AH FabricationsBadger5
Results 1 to 7 of 7
    Dec 2009
    Durham
    76
    Renault Clio Immobilise Problem?
    Evening Dudes,
    my sister has a renault clio when currently has an issue starting...
    i presume its the immobiliser. i have replaced the crackshaft sensor and that didnt work.
    the engine is turning just not firing up.
    is there a know fix or a way to bypass the immoboliser?
    im going to try my obd software to see if i can reset it but it seems to be a faff.
    thanks for the posts in advance.
    mark
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,133
    The ecu cover on the 1.2 petrols can sometimes rub through the harness, coil packs are prone aswell also check the battery eart cable.
    Any fault codes stored ??
    Jan 2011
    northants
    165
    there is a company that do a bypass kit that plugs into the obd socket
    sorry cant remember their name
    Sep 2011
    268
    Quote Originally Posted by towcestervag View Post
    Ex-Car-theifs-R-US i think they're called..... lol
    ROGUE TRADER
    Jun 2011
    Great Melton Norfolk
    1,348
    There is free software you can download for the 4 digit pin code. I have it stored on my other laptop, i will have a look for you.
    Jun 2011
    1,348
    Just had a look for it ,but the free software has been removed now.
    Goosey's Avatar
    Jun 2011
    York
    56
    take it the LED is flashing when you turn the ignition on?
    try a spare key as they can break inside
  1. Renault Clio on eBay very funny!!
    By pauldazzle in forum General Automotive Chat
    Last Post: 22nd March 2010, 14:48
  2. Renault 5 Gt turbo
    By jarvis**turbo** in forum The Cool Wall
    Last Post: 4th January 2009, 19:58
  3. Renault Clio Cup Renaultsport 182
    By A3_Turbo in forum The Cool Wall
    Last Post: 2nd May 2007, 21:17
  4. Renault Clio 197
    By Olly_K in forum The Cool Wall
    Last Post: 25th January 2007, 20:52
  5. renault clio imobilser switch???!!
    By rockstar in forum Other Brands & Models
    Last Post: 13th January 2003, 17:02
Tags for this Thread
