EM TuningChris Nott
Thread: Advice RE: TSB
    S3 Big Andy's Avatar
    Stealth Beast Baby Yay
    Feb 2008
    Bramley Hants
    707
    Advice RE: TSB
    Hi, is this common knowledge in the UK? as I am having real problems with my car..
    Technical service bulletin, from another forum
    http://forums.fourtitude.com/zerothr...2605520&page=2
    It's 01-08-05 jan 23, 2008 2017064
    Basically says you get cold start misfires
    Try swapping spark plugs and ignition coils between cylinders
    Check compression and leak down of affected cylinders
    verify fuel quality
    swap injectors
    If all else fails:
    replace all 8 rocker arms and 8 hydraulic equalizing elements (lifters) of the affected exhaust side.
    Parts:
    022109423D Engine - Cylinder head & valves - Valve lifters
    06E109417F rocker arms ($20-$15 each)
    06F103483D Engine - Cylinder head & valves - Valve cover gasket ($15-$11)
    Phantom Black, Revo, 450+ BHP , Milltek Evom's, Autotech fuel pump, RS4 brakes 18" Pro Race 1.2 team Dynamics, H&R ARB's, Bilstein PSS10's, Forge Twintercooler, GT3071R, RS4 Injectors, Helix racing clutch, Custom downpipe de-catted straight pipe to back box, 12.6second 1/4 mile! 4.03 sec's 0-60 This isnt just any car, this, THIS WAS the Stealth Beast!!
    Gone but not forgotten
    VCDS GONE TOO
    http://www.andyoram.co.uk
    Mar 2008
    2,231
    Hi Andy,
    just spoke to our master technician,
    the only thing we replace over here is the coil packs and spark plugs
    and we usually find out its the coils packs.
    wouldnt try swaping them around, just replace with latest ones
    Dave
