DPMVAG Check
    Aug 2010
    23
    Post Thanks / Like
    project vimto b5
    after putting up some pictures been asked to do a project thread.... so hear goes ( sorry about all the pics of work so far )
    this is the only pic i got before stated work:
    new wheels running et33 on the front et27 rears
    how it stands so far, cage still needs harness bar fitting, have a louvred vent to fit the bonnet interior to finish.
    not hundred percent sure if the purple is staying thinking about white?
  2. Likes ScottB5 liked this post
  3. # ADS
  4. #2
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,021
    Post Thanks / Like
    i like it. looks good so far. keep the updates coming
    Current mods
    Forge 007P, front mounted intercooler, smoothed airbox with jetex panel filter, boost gauge, broadband AFR, 312mm brakes, 3" downpipe/decat,straight thought, s/s backbox, stage 1 remap, coilovers, silicone TIP
    WantedS3 upper strut brace
  5. #3
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,611
    Post Thanks / Like
    As said mate, nice to see something different done on a B5.
    Do you get any rubbing with the low et on the rears?
    Also, what frames did you use to fit the bucket seats?
    Project RS28 build
  6. #4
    superkarl's Avatar
    MACH 9
    Mar 2010
    Southport, N west
    3,712
    Post Thanks / Like
    keep purple!!!
    superangry
  7. #5
    Aug 2010
    23
    Post Thanks / Like
    my missus said the same on sunday after a drive so purple may stay.
  8. #6
    Aug 2010
    23
    Post Thanks / Like
    Quote Originally Posted by Foxmeister View Post
    only had rubbing once when we moved house and was a lot of weight in the back, but even before the cage back seats were very rarely used. had to make my own subframes as apparently unless you buy that manufacturers seat they wont sell you a subframe and want reciepts and serial numbers from you ie. if you want cobra frames you have to buy cobra seats. everywhere i cantacted tha listed a4 frames said the same. if you strip down a standard seat there are various ways of making a frame, i cut everything away leaving the three mounting points then welded in a box section frame around that.
  1. Project A3 8l 1.8t
    By Jordan1.8t in forum The Project Room
    Last Post: 15th March 2011, 20:43
  2. Project anyone?..
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2010, 12:56
  3. my New A4 Project "Project Dogs Dinner"
    By Drifterwanab in forum The Project Room
    Last Post: 15th August 2010, 18:43
  4. got myself a little project!
    By monkeyboyuk in forum Classic Audi Forum
    Last Post: 28th February 2009, 17:52
  5. project anyone?
    By pt7550 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th February 2007, 22:02
