Badger5Chris Nott
    Widemonkeys's Avatar
    Aug 2010
    Durham, Durham, United Kingdom
    274
    A4 avant triangle cover screw
    I am just wondering whether you could help please. My wing screw has broken on my triangle cover flap on my 2002 A4 avant.if this is the correct part number 8E9860333 how much is it and how much for delivery? Also how can I pay
    02 A4 B6 1.9tdi Avant sport 130bhp, 18" RS4's, Cruise control, Armrest, Ambiant lights, LED number plate bulbs,Pressed number plates, rear RS4 ARB, blacked out grills.
    Wanted : S line front and rear bumpers , S4 lower grill, s4 door blades
    Mar 2008
    2,234
    Hi
    there is actually 2 different fixings for this
    if you pm me chassis number will supply correct one
    Dave
    Parts Team (Stoke Audi)
    www.stokeaudi-parts.co.uk
    www.audiservicing.com
    Stoke Audi
    Stanley Matthews Way
    Trentham Lakes
    Stoke on Trent
    ST4 4DD
    01782 590428
    Aug 2010
    274
    It's not the one that holds the triangle it's the flap on the boot that hides the triangle.
    Jan 2012
    Hi,
    I just got a B6 avant (2005) 2 months ago and had the same problem. I'm in the US and dealer price for this item is $30. I didn't want to pay that much money for an item that was just going to break again, so I created a mold from the OEM part. Before casting, I epoxied the broken tab back together and added material at the break point to beef up the rigidity in the weak spot. Then I used fiberglass reinforced polyurethane for the material to further increase the stregth of the part overall. Not sure what replacement cost is in the UK but PM me if you're interested in this improved part. See pics below. In the side view you can see the larger radius from the larger radius where the weak OEM part snaps.
    matt
  1. A4 avant triangle cover wing screw
    By crazy88 in forum Parts Requests
    Last Post: 9th August 2011, 11:57
  2. Drivers Side Sun visor/ Boot triangle cover
    By crazy88 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st May 2011, 23:36
  3. Avant load cover
    By quattrojames in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th December 2009, 21:26
  4. A6 Avant - Warning Triangle panel catch broken...
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th November 2009, 19:47
  5. Avant Load Cover
    By stevehall in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th February 2009, 19:34
