AWEsome GTIEM Tuning
    RS_Cosworth's Avatar
    RS_Cosworth is offline 1st Gear
    Dec 2009
    Yorkshire
    126
    Post Thanks / Like
    Wheel spacers on 2.0 TDi Sport??
    Would like to fit a set of spacers to my 2.0 TDi sport which is fitted with a set of genuine 18" S-Line RS6 style alloys, and is lowered on -50mm H&R springs. Need a bit of help/advice though as to which ones I need and where to get them from
    Firstly, what size spacers are the ideal ones to have with my setup? (what is the maximum width I can get away with without causing rubbing issues ect..??)
    And secondly, where is the best/cheapest place to get the spacers and new wheel bolts from and how much will I be looking at to do all 4 corners?
    Any pics of your cars with spacers fitted would be gratefully received and may help me decide what width spacers I need
    Audi A3 2.0 TDi Sport, Lava Grey, -50mm H&R's, 18" RS6's, H&R 10mm Spacers On Front/12mm On Rear, Facelift Rear Lights...
    Google Adsense Circuit advertisement
    Advertising world
    Richy_C's Avatar
    Richy_C is offline 2nd Gear
    May 2010
    Derbyshire
    451
    Post Thanks / Like
    Well not got any yet but after a good research it seems that 10mm front and 12mm rear are the standard, reason being that the fronts are 2mm wider as standard.
    lowered 50mm you may get minimal rubbing on the rear but removing the screw from the inner arch will fix this.
    cheapest place would be DPM Performance (is active on this forum, Damian) and he can also provide the required bolts.
    DPM Performance Online Store
    May need to check with him that there is nothing different with your wheel to the spacer but should be fine.
    Sarah's A3's Avatar
    Sarah's A3 is offline V6 S3 Hybrid!!! vroom vroom...
    Cheshire to Perth AU
    5,520
    Post Thanks / Like
    Richy is right, I've also contacted Damian and hes a really helpful guy!
    DPM's Avatar
    DPM
    DPM is offline 6th Gear
    Jun 2006
    Newcastle/Durham
    3,572
    Post Thanks / Like
    Just give me a shout if I can be any help.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Dec 2009
    Yorkshire
    126
    Post Thanks / Like
    Thanks for the replies guys & gals, most helpful Will be ordering myself a set very soon
