JMB RetrofitsAH Fabrications
    owdgit's Avatar
    Sep 2005
    UK North West
    112
    Brake wear indicator cable
    Hi, was wondering if this is a reasonably cheap part.
    It is the cable from the brake and anti lock at the hub end that goes into the bulkhead, it has a red and a black connector inside the bulk head after passing trough a grommet 2 cables to each plug.
    Would need both sides as the brake wear indicator cable has broke at the join to the connector block at the hub end.
    Audi A6 2.5tdi 2001 tiptronic.
    If it is silly money I will probably replace it with new cable and spade terminals.
    Thanks.
    Chris
    I like to think I'm an optimist.
    Mar 2008
    2,234
    hi
    the wiring comes with the ABS sensor
    131.50 inc vat
    Dave
    Parts Team (Stoke Audi)
    www.stokeaudi-parts.co.uk
    www.audiservicing.com
    Stoke Audi
    Stanley Matthews Way
    Trentham Lakes
    Stoke on Trent
    ST4 4DD
    01782 590428
    owdgit's Avatar
    Sep 2005
    UK North West
    112
    Cheers Dave, the soldering iron it is then, its only the brake wear indicator that the cable has worn.
