Forge MotorsportW8 Performance
Results 1 to 17 of 17
    S3mad is offline Dark Knight
    Jul 2008
    926
    Post Thanks / Like
    Starting Audi A3 2.0 TDI
    Hi all ,
    i have a Audi A3 which is a few years old when i start the car in the morning it starts straight away fine but if i stop and then turn the car over again it takes a few sec's more to start the car ? Could this be the battery as its fine when i start it when its been sitting a while ?
    Current Audi A3 2.0 TDI New shape
    Audi S3 -MAD / Tax Beater /Forge 007/Stage 2 Vagcheck /
    Google Adsense Circuit advertisement
    ScottTDI is offline Neutral
    Aug 2006
    71
    Post Thanks / Like
    Does this only happen only when the engine is warm/hot?
    If your battery is o.k, then it is most probably a worn starter motor (quite a common problem).
    Regards,
    Scott.
    (8P)A3 2.0 TDI Sport-Dolphin Grey-
    1983 (DAC)Talbot Sunbeam Lotus - Weekend Toy.
    mike foster is offline Fossie
    2,313
    Post Thanks / Like
    Definitely starter motor. Very common on this engine
    Check ebay - usually loads at reasonable prices
    Jul 2008
    926
    Post Thanks / Like
    I had a look at the battery and the eye was black so its not green ... Starter motor if it was this then it wouldnt start straight away it has problems when its warm say i drive 20min and then park up for a few minutes and then start again ....
    2,313
    Post Thanks / Like
    The starter motor problem mainly occurs with a hot engine, not a cold one !
    Jul 2008
    926
    Post Thanks / Like
    Yes but how do we know this is the cause ?
    i dont want to spend out loads if i dont need it ?
    2,313
    Post Thanks / Like
    You don't !
    You'll have to get a further opinion. There are loads of threads on this forum about hot starting problems and 99% are down to starter motor.
    Good luck !
    Jul 2008
    926
    Post Thanks / Like
    Anyone?
    Anyone else any idea's?
    2,313
    Post Thanks / Like
    Can I suggest you read this thread all the way through. It gives everyone's opinions and possibilities and the answer is in post number 31 !
    GOLF/A3 2.0 TDI Starting Problem can anyone help?
    DiKapo's Avatar
    DiKapo is offline 1st Gear
    Apr 2009
    London
    214
    Post Thanks / Like
    i have the same problem and it looks like its the motor starter that is causing this so i am changing it soon and hope it solves the problem
    Jul 2008
    926
    Post Thanks / Like
    Any idea's of cost im wondering weather to get it changed as it starts fine but when hot a few turns ...
    DiKapo's Avatar
    Apr 2009
    London
    214
    Post Thanks / Like
    at audi starter motor costs at around £170 and at euro car parts same starter motor costs at around £120 plus labour job which is pretty easy to do
    tdi-man's Avatar
    tdi-man is offline 4th Gear
    Jul 2009
    882
    Post Thanks / Like
    new battery and starter helped to make mine start better..
    when diesel engine is cold it injects fuel to help start and when engine is warm it does not
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium door inlays / panal filter / Egr delete / custom map with hot start fix + warm idle fix / Hybrid Turbo / Helix clutch
    213 bhp - 294 ft lb - 399 nm
    FOR SALE
    TANDEM PUMP
    DiKapo's Avatar
    Apr 2009
    London
    214
    Post Thanks / Like
    tdi-man so u changed both and no problems after?
    2,313
    Post Thanks / Like
    You don't say what year your car is but if it has a BKD engine then you could look at this :-
    vw golf mk5 audi a3 starter motor tdi eos passat t5 vag on eBay (end time 30-Sep-10 23:14:29 BST)
    That part costs £267 from Audi
    tdi-man's Avatar
    Jul 2009
    882
    Post Thanks / Like
    i changed starter about ahout ago and started warm ok then changed battery recently as battery was shot and starts 90% better
    FOR SALE
    TANDEM PUMP
    Jul 2008
    926
    Post Thanks / Like
    BKD engine it is ,
    its not to bad at the moment im not changing unless it gets really bad just takes a few sec's more ...
