Chris NottJMB Retrofits
Results 1 to 9 of 9
Thread: Washer jets
    Fast,not furious's Avatar
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    Washer jets
    Hi,i've noticed on newer models of A3,the spray pattern for the wipers now uses 3 jets each side,giving much better coverage. Is it possible to retrofit these? Can i do it easily? I have an S3 8P,07 chassis.
    If so,how much are they?
    regards,Gary
    S3 Brilliant Red - 340bhp
    Custom Code Phase 2 + PSS, Autotech pump, Hybrid Forge/ITG Maxogen CAI /Reflactagold, Sprint Booster, Forge Quickshift, Forge DV, Denso Iridium sparks, PCV mod/oil catch can, R8 oil filler cap, Sachs performance clutch,Exhausts UK custom stainless TBE, Braille no-weight battery,PIAA mirror white DRL's,exterior + interior leds, AndyMac's Sub upgrade, H&R springs, VMR VB3 18x8.5 gunmetal alloys wearing BF Goodrich G-force 235/40
    Mar 2008
    2,231
    Quote Originally Posted by Fast,not furious View Post
    regards,Gary
    Hi Gary
    the non heated ones are 4.55 each
    heated 13.30 each
    P&P extra
    not sure if they will fit straight in but look the same, just pull old ones out i guess and replace with new ines
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    I thought they were heated,as standard on an S3? I'll take some,just looked at mine,they've a small unit wired to them,i guess that's the heater? There's a number on the back - 8PO 955 988. Whats the total cost please?
    Dec 2004
    287
    The will not fit straight into the older type scuttle panel. I believe there is a retrofit kit on section 0-97 of ETKA though now though.
    Mar 2008
    2,231
    Quote Originally Posted by Nelson_R32 View Post
    Nelson could you please not advertise in this forum ,
    as this is a funded parts forum by ourselves
    Thanks Dave
    Parts Manager
    Dec 2004
    287
    Quote Originally Posted by stoke_audi View Post
    Thanks Dave
    Parts Manager
    Apologies Dave; I forgot to remove my signature from the previous post. I'll see if I can edit it.
    FYI; I tried this mod on my 2007 A3 a while back and the only obstacle is the scuttle panel. You could either be clever and cut the scuttle panel (I didn't fancy this in case I cocked it up) or fit a new scuttle panel.
    The '3 jet' washer retrofit kits it appears on ETKA as only applicable to A4 B6/B7 and C6 A6. Part number 4F0898101. BUT because it's a retrofit kit its more cost effective to buy the kit and throw away the bits you don't need as buying the two jets seperate is more expensive.
    Mar 2008
    2,231
    Thanks for that
    Dave
    Jun 2007
    Cheshire
    95
    Sorry to sound dumb but can someone please tell me what ETKA is?
    Cheers.
    StagsyA4
    Audi A4 (B7) 2.0 TDi S-Line (140 bhp), Saloon, Moro Blue Pearl Effect with...
    Black Leather w/ Alcantara | Rear Parking Sensors | BT Handsfree w/ iPhone 4 Dock | RS4 Pedals | RNS-E | Tints
    To come: OEM Xenon's | FB Steering Wheel | Centre Armrest | Bluefin | New RS6 rep's 19"
    Mar 2008
    2,231
    is the programme we use to look parts up and identify them from chassis number
    Parts Team (Stoke Audi)
    www.stokeaudi-parts.co.uk
    www.audiservicing.com
    Stoke Audi
    Stanley Matthews Way
    Trentham Lakes
    Stoke on Trent
    ST4 4DD
    01782 590428
