics of today and yesterday.
    Loose from the factory? I've no evidence of the turbo ever being removed.
    Cleaned the pickup...
    Rod installation
    More parts
    Rocker gasket
    Turbo gaskets
    Manifold gaskets
    Updated 'sputter' big end bearings
    Tubular manifold
    3" down pipe
    3" sports cat
    Mar 2012
    52
    17/2/12
    Well, due to problems at home(gf...) Meant the rebuild pics are kind of non existant.
    Apart from this one.
    Heres a pic of the badger 5 tip:
    and the manifold:
    My rear arb also arrived today
    Here's 3 videos.
    Noise(with ESP intervention)
    http://i432.photobucket.com/albums/q...2/2ef8c02c.mp4
    Spool up
    http://i432.photobucket.com/albums/q...2/5a37b840.mp4
    And speedo.
    http://i432.photobucket.com/albums/q...2/b2d68bba.mp4[/QUOTE]
    24/2/12
    Well, a LONG overdue update. Not really been in the frame of mind to update due to becoming single again
    Anyway
    A new bit arrived..
    A Neuspeed 28mm Rear Anti roll bar. Decided i didnt like the red it was powedercoated so keyed it up and painted it matt black, in keeping with the car's stealthy appearence
    Fitting was a doddle, took all of 20 minutes, and has 3 adjustable settings, soft, medium and hard. Me being me, set straight to hard :P
    Fitted:
    Next up, was just an oil change, seeign as it hadnt been changed since the new rods and shells went in. Here is imo a picture worth noting. This is why I ALWAYS run a magnetic plug or atleast a strong magnet on the sump after doing a build, you can be as clean as you like, but in a workshop environment/home there will always be **** that gets in places you didnt see.
    I also Fitted braided lines, and did a full fluid change for ATE Superblue. Here is a few pics as to why it is nice to use when bleeding through
    Old:
    New:
    Next up was an offer I saw on here, vermiglius@aol.com Joel Vermiglio is doing a cracking deal on alignment/corner weighting/camber/castor (basically, if you can change it, they'll set it up) etc for £50. he is part of Bridgwater college's motorsport course. Having been in contact, I got my car booked in for tracking check and corner weighting.
    I took the trip down for my booking slot at 5pm, arrived to meet Joel and his tutor (who's name has slipped my mind!) to discuss how the car was used and what I wanted out of it. I explained that I shall be using the car on track alot so would want a reasonably aggressive setup.
    First of all he went round checking my current setup, height, wheel alignment and damper settings. I had set the alignment and height up by eye, And I was impressed myself at the results:
    FL
    Toe 5mm TTout
    Height 588mm
    Bump 3 clicks
    Rebound 1.5turns
    Weight 428.5kg
    FR
    Toe 5mm TTout
    Height 590mm
    Bump 4 clicks
    Rebound 1.5turns
    Weight 495.0kg
    RL
    Height 619mm
    Bump 6 clicks
    Weight 347.5kg
    RR
    Height 622mm
    Bump 5 clicks
    Weight 296.0kg
    They then went on to disconnect the roll bars to enable corner weighting.
    I asked for my corner weighting to be setup with me and a passenger of similar weight, as Im usually on track with a passenger.
    The results looked like this:
    Shes a lardy mofo!!
    I let them work they're magic on it and here is the result(without passengers) after the 1st adjustment
    Not bad I thought!
    And after another tweek(with me and a passenger)
    Truely impressed!! Joel and his tutor then discussed any handling characteristics I liked or didnt with regards to the dampers, after a short chat they decided to stiffen the front and soften the rear a tad.
    Here are the final settings:
    FL
    Toe 5mm TTout
    Height 592mm
    Bump 6 clicks
    Rebound 2.5turns
    Weight 457.5kg
    FR
    Toe 5mm TTout
    Height 590mm
    Bump 6 clicks
    Rebound 2.5turns
    Weight 466.5kg
    RL
    Height 621mm
    Bump 2 clicks
    Weight 317.0kg
    RR
    Height 622mm
    Bump 2 clicks
    Weight 325.0kg
    All in all, I've not really had a chance to push it yet, but the feel of it is very different, feels alot more keen to corner rather than a bit, 'fidgity' like it was.
    I can highly recommend them for how it was set up and I'm happy to have taken it there, Its not actually a case study or part of they're course, the money goes towards they're castle combe race car running costs, and they get valuable learning experience of how to set different cars up.
    Mar 2012
    52
    27/2/12
    So!! Saturday came, And i departed at 8 to make the trip up to Bill, to have my map reviewed after a few changes.
    After chatting with Bill discussing how the car drove and what has been done he set about getting it on the rollers.
    He ran it up and Disappointment followed...
    Power was pretty much what P-torque said, however, torque was a good 60lb/ft down. Not only that, but it was very lean. VERY lean. to the point that EGT Protection was kicking in by 6000rpm.
    I shan't repeat Bills initial comments lol.
    At this point, it was decided a Full map would be done.
    So after a few Tweeks bill had the AFR's down to where they should be. He then started working on the boost pressure.
    A few running shots:
    We found that either i have a weak actuator or a rather worn turbo as peak boost even after a spike was 22psi. and tailing off massively towards high RPM. However, even with this little boost, both Bill and Tufty were impressed with the power it made. What impressed me and I feel is a testiment to Bills Mapping is the torque 'curve'
    As seen here:
    And here is the other sheet showing how bad the AFR's were,and how the boost tails off.
    On the Road, Its an absolute missile. scarey thing is how its acceleration between 3000-6000 is nigh on the same all the way through, makes a quick motorway overtake, with a dab of the throttle into silly speeds very quickly.
    Taken on bored Bills advice and have started on the parts he recommended, a new Actuator, and a water meth kit.
    Oh and I had to modify a sticker I had
    Then yesterday I did a quick refurb of my wheels:
    Before:
    After:
    7/3/12
    Got my Methanol
    And the new actuator sorted the lack of a boost spike
    10/3/12
    Oh My welly cooler turned up and so i took no time in fitting it.
    Old and new:
    New one:
    And thats to date
    Mar 2012
    52
    Sooo, Clutch change today.
    Not much else to say.
    1045am:
    12pm
    New clutch in
    1230
    230pm FINISHED!
    Then faffed about fitting new droplinks:
    Finished product
    warren_S3's Avatar
    Oct 2007
    6,104
    Love a bit of Cupra R action.
    Dare I say it on an Audi forum????? LCR, the most fun you can have on the Mk4 Golf platform?!?!?!?
    Good work, and getting close to the magic 300!
    Like it all apart from the rear window sticker, great work!
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,186
    Always liked these, looks good
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Mar 2012
    52
    The rear window sticker was originally a p-torque sticker that i arsed about with. Has gone now though came off when i washed it yesterday lol
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,617
    Impressive work
    Mar 2012
    52
    Yes, certainly hope so!!
    Anyway.
    The start of a 2 day detailing session. I started by tidying up a few bits a pieces i wasnt satisfied with. namely the routing of my WMI pipe work, no pics, but it now follows the brake pipes.
    Today, was refitting of the new Splitter after i destroyed it leaving the workshop when i did my clutch :censored: I also refitted my passenger fog:
    Then onto the arches and liners, Scrubbed using AG Engine and machine cleaner and a bucket of water and various brushes:
    And dressed with UB40
    Tomorrow, is Paint correction and glaze/wax etc etc. I shall be joined by My glamourous Assistant I have bribed with letting her use my car as a Test mule for her first rotary attempt. And probably food. lol
    Day 2:
    Heres a few pics after the finishing touches:
    Products used:
    Chemical guys Glossworx wash
    Dodo juice clay bar
    Poor boys SSR3
    PB Black Hole
    Nattys Blue Paste (didn't like the results, so topped it with some CG Butter wet wax)
    Clay(this was the most contaniment(sp)
    A few swirls before hand:
    No pics afterwards, however I shall grab some tomorrow.
    Finished Product, My glamours assistant was delayed before coming round so Turned up intime to put on the tyre shine lol
    My Favourite one:
    Mar 2012
    52
    My new plates arrived today, had the reg transferred over yesterday
    And I've bought a GT2871r kit
    Feb 2012
    Leicester
    13
    Just gone through the build thread. Some very good progress. Look foward to future updates
    Mar 2012
    52
    Thanks fella
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,527
    Brilliant work here dan, very impressed and that car moves!!! Sounds great too! What map did you have that was running lean? I may have to get bill to check my map when i go for my tip as i have a feeling its not right. But lovely car!
    EDIT: read the post and it was p-torque doh!
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    I love these cars - was going to buy one a few years ago, but due to my age and insurance costs, I had to settle for a MK3 Ibiza Cupra R.
    Mar 2012
    52
    Guess what's here :D2871r time!Just need a clutch and injectors.
    Feb 2008
    2,810
    Great read that.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,158
    Christ, someone doesn't hang about! Good work here mate.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Mar 2012
    52
    Its like a bug isnt it
    I've had a message from Bill saying my Hotside is ready to come back, he has ported it slightly and improved the wastegate as it was tiny apparently. And he has welded in an EGT Sensor boss.
    I also have some 630cc injectors en route Now all i need is a clutch
    Mar 2012
    52
    Castle combe action day today, car performed faultlessly apart from the atrocious weather and the continentals not coping very well(scrubbed 1.5mm off today) so they are now borderline. getting changed monday for the michelins.
    Had a minor excursion in the first session about lap 3, understeered at about 120 in folley which resulted in a minor tail slide correction, decided to take the safe route of the Grass for about 300 yards, and lost the splitter and passenger fog light grill. But it was very quick, across 4 sessions, i think 4 cars over took me, namly because of traction out the corners, wheelspin in 4th was a pain.
    Over took numerous cars, and pushed an hawk eye Impreza into a spin trying to out brake and corner me.
    Pics, note the grass :lol:
    Mar 2012
    52
    Busy saturday me thinks.
    Mar 2012
    52
    More of mine:
    Hassling the DC2
    DC2
    Then next lap, the m5:
    By the looks of my hand movement, i was getting a little frsutrated with the car infront...
    Mar 2012
    52
    I have ordered my new brake pads
    RC8
    Outrageous stopping power, these pads must only be used with other CL products as power is so high. These are for use in the most severe conditions such as GT racing, WRC Tarmac, World Touring Car, and NASCAR.
    I think they'll do.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,527
    Car looks lush matey! Nice to see it coming along great but ouch with the splitter lol!
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    How the hell have I missed this thread! So much hard work has go onto this.
    Looking forward to the new turbo setup......as if you needed a bigger tutbo!!
    Mar 2012
    52
    So update. Unfortunalty, my camera died after about 4 pictures.
    Basically, all was ok, until, it came to fitting the downpipe. the 2871r is longer in a dimension somewhere meaning the relentless manifold and downpipe fouled each other. so a bit of 'tolerancing' was required. a small dink in the manifold and about 10mm of downpipe plange was cut away to allow fitment.
    This has meant its making contact with the body somewhere which is annoying as I cant see it, so it's coming off again tomorrow for more 'tollerancing'.
    Started up with the new clutch and it is genuinely silent. Ive not seen a SMF conversion like this until now.
    Clutch feel is lovely, very OEM.
    Turbo wise. Well. OH MY GOD. Spool is just the same as the K04, but, its holding 26psi at 75% throttle at 5000rpm Before I Bottled it. as my laptop didnt standby and had gone flat again.
    Laptop charged up today, +10% fuelling, and -5* of timing to make it run a bit safer when on boost.
    Did a quick log, it started to run lean at 6300 so aborted, however just as i aborted the highest MAF reading was 269.11g/s (336.25bhp) Its going to be a quick one
    N75 Now unplugged to limit it, and now its the LONG wait until the 2nd of june until Bill Can get it in to map it.
  28. #27
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,067
    Sounds awesome Dan!
    I saw this on track at Combe, looked to be going well. Didn't realise the spec at the time, it's a proper sleeper!
    I didn't realise Joel was doing geometry for people now either! I went to school with Joel so I've known him for years. I think I'll have to get in touch to get mine setup!
  29. #28
    Mar 2012
    52
    Thanks fella, Yes it felt really good at combe, but there was too much traffic and too little traction to really press on. Joel seems to know what hes doing from my experience. Ive got a half decent idea of suspension setups from doing my apprenticeship in a motorsport based workshop, but it was good to speak and learn a little more
    Yeh I like the idea of it being stock looking
  30. #29
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,067
    You need a diff my man! I think it was dryer when I went out later in the day, but I wasn't struggling with traction at all really
  31. #30
    Sep 2011
    69
    what clutch did you go for in the end?
  32. #31
    Mar 2012
    52
    A diff is certainly on the cards, I've got a spare box to rebuild, just time and money I don't.
    I went for the awesome GTI Clutch
  33. #32
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    nice car and great work.
    is the gt28 an 'eliminator'?
    and where did you source that from?
  34. #33
    Mar 2012
    52
    Thanks.
    yes it s 2871 eliminator, was from a member on here.
  35. #34
    Mar 2012
    52
    Few deliveries to fit this weekend...
    Compbrake top mounts
    and my new RC8 pads
    We also have the arrival of my £400 beater
  36. #35
    Mar 2012
    52
    Well, new fuel pump fitted today, Cable tie was until i could replace it with a jubilee clip.
    Wired in with the other pump with an inline fuse.
    New RC8 Pads
    And its nice when people take pictures without you knowing...Yes I really need to shave...
    And on another note, I'm going to semi Start up as a specialist to 20vt's and Renaultsport among things. Ive got use of the workshop seen in the pics, and will be working under the name of the owners, but will be doing the specialist work for them. So feel free to bring the business to me if your in need of any work doing
  37. #36
    Mar 2012
    131
    Great read :-)
    Martin
    S3 2003 Avus Silver, Sunroof, Chrome Mirrors, Symphony II, Cruise, Heated Seats, Centre Armrest, Ambient Lights, GTRS Turbo, Forge FMIC, Sports Cats, MillTek, Coilovers ...
  38. #37
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    Well done!
    Wheres the workshop??
  39. #38
    Mar 2012
    52
    Workshop is in Glastonbury and we're less than a mile from clarks village so perfect excuse to have your car done as the mrs can go shopping
    Update:
    Comparison to the K04.
    Not quite the result I was hoping for tbh, but I believe this is down to the K04 flange being too restrictive for the 2871's flow.
    Final Figures were
    336bhp
    291bhp at the wheels
    321 torque
  40. #39
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    3,991
    The delivery is nice, even if the figures aren't quite what you were hoping for.
  41. #40
    Mar 2012
    52
    Oh certainly. Its an absolute missile once rolling. in gear 40-140 is quite frankly scarey.
  1. 10 Course meal anyone? (pic heavy)
    By jojo in forum General Chat
    Last Post: 1st September 2011, 09:48
  2. My car (pic heavy)
    By Ardz83 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th June 2011, 10:12
  3. what do you think??PIC HEAVY!!
    By tangerinedream in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2011, 19:00
  4. S3 Photoshoot (Pic Heavy)
    By S38P in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2010, 08:46
  5. My A3 progress, pic heavy
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2010, 11:16
