Volks AutosJMB Retrofits
Like Tree1Likes
  • 1 Post By voorhees
Thread: Vauxhall Astra Fault Codes
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    The wife has an 06 plate 1.6 16v SXI Astra H and we have noticed recently that the car seems to judder a bit and is holding back on power. I have since purchased Opcom and done a scan and the following fault codes have come up.
    P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    (00) - Present
    P1116 - Coolant Thermostat Valve Circuit Low Voltage
    (06) - Present
    I did change the thermostat on the car middle of last year as it was shot and since changing it, its made a huge difference, however the fault for it is still there even though I have cleared the codes, the above two keep coming back and he EML stays on.
    Any help would be much appreciated.
    Thanks in advance.
    Nilz
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    Nilz's Avatar
    Apr 2006
    10,087
    Hi Jase
    Happy New Year to you too, hope you are well?
    Thanks for looking into this, ive joined a couple of Vauxhall Forums, but getting no joy at all!!
    I will have a look at the fuses and possibly replace the 02 sensor and see if that makes a difference, do you think that would cause the car to judder??
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    If it keeps coming up it needs replacing anyway but I would assume the juddering is down to that,they measure oxygen so if fecked then your ecu is being given wrong data
    Nilz likes this.
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
