W8 PerformanceForge Motorsport
Results 1 to 21 of 21
    gynads's Avatar
    gynads is offline 2nd Gear
    Oct 2009
    335
    Post Thanks / Like
    S3 Stage 2 & misfire problems
    Hi all,
    Had stage one on for a while, with evoms , then decided to buy a Milltek DP and cat , with a custom connector pipe (same diameter as OE), and use the standard pre silencer and back box, and go for stage 2, after having the DP and cat fitted, i went to my tuner to have the stage 2. There is the dreaded misfire at 6 ish k.think it was cylinder number 3. They said it will be cured by fitting the rest of the milltek, (cat back) so i ordered this, along with the Autotech HPFP. Its being fitted on the 27th.
    My question is, will this cure the misfire? or will it remain unless i have the exhaust valves changed?
    Has anyone had to pay to have this done? As mine is an 07 its now just out of warranty
    Google Adsense Circuit advertisement
    sandip's Avatar
    sandip is offline 6th Gear
    Nov 2006
    Greater Manchester
    2,246
    Post Thanks / Like
    Just out of interest, what map have you got?
    Sounds like you've had a fair bit done, i know on the 8L the coilpacks tend to fail under load after a remap, could this be the case with your 8P? Or could it be a simple case of changing/gapping the plugs?
    APcoiloversNeuspeed FilterBailey DV30 Pipewerx cat backSamco tip3"Downpipesports cat350mm discs 4pots JBS K04 manifoldForge PCV HosesForgeUnos 16psi - 240bhp...Stage 0.5!
    dc240969 is offline 4th Gear
    Oct 2008
    861
    Post Thanks / Like
    Cured mine
    gynads's Avatar
    Oct 2009
    335
    Post Thanks / Like
    Quote Originally Posted by sandip View Post
    It's a known issue with valve float on MY 07 engines. Im just hoping as with DC's the fitting of the rest of the system cures it
    EDIT: its REVO software btw sandip
    gynads's Avatar
    Oct 2009
    335
    Post Thanks / Like
    Quote Originally Posted by dc240969 View Post
    Cured mine
    were you in the same situation as me DC? did you have the DP fitted first, had the problem so fitted the rest of the system?
    JamesS4cab's Avatar
    JamesS4cab is offline 3rd Gear
    Mar 2008
    660
    Post Thanks / Like
    Maybe worth running another diagnostics logged run with Revo as I had the same problem a few weeks back. They dropped one setting by one and that cured it. Sorry - i dont remember which setting, but looking at the logs, you could see that the engine was mis firing as it was correcting itslef due to one setting be too high. I also changed all the spark plugs when i had stage 2 software.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    S.'s Avatar
    S.
    S. is offline 2nd Gear
    Mar 2009
    Zgb Croatia
    476
    Post Thanks / Like
    i think that having milltek cat-back fitted won't change anything. i've had milltek tbe before remap, then i went straight stage 2 and after few months it started to misfire. same cylinder no3. mine went after fitting colder spark plugs. since then i didn't have any problems. i think it's a cheaper solution than fitting milltek cat-back.
    GConn is offline 1st Gear
    Jan 2009
    233
    Post Thanks / Like
    Replacing the exhaust valve springs will solve your problem. IF your car is indeed within the batch with those 'faulty' springs. I had mine fixed as a warranty FOC service. I've heard stories of dealers in the UK not accepting the bulletin warrencox had posted here.
    A downpipe and a free-flowing exhaust will relieve some back pressure, so it might help mitigate the problem, but it's not guarrantied. Milder settings also help in reducing the effect.
    It may worth making the effort to have this done FOC. If there is a 'campain' for your car from audi and the dealer did nothing, you'll have a valid argument. HTH
    gynads's Avatar
    Oct 2009
    335
    Post Thanks / Like
    thanks for your advice guys, i have the bulletin number so ill ring the dealer. What plugs should i be fitting ?
    phil76's Avatar
    phil76 is offline 2nd Gear
    Feb 2008
    SHEFFIELD
    323
    Post Thanks / Like
    I would also go with spark plugs on this,didnt the S3's have a batch or a different make they started putting in for a while and people were noticing a misfire on a standard engine never mind one running a map
    A3 S-line 2.OTFSI Quattro,Giac Software Est 260bhp
    S3 Bumper spoiler,LCR Frt splitter,Evoms Intake,Apex Springs
    Jan 2009
    233
    Post Thanks / Like
    maybe. I remember that after a point the OE sparks went cooler by a level, but I can't remember any details
    gynads's Avatar
    Oct 2009
    335
    Post Thanks / Like
    I hope so, i just hope its not valve float. i can imagine a big bill to change the valves. I'll order some IK24's and try those before the stage 2+
    Oct 2008
    861
    Post Thanks / Like
    Quote Originally Posted by gynads View Post
    no, my misfire lead to new coils, ecu. then l put colder plugs in. it was still there. then tbe went on and nada misfire since.
    sandip's Avatar
    Nov 2006
    Greater Manchester
    2,246
    Post Thanks / Like
    gynads's Avatar
    Oct 2009
    335
    Post Thanks / Like
    well the rest of the TBE is going on, along with some IK24's, (same temp as BCP8's) & HPFP, gonna try get hold of an RS4 fuel return valve/regulator. Fingers crossed it will be ok!
    waring192's Avatar
    waring192 is offline 2nd Gear
    Dec 2009
    North West
    390
    Post Thanks / Like
    I had the exact same problem as your are describing. Fitted milltek along with other stage 2+ gubbins and it was still happening. Took it too Audi and had the valve springs changed and problem was sorted.
    S3 Sportback - Ibis White
    Factory: Privacy Glass, Cruise Control, Heated Seats, RNS-E, Bluetooth, Bose, Ipod Dock
    Modifications: Revo Stage 2+, Forge CAI, APR HPFP, Milltek TBE - H&R ARB's & Springs - TV Tuner, Reverse Camera
    Wanted: Stock S3 facelift alloys
    gynads's Avatar
    Oct 2009
    335
    Post Thanks / Like
    Thats good and bad news! if it is definately the springs, im not sure if Audi will change mine as im out of warranty? could cost an arm and a leg. I take it yours was covered under warranty warning?
    waring192's Avatar
    Dec 2009
    North West
    390
    Post Thanks / Like
    Yeah its under warranty but i think you could have it done free as its TSB.
    S3RYE's Avatar
    S3RYE is offline Interior Next!!
    Apr 2009
    London/Essex
    3,304
    Post Thanks / Like
    Gynads... how did you get on with this?
    S3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    FOR SALE - S3 Front Brake Kit - USED - PM OFFERS
    gynads's Avatar
    Oct 2009
    335
    Post Thanks / Like
    Put a pcv delete kit on and sorted my revo settings out, I bought a switch and am running 9 6 6 and has sorted itself, looks like it was just rich, hope this helps
    S3RYE's Avatar
    Apr 2009
    London/Essex
    3,304
    Post Thanks / Like
    Amd have had my car two days & cannot find the fault with the misfire.. i was tempted to tell them to complete my TBE but now im wondering whether they have though about this?
Tags for this Thread
