Chris NottVolks Autos
Page 8 of 8 FirstFirst 12345678
Results 281 to 302 of 302
Like Tree12Likes
Thread: Audrey The Dirty Derv Build
  1. #281
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    I fitted my auto dimming mirror today.
    Not much to it. Unbolt the old one, bolt the new one in and give it power.
    I used the illumination power cause I don't want it running all time and it saved me from running another cable.
    I used the earth for the lighting unit in the roof.
    I also ran the cables for the side dimming mirrors just in case I buy a set at some point.
    Pics.
    Before
    No mirror
    Wiring
    Done
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  3. #282
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Since I fitted my RNS-d I've always had a TMC unit connected but could never get it to work.
    I had some spare time over the weekend and I set about removing it completely because it never worked and I was not going to buy another one for £100.
    With it out and broken, I thought i'd take it apart and have a butchers just in case I could get it working.
    With it in bits, I found out the onboard fuse has blown.
    Before I order any I bodged it together with a normal 5amp blade fuse and it worked on the bench.
    Updated the firmware and set about finding some new fuses to order.
    Found some on eBay, ordered, delivered, fitted and put back in the car.........................Still did not work.
    Checked the coding.
    All correct.
    Checked the power, present and active
    Only thing left was the canbus cable but they are connected...........I know, I'll swap them over.
    TMC unit is up and on line.
    One issue I got is I'm unable to change the TMC source for the traffic information.
    I went in to Radio and Navigation, Adaptation and block 06 should be set to 1 for Radio as the source but the TMC always seem to show Telephone.
    I'll keep playing about and see what happens.
    With TMC in the car I thought it was time to get the aerial working.
    I removed my shark fin aerial, wired up the correct plugs so I can use a standard aerial and bought a smaller Polo aerial.
    I've not had a aerial on Audrey for over a year, it might take some time to get use to it.
  4. #283
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    What a build thread and you went and fitted an aerial...............OMG!!!
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
  5. #284
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by Brodster View Post
    It beats cleaning it every week................OMG you cleaned it again, it looks the *** same as before.
    Brodster likes this.
  6. #285
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,402
    I cant help cleaning it........my OCD is taking over.
  7. #286
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Since I've owned Audrey the door trims was rusting away and starting to fall off.
    Bout 3 months ago one of them got caught on a bush and fell off and kind of forced me to buy a set.
    They turned up yesterday and since the weather was nice i thought i'd spend 20mins and fit the new ones.
    Before
    During
    After
    I had the passenger side of the car painted cause one wing was damaged and going rusty and the other was badly painted and started to flake.
    They did the whole side of the car and at the time I thought it was really good, then I started to notice bits that was wrong and not very good.
    When I removed my lower door trims, I noticed this.
    It looks like they only painted up to the door trims with some over spray dribble paint stuff being. The edge you can see if very harsh, you can feel the layers of paint.
    Not much I can do at the moment but I'm a little bit worried about the paint starting to flake and then slowly taking all the paint off the door.
    The door is starting to bubble round the clip studs so I need to get it sorted out at some point but not this year.
  8. #287
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    I've been toying with the idea of buying some sun shades for Audrey but not the square stick on ones from halfords. Proper made to measure B5 Sun shades, a set was located at vanstyle.co.uk and I got my ass in gear and bought a set.
    Fitting was easy, little bit of bending needed on the blinds to help them fit in but once in it was very snug.
    On with the pics.
    Boot lid external.
    Boot lid internal.
    Rear Boot window internal.
    Rear Boot window external.
    Rear Passenger door external.
    Rear Passenger door internal.
    Rear boot window external.
    Rear boot window internal.
    Rear drivers door internal.
    Rear drivers door external.
    Doors open to show light without blinds.
    Doors closed to show light with blinds.
    CHEZ likes this.
  9. #288
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    A small update on the facelift clock project (A small project).
    Had a bit of a button bash some coding while trying out a canbus cable idea and it worked.
    I now have fully working facelift B5 clocks in my preface B5.
    Bonus.
  10. #289
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,786
    Great work Scott! Clocks look gooooooood
    <Jay A3 build thread>
    241bhp K03s - R Tech
  11. #290
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Not much happening at the moment. Just sorting some bits out for my next little AV project.
    These bits turned up today.
    As a result of what I'm doing, I'm selling my Xcarlink and iPod video if anyone is interested.
  12. #291
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    PhatBox PhatNoise Install
    I've had a Xcarlink in the car since my very first RNS-d unit and its always worked well and done everything I've asked (Even watched movies on my iPod video) but I've wanted more of a OEM fit.
    I've heard and read about the phatbox but never paid it much attention until now.
    I spent a couple of weeks looking at different phatbox adverts on ebay and trying to work out the best way to build up a phatbox kit then I came across a advert for a new, in box, unused phatbox and thought sod it. I'm buying it.
    So I sold I Xcarlink and bought the phatbox.
    In a box.
    The Phatbox
    Dock and DMS
    Ready to install
    Placed in the boot
    DMS Phatbox installed
    DMS and boot rebuilt
    How long is this changer cable?
    I was never aware of the phatbox having voice prompts but it does.
    Pre-recorded voice for the menus and options but a Stephen Hawkins style voice for the albums and artists.
    EDIT:=- I've changed the voice from Stephen Hawkins to Microsoft Anna. Sounds better and easier to understand.
  13. #292
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    G60Leigh from the 8L sold me his MiniMedia player he bought off ebay.
    Its about the side of a pack of cards, USB and SD input, Remote control, HDMI and A/V outputs. The HDMI out put is of new use to me cause I wanted it for the RNS-d.
    The unit needed some modding for it to be usable for my needs. The IR needed moving to the front of the car and I wanted to the IR moved there as well.
    about 30 metres of cable and 2 plugs was ordered to run the IR and LED from the boot to the front.
    Some testing also highlighted that the 3.5mm A/V jack was wired different. The Jack went first ring Earth, 2nd ring Video, 3rd ring left, 4th ring output but I needed 1st ring left, 2nd ring earth, 3rd ring video and 4th ring right. So that had to be moved and modded.
    With the media player and bits looking like this.
    Next was thinking about fitting the IR and LED into dash.
    The best place i could think to put it was in a switch blank.
    Spare switch blank found and drilled. (Can you see the face?)
    Cables routed and switch put back
    Cables routed to the boot, media player connected up and fitted back together.
    Quick test.
    WooHoo. it works.
    Hopefully that's the media/TV side of the RNS-d done up front.
    Couple of other little bits I want to add/do but they will come in time.
    For now I will enjoy my media player, sort out a proper on off switch for the boot power and find a smaller power supply for the player. The normal 240V plug running off my inviter is not ideal.
    Sandra and PAULF like this.
  14. #293
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    What's going on with your weird thumb in picture 2?!
    The phatbox is something I considered before going xcarlink too. I'm just too lazy to keep my music up to date anyway!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  15. #294
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by Westy View Post
    The same thing it always does. Bends back a little further than normal.
    I prefer the phatbox to xcarlink (Other iPod adaptors are available) as its easier to navigate around your songs.
  16. #295
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    I finally got round to constructing a MFTTSW.
    Waiting on a slip ring to turn up and for me to change the colour of this wheel from blue to black.
    Full thread here.
    MFSW + Sports trip tronic wheel = MFTTSW or something.
    Jay A3 likes this.
  17. #296
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,786
    What colour is that steering wheel? Looks black
  18. #297
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by Jay A3 View Post
    Blue.
    Its hard to take a pic of it but its blue.
  19. #298
    Alex C's Avatar
    Lizard, Cornwall
    2,599
    don't know if this will be of interest to you but I thought of you when I saw it...
    Device to Cloud, Hands-On. Part 7: The Pi in the Car | Subscribe! | Channel 9
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
  20. #299
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by Alex C View Post
    That's very cool.
    Thanks.
  21. #300
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Not done much recently apart from driving and maintaining Audrey.
    But today I finally sorted out a switch for my rear electrics so I can power the Tuner, Media Player and Inverter without having the ignition on.
    I've also made USB power cable for Media player so it runs off a USB 12v charger.
  22. #301
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Bit of a update on the MFTTSW.
    I sat down last weekend cleaned all the old dye, oils and other contaminants off the leather ready for recolouring.
    Been looking at this product Leather Recolouring but not sure.
    Anyone got any recommendations?
    I also sat down and stripped off all the old peeling blue rubber coating off the air bag.
    Hopefully I'll plasti dip it this weekend to turn it black.
    I need to strip down the trip-tronic buttons as well.
    Not sure how to do that.
  23. #302
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Replaced my incandescent side lights with some T8ups supplied Cree LED side lights. Incandescent bulbCree LEDIncandescent bulbCree LEDSide lights only at night
    Jay A3 likes this.
  1. Hello Lads, A4 Derv novice here
    By caistor_bmx in forum The Welcome Section
    Last Post: 4th October 2011, 15:42
  2. eml and esp a4 2.5 v6 derv
    By rockierobin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2011, 21:17
  3. Dirty Derv thoughts!
    By phantom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2008, 20:49
  4. 2.5 Derv
    By d3fy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th June 2008, 20:23
  5. Back and lookin for a DERV..
    By Lowride in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th April 2008, 22:03
