Home Page
+ Reply to Thread
Results 1 to 11 of 11
Thread: Ambient Temperature Display
    justandy's Avatar
    justandy is offline Not an S3 owner!
    Jun 2004
    West Mids
    29
    Smile Ambient Temperature Display - SORTED!!
    My bargain basement? (A3 special edition - not SE) does not have the outside temp display switched on, I know it's there, under the clock. (no DIS).
    Does anyone know if this can be switched on with VAG-COM, I spoke to the stealers and they are unsure, they think it uses the same sensor that the A/C uses to sense below 5C and disable the compressor.
    They are going to have a go on Thusday FOC! Maybe I should get the door warning/puddle lights switched on to.
    Andy
    ***UPDATE***
    Top marks to Simon and Darren at Stafford Audi, they tried for over an hour yesterday and had no luck, they put in a request to Audi Tech and got a reply from Germany.....
    Seems there is a hidden channel (20) and this is coded to (1) to switch on the display. So off to stafford I went, again, and 2 minutes later success!
    They would not give me a copy of the tech report so this is only word of mouth, shame really.
    I don't know if this works for cars without aircon, you may not have all of the parts fitted, but if you have aircon it certainly works.
    Andy
  2. The Following User Says Thank You to justandy For This Useful Post:
    phil_w (November 10th, 2008)
    MarcQuinlivan is offline 6th Gear
    Dec 2006
    Ireland
    2,538
    As far as I know if you don't have the full DIS you can't enable the outside temperature guage.
    Although I have seen somewhere where you can enable the DIS for cars with DSG. I'll try to dig out the link.
    justandy's Avatar
    Jun 2004
    West Mids
    29
    My 04 A3 didn't have full DIS but still had ambient temp display, don't have DSG.
    Maybe it's a lost cause, it was, I think an option from new, buried somewhere amongst the specs, but it was never in the configurator.
    nhowroyd's Avatar
    nhowroyd is offline 1st Gear
    Apr 2008
    ILKLEY
    128
    My car is DSG but I didn't know it was DIS as I have no controls for it..... If it is possible to activate the DIS I would be happy...
    Nick
    July 08 - A3 Sportback SE 2.0 TDI 140 S-Tronic - Deep Sea Blue - Ipod - Aluminium inserts - TomTom Proclip mount - THB Bury Car Kit - DIS
    justandy's Avatar
    Jun 2004
    West Mids
    29
    There is a thread on here somewhere that tells you how to activate the DIS on DSG cars, it involves fitting a new indicator stalk with buttons to use the DIS and some re coding with VAG-COM.
    The local dealer tried for an hour to activate my ambient temp display but with no luck, they did however switch on my door warning lights, parts ordered for this mod thanks to Robin.
    Dec 2006
    Ireland
    2,538
    Found this over on vortex;
    You can enable the distance to empty bit without buying a new wiper stalk, but you'll need the new stalk to allow you to scroll through the other menus - trip distance, mpg, etc.
    Requirements:
    1) 2006 A3 - Possibly work on 2007 as well
    2) DSG... sorry MT folks
    3) Access to Vag Com
    4) Balls...
    Parts:
    1) Multifunction Wiper Arm - Part # -> 8P0 953 519 A 9B9 - $115
    2) Terminal Wire - Part # -> 000-979-009 A - $3-$4
    3) Assorted Hex toolset from T20 - T40
    4) Various Metric Socket Wrenches
    5) 12mm "Internal Wrench" -> used for taking steering wheel off. Hard to find.
    6) Small Handtowel
    NOTE!!! I am not responsible for anything explalined/outlined here. Please do at your own risk
    NOTE!!! Before proceeding to the sections 2 and 3 outline below. Be sure to let your car sit for 30 mins, then dissconnect the battery, wait for 10-15 mins, then proceed with the instructions. Failure to do so will set off airbag codes and may also DEPLOY THE AIRBAG!
    Section 1 - Vag Com - 5 minutes
    1) Plug and prepare the vag com through your cars diagnostics port
    2) Go to section 'Steering Column --> 16' and change your coding to 0012142.
    3) Go to section 'Instrument Cluster --> 17' and change your coding to 0000262.
    4) Once changes have been made, dissconnect the vag com, take the key out of the ignition and wait 10-15 sec.
    5) Turn the ignition on and wait for the idiot message to go away. You should now see the following screen shown below. NOTE that
    performing Section 1 will result in two things. One, the washer fluid empty icon will appear since our A3s do not have the sensor. Two,
    you will get the distance to empy readout. Section 2 will outline how to get rid of the washer fluid empty icon.
    Section 2 - Installing Terminal Wire - 30 mins
    1) Locate the top of the steering wheel column.
    2) In the space between the top steering wheel column and instrument display, lift the plastic column piece in an upward direction.
    3) The picture below shows where the clips are for the steering wheel column
    4) Now remove the plastic trim piece between the instrument cluster and steering wheel column. This piece should be gently pulled toward
    the driver seat to remove.
    5) Once the upper steering wheel column plastic and the trim piece is removed, two bolts will be revealed that hold that cluster in place.
    6) Remove these two bolts
    7) Once these bolts have been removed gently slide out the cluster. Note that the cluster only has one terminal connected to the back and
    has a lot of slack.
    8) Locate the terminal on the cluster and remove.
    9) Remove the zip tie and slide the pink retention clip in the direction shown below.
    10) Once the clip and zip tie are removed, remove the terminal from the casing by simply sliding it out.
    11) Install the terminal wire part # 000-979-009 A into terminal #20 as shown below.
    12) Once the wire is installed ground the other end to the chassis as shown below
    13) Note that performing Section 1 and Section 2 will give you Distance to empty and radio output as shown below. If you do not feel
    comfortable removing the airbag/steeringwheel/and computer modules, please reverse the procedure in section 2 and have fun with your DTE and Radio
    features. For those who are more adventerous, proceed to Section 3
    Section 3 - Wiper Arm Install - 1 hour
    1) Locate the steering Wheel telescope/tilt lever and remove the two hex bolts on the lever (pic shown below).
    2) After removing the two hex bolts on the lever, the plastic lever should slide out.
    3) Locate another hex bolt in the steering column directly under the lever and remove.
    4) Follow the lines of the column enclosure along the back of the steering wheel. You will find two hex bolts holding this enclosure in place (shown below). Roatate the steering wheel to gain access to these bolts and remove.
    4) Remove the lower steering column enclosure.
    5) Locate two plastic covers on the 3 o'clock and 9 o'clock and remove. One location is shown in the picture above in RED.
    6) Loosen the two torx bolts behind these covers. Note that the bolts will not come out but will eventually loosen enough so that the airbag will be removable from the steering wheel.
    7) The airbag unit should feel loose. Gently pull the airbag out and rotate it 90 degrees and place it in the steering wheel cavity. Note you may want to place a towel in the cavity so you dont scratch the airbag facia.
    5) Located directly behind the airbag are two connectors. Remove the yellow connector by unlocking it by pulling the orange clip away from the steering column followed by pulling the yellow connector away from the steering column (shown below). Next remove the black connector (shown below)
    6) Once the terminals are removed, you should have an emtpy cavity as shown below. Remove the bolt shown in yellow with a 12mm Internal Wrench. Note that you do NOT need to remove the bolts shown in red unless you want to.
    7) Once you completed step 6, you will see the following shown below. Be sure to mark positions of your steering wheel as shown below circled in red otherwise your steering wheel will become forever offcentered.
    8) Below is a view of the column without the steering wheel. The next steps will show how to remove the items circled in yellow.
    9) Remove the steering wheel control module plastic backing plate by removing the bolt shown in red and the clips shown pointed by yellow arrows below. NOTE to be careful with the "I know you F*cked with it tape. If your good, you can tilt the backing plate without destroying the tape... like me
    10) Now, once the backing plate is removed, grap the sides of the PC board that the plate concealed and pull directy down slowly and VERY CAREFULLY. There are pins (shown below) that can bend and break if you try to work it side to side. This is the step that you should take the most time on.
    11) Once the board is out (you can leave it hanging as I did. Remove the the top portion of the steering wheel control module housing. The below images shows where the two clips are located.
    12) Next we need to remove the clock spring. Shown below are 3 tabs. Pull up on them and remove the clock spring.
    13) Remove this small piece that lies directly below the steering shaft and directly in front of the washer stalk.
    14) Remove the washer stalk clip shown below and slide the washer stalk out.
    15) Install the new stalk and put back everything together by reversing all steps.
    THATS IT! The hardest part was figuring how everything comes out by seeing it the first time. But with pictures and intructions, this is an easy install. The hardest part for my was trying to remove the steering wheel control module board. Other than that this is an easy mod
  8. The Following 2 Users Say Thank You to MarcQuinlivan For This Useful Post:
    MarkSport (May 6th, 2009), nhowroyd (July 24th, 2008)
  9. #7
    justandy's Avatar
    Jun 2004
    West Mids
    29
    Bump!
    see edited firs post ;-)
  10. #8
    Dec 2006
    Ireland
    2,538
    I'll take a look at VAGCOM later and see if I can figure out what that setting is.
  11. #9
    phil_w is offline Neutral
    Nov 2008
    98
    Many thanks for that post - worked like a charm! Saves me buying parts and cable only to find the sensor already in place!!!
  12. #10
    MrTea's Avatar
    MrTea is offline Neutral
    Jan 2009
    Bournemouth
    53
    Interesting post... I had a feeling all this stuff could be activated fairly easy on the basic DSG DIS although I'm not sure if it would work for my 2005 edition and whether I've got the skills to do it...
    ..I removed the dashboard on my old car and it was never quite the same again
    2005 A3 2.0 TDI SE DSG, 3 Door, Phantom Black (aka The Scratch Magnet)
  13. #11
    carbon is offline Reverse Gear
    Jun 2010
    Quote Originally Posted by MarcQuinlivan View Post
    hi,any joy with the codes for all the modes-trip,distance,mpg.
    cheers
+ Reply to Thread
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
