smudge_don
I know it's a simple thing, but i though i'd make a tutorial
You will need:
Bi-Xenon headlights
D1s bulbs
Needle nosed plyers
To start, take the clip off the back of the headlight cover for the dipper beam
And then take the cap off. You will be faced with this
Undo the 2 butterfly clips that hold the bulb in place
I tried taking the connector with my fingers, but it's a tight squeeze. So i grabbed some needle nosed plyers and gently pulled the cable and connector away from the bulb
Next, remove the bulb carefully, trying not to let the actual bulb touch anything
Next, place the new bulb in place, making sure the bulb is the correct way round
Put the connector back on and put the butterfly clips back in place
All done
Anyone want some Phillips Xenstart D1s bulbs?
You will need:
Bi-Xenon headlights
D1s bulbs
Needle nosed plyers
All done
