On all Variants of KW coilovers we are pleased to offer less than half price fitting. Normal fitting price is 240 + vat.
The special offer price will be 100 + vat for fitting including 4 wheel alignment on our laser tracking machine.
If you would like a price for the coilover kit for your car please ask and I will get back to you
Here is some Info on the KW Coilover range.
KW V1's
KW Variant 1 inox-line Perfect Street Performance
Sporty Handling with factory pre-set damping
The ideal systems for customers wishing to rely on the experience of our engineers to set the damper setting, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety. The user is then free to decide the best height setting for their use and preference.
  • Optimally pre-set
  • Sporty harmonious damping technology
  • Stainless steel technology "inox-line"*
  • Individually height-adjustable
  • Lowering range approved by the German Technical Control Board (TV)
  • Fully finished complete solutions
  • High-quality component parts for long durability
  • Comprehensive documentation for easy use
KW V2's
KW Variant 2 inox-line Perfect Street Performance
Sporty Handling with adjustable rebound damping
The system intended for the experienced driver who does not only wish to determine the individual lowering of his vehicle, but also wishes to carry out setup adjustments. The adjustable rebound damper allows adjusting the pitch and roll behaviour of the vehicle and therefore the driving pleasure can be adapted to the own requirements.
  • Damping technology with individually adjustable rebound
  • Available in two different housing designs, "inox-line" and "basic"
  • Individually height adjustable
  • TV-tested adjustment parameters
  • High-quality components for long life
  • Comprehensive documentation for ease of use
  • Infinitely adjustable rebound damping
KW V3's
Variant 3 inox-line Perfect Street Performance
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
  • Damping technology with individually adjustable rebound- and compression technology
  • inox-line* stainless steel technology
  • Adjustment parameters approved by the German Technical Control Board (TV)
  • High-quality components for long durability
  • Infinitely variable rebound damping adjustment
  • 14-way adjustable compression damping
  • Unique, individually working damping force adjustment
