JMB RetrofitsVolks Autos
Thread: Steering Judder
    Lancashire
    177
    Steering Judder
    I'm getting a juddering through my steering which feels like the front wheels are out of balance so I had them balanced but it's still not cured [img]/ubbthreads/images/graemlins/frown.gif[/img].
    It is only noticeable when accelerating hard and seems to kick in at 70 mph+ ( I mainly notice it when pulling onto a motorway from the sliproad and accelerating hard through the gears from 3rd to 5th), if you get to say 80 and then take your foot off the gas the juddering stops then when you plant it again the juddering starts. When cruising at a steady motorway speed the steering feels fine.
    Any ideas? I'm suspecting maybe a (very slightly) bent driveshaft or some other suspension part but I haven't run up any kerbs or anything [img]/ubbthreads/images/graemlins/confused.gif[/img].
    Christian
    Kent/Nr the tunnel of hell
    41
    Re: Steering Judder
    Sounds like wheels out of balance, try getting them balanced on the car, this then takes hub,disk etc into account, as well as wheels and tyres, something will only bend if it gets hit
    Bucks
    1,038
    Re: Steering Judder
    I've had this on various cars. Could be any of the following!:
    Wheels not balanced
    Tracking
    Bent wheel/suspension or something
    I've had all of them - if it is something that's bent chances are it will be juddering all the time I think (I stand to be corrected though!)
    If it's balance, you tend to "drive through" the juddering. Try getting it balanced again - it sometimes takes the tyre places multiple goes to get it done properly.
    I've always found Hi-Q pretty good.
    Lancashire
    177
    Re: Steering Judder
    Thanks Jo, I'm still thinking that it MUST be the balancing. Some of the young guys who work at these tyre places don't seem to know their arse from their elbow, I think I'll have the wheels checked again then if it's no better it's back to the dealer [img]/ubbthreads/images/graemlins/mad.gif[/img]. I've only just got my car back from them. They had it for six weeks replacing a fecking coilpack.
    Cheers,
    Christian
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Re: Steering Judder
    Christian,
    Sounds odd mate. I would have said 1) check all your wheel bolts are on tight and 2) get wheels balanced, but you've done that. Hmmm. [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Sounds like one for the dealer.
    AL
    Bucks
    1,038
    Re: Steering Judder
    Yeah - mine went to Hi-Q in Feltham. I was with the guy while he balanced it on the machine - he was explaining how it worked.
    He figured out that my wheel was bent (when the dealer couldn't figure that out !!) which was causing a problem.
    Car had also been in for alloy repairs, and the muppets hadn't put the weights back on !!!!
