As long as the stud pattern is 5x112 which I know many (all?) mercs are, they will fit. I think the centre bores are slightly different, but can be cured with the correct spiggot rings.
there is different types and lenghts of wheel bolts even if you swap wheels around on a merc though as I have already done that before, especially needed if the wheels are fakes although with mine i needed longer bolts for geniune wheels
Thanks for the feedback. I am going to be getting a genuine set of merc amg wheels. Ill check the pcd. Any heads up on the size of the spiggot rings id need?
